The ACO got it wrong again at Le Mans | Page 2 | FerrariChat
Discussion in 'Other Racing' started by william, Apr 26, 2011.
  1. AreOut
    AreOut Rookie
    May 3, 2011
    3
    Well they have to market those smelly tdis somehow..and Le Mans, thanks to its organizers, seems to be the cheapest way...
    So how are those two sentences connected?! Provided same regulations gasoline cars would make so much gap that they could sleep in a pit stop waiting for diesels..current 3.7 V6 diesel making 540 hp would definitely make over 1000 hp in a gasoline configuration.
    How is torque producing down force exactly?! And no diesels of same capacity and turbo pressure as gasoline do not produce even close what gasolines do. Diesels of same power produce more torque than gasolines, but thats another story and has not to do with racing.
    Nothing has caught up, they could make some huge turbodiesels and limit the gasolines to 1 liter capacity in 80s and diesels would win too.
    His sentence sounds so utterly stupd. "Noise is unused energy." Well, sir, racing is unused energy too, especially from some diesel driver point of view..
  2. normv
    normv F1 Rookie
    May 3, 2005
    2,767
    Mishawaka In
    Norm
    #27 normv, May 3, 2011
    Hello Torque by itself doenst make downforce, but it allows you to set the areo on the car for maximum downforce in the corners without robbing speed on the straights as the extra torque can overcome the unwanted downforce without losing top speed. Hope that helps in a non tech way of speech. Its easier with a lot of torque to PUSH that brick down the long straight as an Indy car is set up with less downforce in qualifying trim for maximum top end speed. Thanks Norm
  3. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    and that's the reason if we race at Le Mans next year we'll be removing the Ferrari lump and be replacing it with a 3.5 Liter Direct injection Turbo Diesel.
  4. tomgt
    tomgt F1 Veteran
    7,243
    Netherlands
    Tom Wiggers
    :-D
  5. william
    william Two Time F1 World Champ
    Jun 3, 2006
    28,054
    But still with the Ferrari logo on the cam covers, right?
    Every body else does it, so why not Ferrari?
  6. teak360
    teak360 F1 World Champ
    Nov 3, 2003
    10,065
    Boulder, CO
    Scott
    #31 teak360, May 3, 2011
    It doesn't.
    People say an engine is "torquey" which more importantly refers to making more hp at low rpm. Torque at the wheel, not the engine, is what determines the rate of acceleration. The more hp (not torque) at the engine the more torque at the wheels at any given road speed.
    It takes hp to overcome the drag of the aero. It's really the broad power band that helps the diesels. The useable power band of 3,000-5,000 rpm in the Audi LeMans car, for example, means you can increase your speed by about 2/3 (60 mph to 100 mph for example) before needing to shift gears. If an F1 engine put out the same hp from 12,000 to 20,000 rpm as the diesel does from 3,000 - 5,000 it would be a very broad powerband, but in terms of rpm delta expressed as a percentage it would be the same as the diesels. It would also accelerate the LeMans Audi, aero and all, at exactly the same rate as the diesel while developing much less torque. HP determines the ability to accelerate and overcome aero drag, not engine torque.
    In reality a modern F1 engine develops just over 200 lbs/ft of torque, whereas the Audi develops around 800. The F1 engine, however, develops about 100 more hp. Put the F1 engine in the Audi LeMans car with the right gearbox, and it will out-accelerate the diesel version because of the power advantage. Regardless of any aero settings.
    The Audi LeMans diesel engine develops gobs of torque and people like to think that is what makes the difference in "overcoming" aero. It isn't...unless you combine the torque value with engine rpm you don't know what you have. When you do, have hp. That's what matters.
  7. GTE
    GTE F1 World Champ
    Jun 24, 2004
    10,117
    The Netherlands
    Marnix
    Six likely overall winners. You could do much worse. Seven if you add the Oreca Matmut Peugeot (and why wouldn't you).
    Does it really matter that in LMP1 diesel is the way to go? In F1 at some point in time, rearengined cars turned out to be the way to go and then the FIA didn't even try to make rules to make life easier for those who were reluctant to make the change.
