The Capristo on my Testarossa sounds same as OEM | FerrariChat
Discussion in 'Boxers/TR/M' started by Dkouseller, Nov 18, 2024.
  1. Dkouseller
    Dkouseller Rookie
    Jun 30, 2019
    16
    Las Vegas, NV
    Daniel Kouretas
    I installed a Stage 3 Capristo exhaust on my ‘87 TR earlier this year.
    When I got it out of the shop. Both the installer and I was surprised that it really didn’t sound much different than my stock exhaust. I still have the cats installed, but shouldn’t I still hear a noticeable difference between Capristo and stock?
    Curious what others have experienced that have installed that same exhaust. I know it’s a popular one.
    Thank you in advance for any input.
  2. ttforcefed
    ttforcefed F1 World Champ
    19,255
    that sounds very off. even at high revs?
  3. Steve Magnusson
    26,779
    If you have both precats and cats still in place (or maybe even precats that have broken up internally and are blocking things up) = yes, it probably will still be pretty muted.
    turbo-joe likes this.
  4. Veedub00
    Veedub00 F1 Veteran
    Jun 30, 2006
    5,068
    Troy, Michigan
    James
    Gotta see if your precats are partially melted.
  5. ferralc
    ferralc Formula 3
    Sep 2, 2010
    2,153
    San Diego CA
    Fernando
    I don’t have cats nor precats and I had an Ansa exhaust before and now a Capristo level 3 and the sound is WAAAY louder than the Ansa (and the Ansa was already louder than stock) so yes most likely you have your precats clogged.
  6. bernieb
    bernieb Karting
    Apr 16, 2007
    215
    Alberta Canada
    Bernard J Bonertz
    You've got the cart before the horse. It will come to life once you get rid of both the cats and pre cats.
  7. Jango
    Jango Rookie
    May 18, 2019
    14
    Rotherham UK
    James beaumont
    I have the electric valved Capristo exhaust, and when fully opened up sound mega and I have cats removed
  8. George Vosburgh
    George Vosburgh F1 Rookie
    Along the same conversation, can someone tell me why the Tubi exhausts have a different design for cat and non cat? If you have a California car with a Tubi exhaust can you pull the cats off and find some kind of pipe to take its place?
  9. Steve Magnusson
    26,779
    #9 Steve Magnusson, Nov 29, 2024
    Because on a TR there are different length headers for the TR that came "without catalytic converter" and those that came "with catalytic converter".. Look at the two exhaust systems in any? TR SPC -- not only are the headers different, virtually everything else is too.
    On the "with catalytic converter TR", there are F bypass pipe available for replacing the precats (and aftermarket versions), but you'd need something aftermarket to replace the cats -- but you'd still buy the Tubi "for cat".
    George Vosburgh likes this.
  10. Dkouseller
    Dkouseller Rookie
    Jun 30, 2019
    16
    Las Vegas, NV
    Daniel Kouretas
    Is there a way my mechanic can check that without removing majority of the exhaust system? One of the mechanics out here in Las Vegas told me he would have to remove the cats in order to see the condition of the precast.
    Would it be best to remove both pre-cats and cats? Or just one set? I would like to bring my V12 engine to life, but not make it obnoxiously loud if that makes sense.
  11. Steve Magnusson
    26,779
    Better to remove the precats so that you can look into the inlet side as well -- however (if you don't need to be strictly legal) they should either be "cleaned out" completely or replaced with precat bypass pipes IMO. (If they are still intact and OK, might be best to get the precat bypass pipes so that a still-intact precat can be sold/preserved.)
    Too loud or not loud enough is subjective, but I preferred an exhaust configuration of bypassed (or cleaned out) preacts + cats + Tubi. In this configuration, the thermocouples need to be moved to the exit side of the cats. Doesn't make sense to me to have intact precats + bypassed cats + Tubi.
  12. MMM
    MMM Rookie
    Jul 7, 2013
    42
    Merritt Island Fl
    My 91 came with a Capristo Exhaust. No way a stock exhaust is that loud. No sneaking out of the Neiborhood in the TR! I have been forbidden to remove it by the wife who loves the gurgle it makes when you de-accelerate.
    66MK likes this.
  13. Steve Magnusson
    26,779
    Do you have intact precats and intact cats? My guess would be "no" ;).
  14. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,525
    romano schwabel
    loud pipes save lives ;)
  15. 66MK
    66MK Karting
    Nov 1, 2020
    201
    Mark
    My UK Testarossa with no cats and a stage 3 Capristo is full on 80's F1 - Ear plugs on a long run - its amazing!! :)
  16. MMM
    MMM Rookie
    Jul 7, 2013
    42
    Merritt Island Fl
    Funny. I don't know. But I am guessing that you are right.
  17. Steve Magnusson
    26,779
    This is always the problem when talking about, or trying to compare, the sound of the various manufacturers silencers/mufflers on TR -- very dependent on what's between the header exits and the silencer/muffler inlets.
  18. ago car nut
    ago car nut F1 Veteran
    5,495
    Madison Ohio
    David A.
    Was reported on this forum that pre-cats are bad for performance?
  19. Steve Magnusson
    26,779
    #19 Steve Magnusson, Dec 1, 2024
    Any extra obstruction in the exhaust flow path is technically bad for performance, but doubtful that anyone could detect it with their butt-dyno, and, if you were operating in a way that you noticed a performance difference = you'd probably be in jail ;). IMO, one significant downside is the location of "hot" precats being sort of under/next to the powerplant. Of course, if the precat catalytic structure has melted, or broken up, that's a bigger problem (and that does happen). The precats were a (desperate?) afterthought to minimize cold-startup emissions more quickly. When the engine is up to operating temperature, the main cats work just fine.
    (Anyone who has ever used a private jet - even one time -- has released far more "pollution" than a TR without precats will release over its whole lifetime vs a TR with precats.)
  20. Dkouseller
    Dkouseller Rookie
    Jun 30, 2019
    16
    Las Vegas, NV
    Daniel Kouretas
    This information is great. I'm having trouble finding a qualified shop here in Las Vegas that is willing to dig in and see if we can clean out/remove the pre-cats. I have a feeling you guys are right and that there is an obstruction or they have melted down.
    Would anybody on here? Have any recommendations for a good shop out here in the Las Vegas area?
