The coolest stocking stuffer around | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Ricambi America, Dec 15, 2008.
  1. Motob
    Motob Formula 3
    Nov 11, 2003
    2,389
    Frederick, Maryland
    Brian Brown
    I have heard that in order to use an SD3 you must subscribe to a software service through Ferrari at a substantial cost. The software that is loaded on the unit has an expiration date, after that date the software will not work and the unit will cease to function. You must update the software through Ferrari in order for it to work again. Is this true or is it a Ferrari tale to keep independents from buying one?
  2. hank sound
    hank sound F1 Veteran
    Jan 31, 2004
    5,953
    Burbank, CA
    Hank Garfield
    #27 hank sound, Dec 16, 2008
    With Big E., no stone will ever be left unturned. Whatever steps or equipment it takes to do the best possible job for his client, will be taken or used. He is quite simply "the Toscanini" of Ferrari service.
  3. LAgated360
    LAgated360 Karting
    175
    LA
    Rick
    SD1, SD2, and SD3 testers on the premises is all fine and dandy.
    ASE A1, M1 (certified cylinder head specialist), M2 (certified block specialist).
    Now THOSE are worth mentioning!
    Eugenio, the MD of Ferrari's.
    Best
    Rick (LAgated360)
  4. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    +1
    LOL!!!! That was funny! But scary as to how it is sort of close to the truth.
  5. ferrari.ace
    ferrari.ace Karting
    May 25, 2006
    232
    So.Cal.
    Adam Cox
    Thanks for the heads up!
    I'm Ferrari factory trained & certified with over 2.5 decades of experience and own Ferrari sistima diagnosi equipment as well...
    I am however always looking for a good machinist.
  6. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Mine shows pcodes.
    What software version do you have Brian? I have 1.026, maybe you need an update?
  7. Rothbauer_Racing
    Rothbauer_Racing Formula Junior
    Jan 11, 2007
    442
    Röthbauer GmbH
    Awesome Device! What about the 99 F355 using OBD2 type connection? What machine would be required to get into it's computer and are these available anywhere? Being a bit old now someone might have one for sale somewhere or a buisness might be closing shop?
    I could use one in my stocking! ;P)
    Ciao,
    Stanislaus
  8. Guy Webster
    Guy Webster Karting
    187
    Pasadena
    Guy Webster
    #33 Guy Webster, Dec 17, 2008
    St05 no match for the SD.
    Let me give you an example. On an SD, you can plot the pressure graph (sine wave) of the F1 pump cycling, IOW, a sine wave hi to low with x and y lines and in real time.
    No way your st05 does that. Am I correct?
    Another one, the sto5 screen is about 1/4 the size of a SD3 screen. Am I correct?
  9. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    #34 brian.s, Dec 17, 2008
    No argument on the restrictions of the ST05, certainly the screen is a difficult read, it is annoying to not be able to switch screens easily, it returns to the opening diagnosis page. It does not do many things that the SD3/2 can, but it does allow a shop to carry out more repairs on the later models which would not be feasible without a scanner.
    When I can justify/afford better, I will get something, my market here is small compared the big cities 250 miles or so away.....
  10. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    Why the hell are these things so expensive?? I mean, this isn't any technically sophisticated product, it's a bunch of microcontrollers that reads values out of a memory in the car, am I right? I can't believe that the protocol they're using for the transmission of the data can't be reverse-engineered....
  11. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    +1 ?? And, it seems the "rumor" is they require a "subscription" to FNA (Italy?) in order to be kept "alive"....
    I'm sure others more knowledgeable than I will jump in, but the "protocol" is, I believe, "open and standard" - The "CAN" bus. However, the first "issue" I encountered is "standard" is a *very* lose term in this case :( [The CAN bus is available @ the OBDII port btw.]
    However, it's not just "reading memory" - Realtime display (and modification) of the "brains" in the car - This sucker is a *lot* more than a "reader".....
    And, have you seen the wiring loom that comes with it!? - M/f'er's do not want to make reverse engineering it "trivial". It could be done, but at what cost?
    My 02c,
    Cheers,
    Ian
  12. Ricambi America
    Sponsor Owner
    #37 Ricambi America, Dec 17, 2008
    Good stuff folks, good stuff.
    CAN Line, proprietary ECU's, limited production, controlled distribution, etc. That is why the SD3 is expensive.
    This is a shop tool that generates revenue by offering faster diagnosis and therefore greater throughput of customer cars. With F430's stamped out like cookies in Italy, there are TONS of these cars now requiring out-of-warranty service. An independent shop that doesn't seriously consider an SD3 or similar tool is most certainly closing the door on a large number of potential customers.
  13. Guy Webster
    Guy Webster Karting
    187
    Pasadena
    Guy Webster
    Brian,
    Get in touch with Daniel for a hook up. :)
    Best :)
  14. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    If it's CAN and not some proprietary encrypted protocol, than it shouldn't be too difficult to get at least the basic (reading) functions, even if it's a loose interpretation of the standard. I myself have spent several nights trying to include a "standard" CAN device in a larger application, it IS a load of work, and figuring out what the data actually does would be much much more work ... but if one of those things costs over 20k, you might as well hire someone to reverse engineer it for the cost of a couple of them - and then build as much as you want, the hardware and assembly cost can hardly be in the 3 figure range!
  15. VTChris
    VTChris F1 World Champ
    Aug 21, 2005
    13,259
    #40 VTChris, Dec 18, 2008
  16. VTChris
    Aug 21, 2005
    13,259
    #41 VTChris, Dec 18, 2008
    Good point
    Certificates are important. And I know M1 and M2 certs are not held by many.
    Congratulations to "E" for obtaining them
    Here's a pic I snagged from "E"'s website, hope he doesn't mine.
    If he gets upset, I'll just blame it on Hank :D :D
    If Hank gets pissed, I'll point the blame to .......ummm.....BigD :D
    BigD wont get pissed, I fix his watches :D
  17. johnb@macarbon
    johnb@macarbon Formula Junior
    Feb 24, 2004
    809
    SF Bay Area
    John Borchelt
    I like the steering wheel on the CS! I've heard 'E' does great work as well - from that CS owner.
  18. Joe G.
    Joe G. Formula 3
    1,109
    Los Angeles
    Joe Gazzani
    #43 Joe G., Dec 18, 2008
    Chris
    if you buy a lowly starter F355 like me, then E can plug in his SD1.....then.....you can graduate to the SD2 later ! :)
  19. ferrari.ace
    ferrari.ace Karting
    May 25, 2006
    232
    So.Cal.
    Adam Cox
    Those ASE certs. are held by many automotive machinists in the industry.
    Ferrari factory certs are held by factory trained Ferrari technicians... does the technician who works on your car have them???
  20. Guy Webster
    Guy Webster Karting
    187
    Pasadena
    Guy Webster
    Wow, didn’t take you long to respond. Must be slow in your shop.
    LMAO! Factory cert’s. You’re joking right? I can’t stop laughing. I heard if you basically stay awake in class you get the factory cert.
    That’s why dealer service is so poor.
    I can’t stop laughing….that was a good one.
  21. ferrari.ace
    ferrari.ace Karting
    May 25, 2006
    232
    So.Cal.
    Adam Cox
    "Wow", ditto on the response...
    The work load in and out of the shop is good, no complaints here.
    Factory certs. are a joke??? You must be referring to ASE certs., or at least I hope so... What you "heard" and what you know are two entirely different things. Poor dealer service is usually the result of poor management. I have worked for several Ferrari dealers, independents, race teams and collecters in the last three decades.
    When you finally stop laughing, do yourself a favor and check to see if your mystery tech. is actually qualified to work on a Ferrari.
    On a side note, don't stop LYAO it's healthy and it keeps a smile on your face.
  22. tazandjan
    39,318
    Daniel- Any hint on how much these things are? ST05s ~$15K, SD2s ~$25K, SD3?
    Taz
    Terry Phillips
  23. Ricambi America
    Sponsor Owner
    Between the SD1 and SD2 number you quoted.
  24. Guy Webster
    Guy Webster Karting
    187
    Pasadena
    Guy Webster
    #49 Guy Webster, Dec 19, 2008
    So all those nuts and bolts left loose, scratches on people’s cars, parts missing, capacities underfilled, items missing out of people’s cars (i.e. tool kits), etc., that was all the managers doing?
    I need some of that Ganja Weed you’re smoking. :)
    In your profile you claim 25 years.
    http://www.ferrarichat.com/forum/member.php?u=34235
    How did you get to 30 years (3 decades) overnight? ( you like to use decades alot, but unfortunately, decades are vague ... decades here, decades there, decades everywhere )
  25. ferrari.ace
    ferrari.ace Karting
    May 25, 2006
    232
    So.Cal.
    Adam Cox
    #50 ferrari.ace, Dec 19, 2008
    Obviously it appears that the work described above was performed by a non qualified technician who most likely doesn't possess Ferrari factory certs.
    Yes the manager is responsible for employing and allowing various individuals to work on, drive, wash, park and deliver your car. this is true regardless of weather he is running a dealership or an independent shop.
    In my profile I claim "over 2.5 decades", that translates to over 25 years.
    I have been a professional mechanic since 1978, The first automotive shop I worked in professionally was in 1981.
    1981 to 2008 = 27 years, that is "over 2.5 decades" or over 25 years.
    I never claimed 30 years???... I claim over 2.5 decades.
    Decades are not vague, they are 10 year blocks of time...
    Looks like you've been smoking way too much of that "Ganja Weed" :{D (I personally don't touch the stuff)
    Guy,
    Just out of curiosity, what model Ferrari or Ferrari's do you currently own? Who is the technician that works on your Ferrari or Ferrari's? What are his or her credentials???
    Also, what is your profession and how long have you been employed at it?
    PS. don't forget to subscribe and support the site...
    Thanks,
    Adam