    So yes, if you are in LMP1 with a petrol powered car, you have some fierce competition on your hands. But you have brought it on yourself by sticking with an obviously outdated concept. We have seen this time and time again in the world of motorsport. The ACO shouldn't even try to facilitate those who refuse to make the change. And besides, all categories will have competitors who don't have a reasonable shot at victory. Why should that be different for the likes of Rebellion and Pescarolo?
    And of course, there is always the GT(E) class to look out for. They have provided us with some excellent racing over the past years, even with a leading role for the Ferrari's. This year will be no different.
    I will attend the LMS race at Spa next weekend and not long after will head out for Le Mans. And I for one, can't wait! :D
  8. AreOut
    AreOut Rookie
    May 3, 2011
    3
    Its not torque, its power. But because (for the same maximum power) diesel/turbo cars generate more average power than NA cars thats why they have advantage.
    Thats right, its not about torque number, but torque distribution.
  9. william
    Jun 3, 2006
    28,054
    As far as I know, LMP1 isn't a Diesel category only, so the organisers and the rule makers should have made sure that the equivalency between petrol and Diesel was respected and that the regulations were not bias towards one and against the other.
    More, the ACO had several years to correct its initial mistakes; apart from some window-dressing, it didn't bother as Pescarolo correctly said.
    Petrol cars are not "an obviously outdated concept", it's just a different fuel.
    If tomorrow the ACO introduced rules favouring turbines or electric motors, would you call the piston engine "an obviously outdated concept"?
    One can understand why the ACO favoured AUDI for so long, and now Peugeot. After the fiasco of the FIA World Sportscars Championship, the field at Le Mans was decimated, and most constructors withdrew from the race. Audi came, and promised to stay if the rules allowed it to showcase its Diesel technology. In an effort to keep at least one large manufacturere, the ACO taylored the rules to accept the Diesels and gave them huge technical advantages; capacity break, fuel tank, etc...
    Peugeot jumped on the bandwagon since, it too, wants to promote its Diesel production cars.
    That leaves most of the petrol teams at a huge disadvantage. There is no racing Diesel engines available off the shelf in any case; where could Pescarolo, ORECA, OAK, and others buy competitive Diesel engines - they are private teams!!
    Also, most traditional sportscars manufacturers are not going to design and race Diesel engines when it doesn't suit their production: Aston Martin? Ferrari perhaps?
    I don't even know why Aston Martin bother, really; it has no chance!
    All that is required is fair equivalancy rules between petrol and Diesel cars. Any group of automotive engineers could write these rules, and bring a level playing field at Le Mans.
    The ACO doesn't want it and prefer to keep the competition in favour of Diesels.
    When Audi and Peugeot will eventually withdraw, like most manufacturers do after a while, the sportscars field will have been depleted.
    Personally, I am not interested in watching an Audi Diesel procession and I will vote with my feet.
  10. tomgt
    tomgt F1 Veteran
    7,243
    Netherlands
    Tom Wiggers
    +1!
    We don't need LMP900/675 class. We want full field of GT1, 2 and 3 (maybe even GT4) cars. Some XP cars based on GTs..........P4/5C
    Le Mans 1995 was good!
  11. GTE
    GTE F1 World Champ
    Jun 24, 2004
    10,117
    The Netherlands
    Marnix
    Same as F1 wasn´t a rear-engined category back in the day. Or a semi automatic gearbox with flappy paddles-category.
    Such as the position of the engine is not an outdated concept but just the position of the engine. Really? Why is it that petrol engined cars aren´t able to keep up with diesel powered cars in endurance racing? Well, probably because Diesels are better equipped for the job. If they weren´t, we wouldn´t even need regulation to help the poor petrol powered cars.
    Why you suppose are diesels the weapon of choice for the big guns of Peugeot and Audi?
    If they turn out to be superior, than yes. Obviously.
    And whatddayaknow, diesels are simply crushing petrol in LMP1. That has nothing to do with ACO doing Audi a favour, but everything with the technical advantages diesel has over petrol in an endurance race.
    I don´t know, but if you´d agree they´d be buying dieselengines of they could afford them, we could also agree that diesel is obviously the way to go. The only way to stop diesel is to simply forbid them.
