355 - the cabin blower turns on by itself at maximum speed when engine is running | FerrariChat
355 the cabin blower turns on by itself at maximum speed when engine is running
Discussion in '348/355' started by evo11, Apr 30, 2023.
  1. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    Hi Guys,
    I had the great pleasure of driving my wonderful f355 today.
    To my surprise, after starting the engine, the cabin fan turned on at stayed at highest speed. Nothing changes when adjusting the potentiometer. I stopped, turned off the engine and after a while I started again and the cabin airflow turned off and I could operate it normally by adjusting the potentiometer. Unfortunately when I was returning home it turned on again at the highest speed and did not respond to the potentiometer adjustment. Please help, where should I start?
    K
  2. lanab
    lanab Formula Junior
    Feb 21, 2016
    510
    Stockholm, Sweden
    I had the same problem and it's most probably the power transistor part 63307200
  3. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    Thanks. Where it is located in the car?
  4. lanab
    Feb 21, 2016
    510
    Stockholm, Sweden
  5. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    thank you for the information. Where can I get to this? Need to remove the dashboard?
  6. lanab
    Feb 21, 2016
    510
    Stockholm, Sweden
    From the left side in the luggage compartment, pretty much self explanatory in the pic above.
  7. Qavion
    Qavion F1 World Champ
    14,259
    Ian Riddell
    You need to remove the forward luggage compartment liner. It's in the frunk.
    Also known as the fan speed regulator, power unit, hedgehog (on 360/430), etc...
    No longer available or vary rare. If you look a parts websites, they indicate this by quoting ridiculous prices e.g. $3,153.49 at Eurospares. Best bet is to repair it.
    https://www.ferrarichat.com/forum/posts/148363788/
  8. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
  9. lanab
    Feb 21, 2016
    510
    Stockholm, Sweden
  10. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
  11. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    I have no idea how to pull it out. I tried to pull using pliers for the contacts but unfortunately it does not move...
  12. lanab
    Feb 21, 2016
    510
    Stockholm, Sweden
    Pull what out? it's already pulled out above right?
  13. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    It's need to be removed for fixing?
  14. lanab
    Feb 21, 2016
    510
    Stockholm, Sweden
    Just test it first, otherwise buy a new one, they are hard to find though...
  15. Qavion
    14,259
    Ian Riddell
  16. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    So there's a chance it's working fine and that's not the cause of the problem??
  17. Qavion
    14,259
    Ian Riddell
    The HVAC ECU is sending a control signal, so it's possible that that is faulty. @m.stojanovic has some tips on faultfinding.
    One of the repair shops, technozen-electronics.co.uk, has this warning:
  18. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    756
    Vermont
    john truskowski
    That's a nice watch and lexus brochure! :) I would definitely bench test that before ripping it apart. If it fails, then repairing it may be the only solution.
  19. lanab
    Feb 21, 2016
    510
    Stockholm, Sweden
    I have not replaced the motor, might do that when i have repaired everything else in the HVAC system.
    You know where i can find a new motor or OEM part?
  20. Qavion
    14,259
    Ian Riddell
  21. lanab
    Feb 21, 2016
    510
    Stockholm, Sweden
    Thanks, seems like the whole evaporator unit needs to be removed....
  22. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    guys, where HVAC ECU is located? I understand that there is a high chance that it is actually damaged?
  23. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    consedering rx500h as time to buy suv finally.
  24. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,312
    Southern New Jersey Shore
    Phil
    Passenger side, under the "frunk" cover, between the shock and firewall. It's in a "box" like unit, not sure if you can make this out but it's the only photo I have:
