The F119 power modification thread | Page 11 | FerrariChat
Discussion in '348/355' started by ernie, Feb 18, 2016.
  1. Delta_Lima
    Delta_Lima Karting
    Aug 30, 2014
    151
    Hoorn, Netherlands
    Daan
    #251 Delta_Lima, Mar 3, 2016
  2. awilson
    awilson Formula Junior
    Sep 15, 2013
    368
    Annapolis Md
    Andrew G. Wilson,II
    I have a 94 Spyder built towards the end of the production run. The Competionizone people are pro's and I'm sure they will do everything I ask. Thanks Andy
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,627
    The Brickyard
    The Bad Guy
    #253 ernie, Mar 3, 2016
    Well that was fast. The StoogeWerkz cat is out of the bag now.
    That is actually my modified intake, and the picture is from this Tuesday when I installed it on Tim's (SoCal1) 348 Challenge.
    Out of curiosity what FB page was that off of?
  4. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
  5. ernie
    Nov 19, 2001
    22,627
    The Brickyard
    The Bad Guy
    #255 ernie, Mar 3, 2016
    I thought we weren't gonna post anything up until all the tuning was finalized?
    Guess you were too excited?
    Oh well, it's not like everyone wasn't gonna see it eventually anyway. I just wanted to wait until the tuning was all squared away. The up side is now you are really gonna have to get the mapping perfected.
    So that rest of you know, I am lending my intake to Tim for a little bit so he can work on the mapping. That intake allows the engine to really breathe, so much so that the stock afr goes WAAAY lean. So it's now Tim's task to get the tuning completed.
  6. awilson
    Sep 15, 2013
    368
    Annapolis Md
    Andrew G. Wilson,II
    You certinally have my attention
  7. vjlax18
    vjlax18 Formula Junior
    687
    Nottingham, MD
    I know that FB pgae :)
  8. ernie
    Nov 19, 2001
    22,627
    The Brickyard
    The Bad Guy
    #258 ernie, Mar 3, 2016
    I started thinking about this plenum modification many years ago after I saw the intake on an Enzo. It has a single open plenum with a throttle body on the left, and a throttle body on the right. The idea was in my head but I never got around to doing it.
    Then I saw Maxwell's 348tt with the single plenum, how well it did, with dyno proven results and that was it. So about 4 years ago I finally said screw it, bought an intake, took it to a fabricator and had it modified. It got shelved because I didn't have the ability to tune in the fuel and timing it needs. Anyway, it's dusted off now and we'll see how Tim does with the tuning.
  9. ernie
    Nov 19, 2001
    22,627
    The Brickyard
    The Bad Guy
    #259 ernie, Mar 3, 2016
    May as well let the 348 Brotherhood see the rest of the pics. No sense keeping you fellas in the dark anymore.
    A side by side compairison of Tim's stock intake on the <- left and my modified StoogeWerkz :D intake on the right ->
  10. ernie
    Nov 19, 2001
    22,627
    The Brickyard
    The Bad Guy
    #260 ernie, Mar 3, 2016
  11. ernie
    Nov 19, 2001
    22,627
    The Brickyard
    The Bad Guy
    #261 ernie, Mar 3, 2016
  12. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,823
    Lake Villa IL
    Do you have inside pics or top secret?
  13. ernie
    Nov 19, 2001
    22,627
    The Brickyard
    The Bad Guy
    #263 ernie, Mar 3, 2016
  14. ernie
    Nov 19, 2001
    22,627
    The Brickyard
    The Bad Guy
    #264 ernie, Mar 3, 2016
  15. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    Just upped the fuel and I cant stand behind the car now
    Blew out my other cat yesterday Ernie LOL
  16. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    STUD !!!!!
  17. ernie
    Nov 19, 2001
    22,627
    The Brickyard
    The Bad Guy
    It's not top secret anymore ;)
    I never said anything about it because I generally don't like making things public until it has been proven to work, and has been successfully running for a while. THEN I will normally share the info.
    This modification is not very radical at all. Well, unless you consider cutting up a stock plenum radical. My whole idea was to increase the breathing capacity of the intake, and thus improve the breathing of the engine with the hopes of it producing a respectable power gain. I cc'd my modified open plenum and it measured approximately 4350 cc's +/-. The displacement of a single cylinder in the f119 is 426cc rounded up. So my modified open plenum displaces more than 10X the air of the displacement of a single cylinder. Plus the engine is now breathing through both throttle bodies.
    If Tim can get the tuning to work, and if it makes the power I'm optimistic it can make, I will probably post a dedicated thread about it. Complete with the guts of the modification.
    So keep your fingers crossed for the StoogeWerkz tuning division, aka SoCal1. LOL!
  18. ernie
    Nov 19, 2001
    22,627
    The Brickyard
    The Bad Guy
    #268 ernie, Mar 3, 2016
    LOL!
    My guess is you should only richen up the open loop, full throttle mapping. And man does it need a whole bunch more fuel.
    Check this out guys. Tim texted me air/fuel graphs from the initial dyno test. The engine was sucking in so much air it was running WICKED lean.
    16:1 @ 2000 rpm
    15:1 @ 3000 rpm
    14.7:1 @ 4000 rpm
    14.5:1 @ 5000 rpm with a slight dip down to 14.1 then right back up
    14.7:1 @ 6000 rpm
    14:1 @ 7000 rpm roughly
    13.7:1 @ 7500 rpm
    Now if that doesn't convince you that the engine is indeed restricted in stock form then I don't know what will.
  19. Markphd
    Markphd Formula Junior
    Mar 10, 2012
    713
    Do you want to borrow those F355 injectors?
  20. ernie
    Nov 19, 2001
    22,627
    The Brickyard
    The Bad Guy
    Thanks for the offer Mark.
    Tim is running the yellow top Bosch injectors. Though I don't know what the flow rate is on them. I'm sure we could figure it out with the Bosch part numbers. Or maybe Plugzit can chime in with the specs.
  21. Markphd
    Mar 10, 2012
    713
    The F355's are 270cc/min IIRC
    Sent from my SM-G920P using Tapatalk
  22. vjlax18
    687
    Nottingham, MD
    Yellow tops are usually the 19.5lbs ones I thought. Is that enough fuel? And if that's enough, you can get those all day long from the BMW M50 engines for pennies. If that's not enough, then the pink top were on the M52 engines, and you can get those for nickels.
  23. ernie
    Nov 19, 2001
    22,627
    The Brickyard
    The Bad Guy
    Was ohm resistance are they? They need to be at least 15.8 resistance.
  24. Markphd
    Mar 10, 2012
    713
    No worries, they are high impedance.
  25. ernie
    Nov 19, 2001
    22,627
    The Brickyard
    The Bad Guy
    I see.
    Well let's hope they have enough duty cycle to get the job done. For all we know they could already be tapped out?