    Quite right. I´d love to see AMR putting up a fight against the Audi´s and the Peug´s next June, but I know it will not happen. I would love even more that Ferrari would return to Le Sarthe with an all new factorycar capable of gunning for the overall victory. But that is also not going to happen. Not because of the diesel-supremacy thought, but because Ferrari has other priorities. Ferrari left Le Mans way before a diesel even come close of sizzling down Les Hunaudieres.
    But that doesn´t take away from the fact that diesels are the way to go in LMP1 and that, if you want to win, you buy or built yourself a diesel.
    Back in the day Ferrari was opposed to the notion of a rear engined car (a horse pulls the carriage, it does not push it) but once reality leaves you no option, you either bite the bullit or go and do something else entirely. Or wait for ACO to ban diesel.
    Dieselcars aren´t better at endurance racing than petrolcars because they are being favoured by the rules, they are better at it because they are better suited for the job. It are in fact the petrolcars that need favoritism in the rule department to even have a shot at keeping up with the dieselcars.
    It would be ideal of petrolcars could keep up with dieselcars. But the reality is, they can´t. Not by a long shot. Why is ACO to blame for the fact that petrol has no answer against diesel? Why should they even be obligated to tweak the rules so the disadvantage of the ´wrong´ engine concept can be compensated?
  12. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    True.
  13. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Nope as Ferrari isn't helping us in any way we've taken all of their logos off of P 4/5 Competizione.
    Legally as what a car is is determined by it's chassis and vin # P 4/5 Competizione is a 2009 Ferrari and I guess even if we take their motor out and replace it with another manufactures it's legally still a Ferrari but it won't be running with any Ferrari Logos no matter what.
    As a further aside that is my decision. If I wanted to run with a Ferrari nose badge I would just as the Breadvan and countless other modified Ferrari's have in the past.
    As Ferrari Classiche calls The Breadvan, "A Ferrari of Historical Significance", I bet if we win The 24 of Nurburgring or in class at Le Mans next year that's what Ferrari will be calling us but I won't be.
  14. poppy84
    poppy84 Formula Junior
    Oct 19, 2005
    647
    Italy & Paris
    Andrea
    #39 poppy84, May 4, 2011
    In another way if you pay (Michelotto or the Factory or even Classiche) you have the right to put the badge on your car even if you loose, if you won't pay you have to win Le Mans to (maybe) get a chance to see P4/5C recognised as "A Ferrari of Historical Significance".
    My advice is: put a german diesel engine on, win Le Mans and after that, take a tour with your street legal P4/C and go eat a tortellini dish at Montana restaurant... :D
    [ame]http://www.youtube.com/watch?v=4rzQI1D1zPI[/ame]
  15. tomgt
    tomgt F1 Veteran
    7,243
    Netherlands
    Tom Wiggers
    They did with Prodrive in 2003 the same. 575 GTCs had to be made in Italy. UK Prodrive did not get the job because of Subaru rally parts..............they won GTS (GT1) class...........what was on ferrari.com: Ferrari wins Le Mans! (class) WTF!!!!!!!!????????
    So all these 550s and all Michelotto F40's can only get the typo II certification like Breadvan and 308 GT/M.
    P4/5C IS A FERRARI.
  16. teak360
    Nov 3, 2003
    10,065
    Boulder, CO
    Scott
    #41 teak360, May 4, 2011
    Because it is not an "open" class just like F1 isn't. Diesel fuel is not gasoline, is not alcohol, is not KERS, is not kerosene, etc. All top level racing is heavily regulated to suit a myriad of motives and desired results. If you want the racing to be competitive amongst different fuel sources you balance your power source vis-a-vis it's fuel.
    If you don't and you want LeMans to be a diesel race then leave things the way they are.
  17. GTE
    GTE F1 World Champ
    Jun 24, 2004
    10,117
    The Netherlands
    Marnix
    and within the set of rules ACO has set, diesel is obviously the way to go if you want an overall win. It is a simple fact and it is up to the competitors to deal with that fact, by installing a diesel engine or try to somehow make a petrolengine competitive. I really don't see any responsibility on ACO's part to make life easier for the petrol powered cars through modified regulations.
    I really don't care on what fuel the cars are running.Why would I? The only thing is the sound they make, but that is only a small aspect of racing. If ACO deems it important enough though, they'd be better of by banning diesel alltogether.
