THE F70 (LaFerrari) Thread | Page 102 | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Greg23, Jun 6, 2012.
  1. subirg
    subirg F1 Rookie
    Dec 19, 2003
    4,369
    Cheshire
    Fear not - we are all just speculating and voicing our concerns. Once real info emerges you can be sure this thread will be laser focused back on topic. Oh the wait...
  2. arakisfilip
    arakisfilip Formula Junior
    Jan 25, 2004
    295
    #2527 arakisfilip, Oct 4, 2012
    Someone mentioned here that the 24h le mans was won by a 4WD audi, indication that's a reason for it....
    under ACO LMP1 regulations, the front wheel drive can only be engaged after 120KMH...also the audi won because it was more reliable then the toyota, not because it has a better drive/hybrid sytem...
    Many of the people "in the know" are now convinced Toyota has a superior hybrid system with it's Super Capacitors....
  3. arakisfilip
    Jan 25, 2004
    295
    Ultra is RWD car, not a really good comparison since Etrons are hybrids and Ultras are not...
    More realistic comparison would be Toyota vs Audi....during the course of the few rounds after Le Mans Toyota has asserted itself as the faster car. Keep in mind Le mans was the first race for the Toyota, and it was able to take the lead from Audi before it was hit by the falic mobile...
    Also the E-tron is not a 4WD but a hybrid with electric motors up front. no driveshaft/transmiton/differential... and it is prohibited from engaging the front wheel drive below 120 KPH, negating any benefit from 4W drive..
  4. Igor Ound
    Igor Ound F1 Veteran
    Sep 30, 2012
    8,102
    The Horn
    Igor Ound
    What I meant is that Awd Audi beat sisters Rwd Audi, after the company rightfully chose to take that direction with the new cars.
    No mentions about Toyota as they had a completely different car, even if they too had considered awd prior to the speed restriction.
    That same speed restriction on front wheel activation had been pushed by rwd Peugeot and guess why?
    Because otherwise the 4wd would have been too fast.
    Clear enough?
  5. Igor Ound
    Sep 30, 2012
    8,102
    The Horn
    Igor Ound
    That's the 4wd system I argue would be best on the f70.
    That's the future.
  6. Traveller
    Traveller F1 Veteran
    Apr 10, 2009
    6,323
    Tim
    I suspect the final decision as to what works best will be taken by the small development abilities at Ferrari! If it makes it faster and better, they will use it, if not they will not-simple.
  7. arakisfilip
    Jan 25, 2004
    295
    With this I can agree.
    But comparing Ultras to E-torns makes no sence since E-trons have 200hp more...thus not the same car, not even close...
    I know Toyota vs Etron is also not a realistic comparison, but it's the only one we have with 2 hybrid racecars one front one back...And toyota is ahead in both technology Supercap vs flywheel, and system, they mentioned that their system right now is capable of the 2014 regs, which require 16 times more capacity... They also have 300hp Kers as compared to Audi's 200HP
    Personaly I don't care one way or the other, I find that Hybrids/kers right now are just a publicity stunt, and part of a hype...In 5-10 years they'll be developed enough to be top of their game...But this is the direction we are going, and the best way to advance it faster is to race it, and build super/hyper cars with it...
    I am 1000% sure the new enzo with no 200kg hybrid system would be a lot faster then the one with it....or at least just as fast..
    imagine a 1100kg carbon fiber super car with 800+hp...
  8. Traveller
    Apr 10, 2009
    6,323
    Tim
    And yet they have specifically said that they will not build it with KERS unless it does provide a performance enhancement.
  9. arakisfilip
    Jan 25, 2004
    295
    I don't put too much trust in what PR people say...
  10. Traveller
    Apr 10, 2009
    6,323
    Tim
    I think you will therefore be disappointed!
  11. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,892
    Richmond
    Pete
    1300kg with 1000hp vs 1100kg with 800hp. Power to weight ratio is higher with the 1300kg and 1000hp, simple math. It will be faster in a straight line with the KERS system, no way around it. However, if we're talking about lap times it will probably be very close as acceleration advantages will be slightly offset by slower reflexes, but the extra 30% in fuel consumption and emissions reduction will still make it worth it given same/similar lap times.
  12. furmano
    furmano Three Time F1 World Champ
    Jul 22, 2004
    32,215
    Colorado
    Furman
    I'm curious, why do you think more (most) sports cars aren't designed with AWD?
    -F
  13. ARTNNYC
    ARTNNYC F1 Rookie
    3,795
    Bonita Springs, FL
    Jerome
    Because its expensive, complex and has weight disadvantages. Small article in the new issue of EVO magazine says that a lot of US owners of Lamborghini's are converting them to RWD only
  14. Drive550PFB
    Drive550PFB Two Time F1 World Champ
    Do you realize that the PR people work for the company and it is their job to provide accurate information. If they were not accurate, they would not be in business very long.
  15. arhimede
    arhimede Formula Junior
    Aug 16, 2007
    768
  16. furmano
    Jul 22, 2004
    32,215
    Colorado
    Furman
    Thanks, and I agree, and also would add driving feel to the list. But I am hoping IO will answer the question. I genuinely curious what his thoughts are on this.
    -F
  17. CMY
    CMY F1 World Champ
    Oct 15, 2004
    10,142
    Redondo Beach, CA
    Chris
    #2542 CMY, Oct 4, 2012
  18. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,415
    Bournemouth, UK
    As I said previously, 4WD was tested in F1 and failed miserably! They were good only in the rain.
    PS: Do you really think you know better than Ferrari and are in a position to make recommendations on how to make the F70? The fact that it will be RWD, will make you look foolish.
  19. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,415
    Bournemouth, UK
    #2544 REALZEUS, Oct 4, 2012
    I can simply say that the hybrid Audi has more power than the non hybrid one, be it 4WD or 2WD, and I would easily win this argument. Not to mention that for marketing purposes, Audi would want its environmentally conscious hybrid in front anyway. Let's wait till Toyota gains some more more experience and the we will see what 2WD can do. ;)
  20. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,415
    Bournemouth, UK
    We agree. 4WD is superior in slippery conditions. 2WD is quicker in good conditions though. Who would care to drive such a car in the rain anyway? Even the slightest accident would cost an arm and a leg, not to mention the fright one would get by trying to tame such a monster in a deluge. ;)
  21. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,415
    Bournemouth, UK
    I am sure that both Ferrari and McLaren will disprove that theory. :D
  22. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,692
    Sarasota
    David
    You can count the number of hyper cars driven in the rain on your left thumb.
  23. Ferrari_Michael
    Ferrari_Michael Formula Junior
    Nov 30, 2006
    614
    That isn't what the door looks like, the top part that forms the roof and window is correct, but the panel of the door has shapes formed into it, not flat as depicted.
  24. arakisfilip
    Jan 25, 2004
    295
    Their only job is to make the company look good, and increase the exposure. The truth, or facts have nothing to do with it..
    They said that there would absolutely not be a scuderia 458 coming ever. Who here still belives that.
  25. CMY
    CMY F1 World Champ
    Oct 15, 2004
    10,142
    Redondo Beach, CA
    Chris
    That's what I assumed, just based on the door-up video I've seen so far. Thanks for confirming it though! ;)
