The F119 power modification thread | Page 5 | FerrariChat
Discussion in '348/355' started by ernie, Feb 18, 2016.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    #101 ernie, Feb 21, 2016
    And it has already been done.
    Need I remind you of this thread? Complete with dyno sheets. http://www.ferrarichat.com/forum/348-355-sponsored-bradan/511097-naturally-aspirated-400-hp-348-yes-real.html If all Steve's car is making is 400hp ÷ 3.4L = 117.64hp/lt.
    BOOOOM!!!
    Uh oooops whahappun????
    :D:p
    LOL
    p.s.
    In it's current state of modifications my F119 is making between 97.64hp/lt - 109hp/lt. Of course, depending on what the true drivetrain losses are.
  2. ernie
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    Be careful Sy. You are in danger of eclipsing the 117hp/lt mark with that kinda talk. We "don't" wanna out engineer the engineers now do we? Of course we do........AGAIN. ;)
    Hahahahaha!
  3. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    SoCal LA/OC/New Mexico
    Tim Dee
    Yes totally agree. Engine subframe out of car, apply power and run it on the bench
    The only way to go.
  4. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Of course I have seen that thread. I did not say that it could not be done-- in fact I'm quite confident that it can be done, and in a different and more effective way than was shown in that thread (I'm in no way diminishing the beautiful work shown in that thread, but if 400 hp is your goal there are better ways to get there than an intake $ystem that will support 700 hp). I simply said that you'd have to out-do the engineers who designed the Stradale engine, which gets more than a little easier once you're no longer concerned with meeting emissions standards or lasting through a warranty period.
  5. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Don't we all? :) I think ~400 hp would be just about perfect for our cars, although on the track there's never enough.
    Ever read Mark Donohue's book, "The Unfair Advantage"? He told a great story about the development of one of the early Porsche Can Am cars (I forget the number since I'm not a Porsche guy). The Porsche engineers held true to their typical efficient German reputations, addressing all of the flaws Donohue found every time he was requested to fly to Germany and test the car. After a few test cycles the Porsche guys noticed that every time Donohue made a list of things the car needed, "more power" was always on it, so they finally asked him how much power would be sufficient for him. His answer was something to the effect of, "When I can spin the tires at the end of the longest straight on any track we race, that will be enough power." Sounds right to me. :)
  6. Markphd
    Markphd Formula Junior
    Mar 10, 2012
    713
    Want to pick up an easy 10-15 HP, go to an electric waterpump. We all know that the waterpump is way over spinning at high rpm and doing nothing but wasting energy creating excess pressure and that doesn't tremendously benefit flow and cooling which is restricted by the thermostat.
    Sent from my SM-G920P using Tapatalk
  7. ernie
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    On the F129 you could getaway with it, because the pump runs off the crank pulley, but not feasible on the f119 because the timing belt runs the pump.
    Having said that, a scroll impeller in the pump will help reduce cavitation and drag,
  8. driveitdaily
    driveitdaily Formula 3
    Jul 20, 2013
    1,041
    lake ariel pennsylva
    john
    Easy , want 400 to 500 hp , just buy a 911
  9. FLORIDAsnakeEyes
    FLORIDAsnakeEyes Formula 3
    Jul 7, 2015
    1,154
    Sarasota, Florida
    OC
    LMAO....never.
  10. fatbillybob
    Aug 10, 2002
    29,478
    socal
    Agreed! IMO it is all in the ECU. That has to be solved in order to get real results from modifying. If what Mark says is right then you could do stealth mods and still pass smog.
  11. fatbillybob
    Aug 10, 2002
    29,478
    socal
    You can convert to 2 belts sans pump. Helms has done it a dew times IIRC.
  12. e21jason
    e21jason Karting
    Jul 27, 2015
    70
    Dubai
    Jason
    In the past fitting electric water pumps i have modified the existing water pump to act as idler pulley, or fitted a fabricated blanking plate with an idler pulley and pump outlet.
  13. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    No!!!
    It has to be 401 bhp so we can say it's more powerful than the 360.
