The F119 power modification thread | Page 16 | FerrariChat
Discussion in '348/355' started by ernie, Feb 18, 2016.
  1. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    SoCal LA/OC/New Mexico
    Tim Dee
    Some baseline pulls
    Time to play
    [ame]http://www.youtube.com/watch?v=iLULpXExxQM[/ame]
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    #377 ernie, Mar 17, 2016
    Nice.
    Was that just the camera microphone or was it missing?
  3. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,857
    Lake Villa IL
    Looks like fun :D
  4. Christof
    Christof Karting
    Jun 29, 2014
    185
    Australia
    Yep that was what I was thinking. Coils with inbuilt ignitor. Then wiring this up with factory ECU
  5. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    Tim Dee
    5 year old cell phone mic sucks, car was screaming loud did not miss a beat
    Always is heheheh :)
  6. awilson
    awilson Formula Junior
    Sep 15, 2013
    368
    Annapolis Md
    Andrew G. Wilson,II
    My upgrades are almost finished. Ported Tb's, Ported intake runners, ported plenum, new injectors, no screens in MAF's, straightened intake hoses, twin air boxes, headers, no cats, magnaflow custom exhaust. Will this car run with stock chips ?
  7. vjlax18
    vjlax18 Formula Junior
    687
    Nottingham, MD
    What Magnaflow muffler did you use?
  8. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    Tim Dee
    Sure no issue at all
  9. John_K_348
    John_K_348 F1 Rookie
    Sep 20, 2013
    2,757
    Boston, MA
    John E. Kenney
    Try it and see. Low rpm and cold start may be a problem. May run lean as you go up but bigger injectors may counter that. No real clue just 'guesstrapolating" ;) It would be better with OBD2 telemetry. Hopefully O2 sensors will measure and adjust mixture properly.
  10. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    Tim Dee
    The 02's on these cars really leave a lot to be desired
    Mine runs nice and rich when I unplug them. When plugged in they really dial the AFR back to 1.0 that equals 14.7 to 1. Working on another solution besides tuning the MAF
  11. John_K_348
    Sep 20, 2013
    2,757
    Boston, MA
    John E. Kenney
    Hmmm good info.
  12. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Simple fix is to relocated them out of the exhaust stream. Seems illogical, but they will read less accurately, which is what you are looking for (you want them to richen up it sounds) plus they will offer less exhaust restriction. Goth does this on his cats.
  13. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    Tim Dee
    In a nutshell yes
    A lot of guys I been playing with run strictly off the tables and not the 02's
    Lambda value is 1.00 for a 14.7 AFR. I want to be at 12.5 to 1 so my lambda would value would need to be 0.85, 12.5 divided by 14.7 is 0.85 or there aboutski.
    12.5 afr most likey will eat these old 02's alive so for that reason I may be running without them strictly from the tables, not to mention how it will make the cats glow red. Then adjust fuel afr with injector size and use the tables to set fuel and advance curves.
    The hunt is to find all the spots in the ECU that checks lambda. We found several so far and still more hiding. Once we find those it's a hard core party or we blow up the ECUs hehehe
    I am really have a fun time playing with it :)
  14. awilson
    Sep 15, 2013
    368
    Annapolis Md
    Andrew G. Wilson,II
    I wish I could remember. I had it done in Glen Burnie at a Trick Truck place where the owner owned a Ferrari. Look in the threads for muffler and you will find him. Good guy and not thet expensice.
  15. ernie
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    Yes it will.
  16. ernie
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    I'm hoping you aren't tuning to run at 12.5 all the time, at all throttle positions???
  17. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    Tim Dee
    Yep 12.5 to 1 at idle rules hehehehe :)
    Just showing an example how this ecu works, I never tell my real numbers. :)
    I think the 358 was running about 8 to 1 that one day at the track when it was getting 3 laps per tankfull , that was cool :)
  18. Markphd
    Markphd Formula Junior
    Mar 10, 2012
    713
    #393 Markphd, Mar 26, 2016
    8:1 is perfectly fine for an AF ratio.... As long as you are running E85.
    Fuel A/F Lambda
    Pure Gasoline Stoichiometric 14.7 1.000
    Pure Gasoline Max Power Rich 12.5 0.8503
    Pure Gasoline Max Power Lean 13.23 0.900
    E10 Stoichiometric 14.08 1.000
    E10 Max Power Rich 12.0 0.8523
    E10 Max Power Lean 12.7008 0.9020
    E15 Stoichiometric 13.79 1.000
    E15 Max Power Rich 11.75 0.8521
    E15 Max Power Lean 12.4362 0.9018
    E85 Stoichiometric 9.765 1.000
    E85 Max Power Rich 6.975 0.7143
    E85 Max Power Lean 8.469 0.8673
    Ethanol Stoichiometric 9.0078 1.000
    Ethanol Max Power Rich 6.429 0.7137
    Ethanol Max Power Lean 7.8 0.8659
    Methanol Stoichiometric 6.45 1.000
    Methanol Max Power Rich 4.0 0.620
    Propane Stoichiometric 15.7 1.000
    Propane Max Power Rich 13.18 0.8395
    ernie likes this.
  19. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    Tim Dee
    With race fuel it pours out black smoke at idle stronger then a hit of crack LOL
  20. fatbillybob
    Aug 10, 2002
    29,465
    socal
    Is there a reason people don't run an electrically switched cat bypass? Racers used to open up an exhaust that way for drag racing. Then you could run a clean map and fast map. You really want to run clean 99% of the time. At 12.5 AFR there is so much unburnt fuel your eyes sting and clothes stink by the time you get out of the car.
  21. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    Tim Dee
    Yes sure can butt in the end they would still glow red and start fires.
    Remember in 1975 or 76 when cats were phased in, they were setting fires whenever they parked if the carb was running rich. And the lovely rotten egg small
    Cats tend not to live at anything below 14-1. New standards are saying 15.5 to 1. It sure is changing in the frindge
  22. fatbillybob
    Aug 10, 2002
    29,465
    socal
    #397 fatbillybob, Mar 27, 2016
    Nope I'm talking bypass the cats with more plumbing so the cats don't see any exhaust when running under 14/1 and both ECU maps
  23. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    Tim Dee
    Yes I remember those LOL
    You could but lots of work and extra plumbing then you need a stand alone ecu.
    I rather just pull off the cats if I go to the track, less filling taste great
  24. c7matt
    c7matt Formula Junior
    Mar 3, 2016
    338
    Greater Detroit, MI
    To protect cat's auto makers enrich to keep the brick cool. Excess fuel and excess oxygen (say a dead cyl) will raise cat temp (quickly!) but just running rich does not raise the cat temp, it cools it.
  25. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,857
    Lake Villa IL
    Sized correctly cats aren't taking much if any power. (And there's no benefit to constantly run richer than stoich if its not under load)