  18. tomgt
    tomgt F1 Veteran
    7,243
    Netherlands
    Tom Wiggers
    Ban LMP1/900!
    We want GT racing back in its purest form.
    "showroom cars" with some mods.
    Who wants to see Audi winning LM again?!! (and they will win!)
    I rather like to see R8 GT2 race against Gallardo GT2, 458GTs etc etc @ La Sarthe
  19. GTE
    GTE F1 World Champ
    Jun 24, 2004
    10,117
    The Netherlands
    Marnix
    Why not one of the Peugeots?
  20. GTE
    GTE F1 World Champ
    Jun 24, 2004
    10,117
    The Netherlands
    Marnix
    BTW, I have no problem with Le Mans Prototypes. Not at all. They were always a part of Le Mans, seperated from the GT class. Without them, we would never even have the 330P cars or 512S/M cars.
  21. GTE
    GTE F1 World Champ
    Jun 24, 2004
    10,117
    The Netherlands
    Marnix
    That is more or less exactly what you get to see. The GT battles have been awesome in most recent editions of Le Mans. It is still there. Who cares if they are not in it for the overall win. It is up to you to decide which category gets most of your attention.
  22. tomgt
    tomgt F1 Veteran
    7,243
    Netherlands
    Tom Wiggers
    I do care. ACO thinks they do it right for motor racing lovers.
    I know a lot of Germans, English and Dutch that go to LM for 20+ years, a tradition, BUT they all say the same: WE WANT TO SEE GT RACING not factory prototypes Audi and Peugeot.
    Millions of budgets. You wont see Porsche back for overall victory or Ferrari.
    Bentley was an Audi/VW is disguise.
    I fully agree with "ACO got it wrong AGAIN"
    They also f$%^ked GT1, did not allow MC12 for stupid reasons.
    Typically French though, see Monte Carlo rally stories in 60s: Mini Cooper 1 2 and 3!!!
    No Citroen should win: so 4th car won....
  23. william
    Jun 3, 2006
    28,054
    I must say that I have hardly read a more ignorant post than this one.
    Maybe the author should have read the ACO rulebook before making a fool of himself by claiming that Diesels aren't favoured at Le Mans !
    Up to 2002, the capacity for engines in LMP1 was 6000cc for atmos or 4000cc for supercharged/turbo engines.
    In 2004, the 1st year the Diesel were introduced, the capacitiy limits became
    6000cc for atmo petrol
    4000cc for turbo petrol
    5500cc for turbo Diesel (already a 1500cc advantage).
    In 2011, the rules are this
    3400cc for atmo petrol
    2000cc for turbo petrol
    3700cc for turbo Diesel (now a 1700cc advantage!)
    Diesels are not superior or better for the job: the equivalancy rules are WRONG !!
    The ACO that favoured Diesel engines from the begining, has now increased their advantage!
    Just like organising a boxing match between a welter-weight and a heavy-weight and calling it a fair fight!!
    Audi and Peugeot have chosen Diesels because it suits their marketing and because the ACO give them an unfair advantage.
    I am far from being the only one making that complain: journalists, team managers, constructors, drivers and anyone interested in endurance racing can see there is gross manupulation of the equivalancy rules by the ACO to pander to the wish of Diesels entrants.
  24. mclarenferrari
    mclarenferrari Karting
    Jul 13, 2010
    178
    +1. One could construct any set of rules that would radically promote a certain type of vehicle; I could construct a set that would massively tip the hand to steam-powered vehicles, but that doesn't make them cutting edge racers.
    The whole thing really has become a farce. If I do watch Le Mans, I'm going to be following GT racing only. I couldn't give a damn about soulless diesel prototypes quietly moving around the track.
  25. tomgt
    tomgt F1 Veteran
    7,243
    Netherlands
    Tom Wiggers
    #50 tomgt, May 5, 2011
    fully agree!
    One should not forget VW/AUDI is a VERY BIG sponsor for ACO.....
    If an other BIG (or two) make a deal for several years with ACO.........what would happen with the rules? Toyota with a full hybrid or even full electric and they pay a lot of sponsoring money to ACO..........