    :D
  14. albagtp
    albagtp Karting
    Sep 23, 2014
    57
    Beach City
    Bryan
    Great thread Ernie. Do you have the part number for the 4 hole injectors?
    Thank you Bryan.
  15. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Lots of ideas to respond to this one.
    LdM comes on the scene and wants to make his V-8 mark. He cans the 348 for emotional reasons (he lost a drag race with a VW, allegedly). Ferrari wants to be at the cutting edge of the street performance envelope. Unfortunately, the factory dropped the ball with the 348, not taking full advantage of modern technologies to enhance the car further during its 7-year run.
    So, he needs a 6-speed trans because everyone in a Porsche has one in 1995, or will shortly. He needs an adjustable suspension system because, heck even those backward US cousins have it in the Corvettes. Worse, he has the US OBD II rules and tighter smog regulations to meet. What he needs is variable cam adjustment, but Ferrari is behind that curve, or, worse, doesn't see the necessity of it yet.
    The F355 engine is Ferrari's attempt to meet what are current performance enhancements that are being installed in competitor's performance cars. Throttle bodies - BMW M models have them. The way Ferrari chooses to produce variable cam timing is to provide emulation until the release of the 360. The 3rd intake valve is used to simulate more aggressive cam timing at higher revs. Adding an exhaust bypass is another innovation with this in mind. Now the engine can be tuned conservatively for lower, smog testing rpms, and radicalized for WOT performance against the new wave of competition. Think of this in the same vein as current cars using turbos. The end game is the same - provide regulatory benefits and increased performance in a "have your cake and eat it too" philosophy.
    Now here's the rub, or maybe heresy for the 348 brethren: The F355 engine has a crap load more performance potential than a 348 engine, if only because it has many more variables to tinker with. Unfortunately, it is a more complicated and finicky mill and is subject to greater regulatory oversight if you want to stay legal.
    So that, in a nut shell, FBB, is why we see a "mere" 68 HP difference between a 1995 348 Spider and F355 (312 v. 380). Had the factory adopted an all-or-nothing, winner-take-all mindset as it appears now, I am sure we would have seen much higher performance numbers. In fact, I am sure they could have achieved F355 levels without a new engine design. Considering they were probably looking at the 360 as the next V-8 project, however, it was inevitable.
    One also cannot omit consideration of the financial environment. Early 1990's was not good for high-end consumables. Also, the performance comparison between normal cars and Ferraris was still huge, so there was no incentive to push the performance envelope. The public was satisfied with things as they were, hence no business case supported spending the R&D to further enhance the 348 engine. Interestingly, the TR line had a much different experience. 1992 saw the 512TR which was a huge improvement over the TR, almost making it a different car. Then the 1994 F512M version which is another evolution. Makes you wonder what the 348 would have become with the same experience.
  16. driveitdaily
    Jul 20, 2013
    1,041
    john
    " Makes you wonder what the 348 would have become with the same experience. "
    Ummm , it became the 355.
  17. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    Tim Dee
    #117 SoCal1, Feb 22, 2016
    Kiddies
    The new chips are here, the new chips are here and they are chocolate chip LOL
    I have 100 to burn through of the higher speed ones
  18. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Exactly. Same block, just a natural evolution, as the 348 engine was from the 328 engine. As I illustrated in a post above, the efficiency of F119 was actually quite impressive for its day. Keep in mind that this was Maranello's first attempt at using Motronic on a production car and most of the engine wizardry we have today was unheard of at the time.
  19. ernie
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    I have the OSideTiger part number: D04.14.1.8
  20. ernie
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    The deck height of the F119 is taller than the F105.
  21. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,610
    Menlo Park, CA
    Paul Chua
    Hi Folks,
    I know this is a little off topic, but I know the F119D and F119G are basically the same engine except the F119G is the one with catalytic converters here in the US... Besides having the catalytic converter, is there any other difference in the engines to anybody's knowledge?
    My car recently turned 25, which means it qualifies for "Historical Vehicle" status here in California, which also means (depending on who you talk to) I should be exempt from Smog, which makes me want to take out the cats (yeah stinky, but I hear it sounds better and an extra 5HP ain't bad)
    Would love to hear anybody's thoughts on this?
    Cheers
  22. awilson
    awilson Formula Junior
    Sep 15, 2013
    368
    Annapolis Md
    Andrew G. Wilson,II
    I plan to return to Md. in two weeks and will start my 348 project then. I'll send you my old chips for maping as you requested. I am rubbing my tummy and patting my head in hopes of becomming a test bed for the new chips. I am giong to to do the before and after dyno's so it would be a great oppurtunity to check with real data. Andy
  23. vjlax18
    vjlax18 Formula Junior
    687
    Nottingham, MD
    Where are you getting your car dyno'd in MD?
  24. ernie
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    #124 ernie, Feb 22, 2016
    Heretic! :p
    Let's investigate this to see what is what.
    The 355 has a "special trick head". The F129 comes with three 26.5mm intake valves, and fancy cams with staggered lobe openings vs the 348's two 30.5mm intake valves. So how much better does the 355 head flow with the extra valve? I did some searching and came across flow numbers for the F129 from Sabre Heads in the UK. I think Sabre measures the flow at 10" of water. I will convert the flow numbers to 28" of water by multiply them x 1.67332. Here's the intake cfm data by inches of lift:
    lift / cfm@10" / cfm@28"
    .100 / 52.1 / 87.17
    .200 / 97.94 / 163.88
    .300 / 121.92 / 204.01
    .350 / 127.45 / 213.26
    .400/ 130.91 / 219.05
    Let's now compare the F119 flow numbers versus the F129 flow numbers @ 28".
    lift / f119 / f129 = delta
    .100 / 87 / 87 = same
    .200 / 159 / 163 = +4cfm f129
    .300 / 194 / 204 = +10cfm f129
    .350 / 208 / 213 = +5cfm f129
    .400 / 212 / 219 = +7cfm f129
    Very interesting. The extra valve, all that fancy-scmancy valve opening, and trick cams only yields an extra +4cfm to +10cfm. How much more is that extra cfm good for in power?
    LET'S SEE!
    Again the math is (flows x cfm x number of cylinders = hp potential)
    lift / f119 hp / f129 hp = delta
    .100 / 180 / 180 = same
    .200 / 330 / 339 = +9hp f129
    .300 / 403 / 424 = +11hp f129
    .350 / 432 / 443 = +11hp f129
    .400 / 440 / 455 = +15hp f129
    If the stock 348 head is capable of producing power in within 9-15hp of the stock 355 head, at the same lift, why does the f119 make so much less power that the f129? Hmmmm???? I think it may in fact have been plugged up and restricted on purpose!
    I looks as though a f119 with bigger intake valves could flow just as well as the 3 valve F355 head.
    How about we see what a f119 ported head + bigger valves vs f129 ported head + bigger valves does in cfm? Good thing for us we have flow numbers for both heads with the improvements. Though for the f119 I only have flow numbers up to .360 (the stock cam lift is only 362). I will also convert the f129 cfm to 28". Anyway here are the numbers:
    .100 / 97 / 95 = +2cfm win f119
    .200 / 175 / 178 = +3cfm win f129
    .300 / 228 / 218 = +10cfm win f119
    .350 / 238 / 228 = +10cfm win f119
    .360 / 241 / ---- = no contest
    .400/ ---- / 232 = no contest
    So even at a lower lift the f119 head out flowed the f129 in all but one area. Based on this the f119 with bigger valves (34mm) takes the win, and on the stock intake cam.
    How about the estimated power potential of both modified heads at the max lift cfm numbers?
    f119 / f129 = delta
    501hp / 483hp = +18hp WIN F119 (and on a lower valve lift)
    The 348 is SERIOUSLY under powered. Contrary to common opinion, it looks like the only reason the F129 makes more power is because the F119 is fighting with one hand tide behind it's back. The 348 CANNOT breath!
    I am convinced the power of the 348 was deliberately held back from the get go.
  25. vjlax18
    687
    Nottingham, MD
    It seems like you're well on your way to proving it and the rest of us will benefit from your work. That is if you share your secret sauce once developed.
