THE F70 (LaFerrari) Thread | Page 163 | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Greg23, Jun 6, 2012.
  1. Igor Ound
    Igor Ound F1 Veteran
    Sep 30, 2012
    8,102
    The Horn
    Igor Ound
    #4051 Igor Ound, Dec 17, 2012
  2. Traveller
    Traveller F1 Veteran
    Apr 10, 2009
    6,323
    Tim
    Seeing the mule engine again, I think that rules out Autocars central exhaust hypothesis. Is there some reason they might not be included in the diffuser?
  3. 4re4ever
    4re4ever Formula 3
    2,276
    Auckland/London
    Simon
    Its a Mule nor will Ferrari show there final engine layout yet last thing they want is the P1, 918 groups etc seeing to much ...
  4. Skovbo
    Skovbo Formula Junior
    Aug 8, 2012
    296
    Clearly they have no idea about what they are talking about.
  5. Mr reventon
    Mr reventon Rookie
    Jun 14, 2009
    45
    so what happened to the P4/5 comments huh? I guess they showed you to shut you up for a while
  6. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,036
    Huntsville, AL., USA
    Andrew
    There's no need to be rude, tone it down please.
    Regards,
    Andrew.
  7. Mr reventon
    Mr reventon Rookie
    Jun 14, 2009
    45
    Sorry, I was meaning to add a smiley on the end of that, there's no seriousness to my comment, just banter :)
  8. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,036
    Andrew
    My mistake. :)
    All the best,
    Andrew.
  9. AlexGR
    AlexGR Rookie
    Oct 31, 2011
    48
    we shall be waiting then...
  10. Drive550PFB
    Drive550PFB Two Time F1 World Champ
    This Zonda engine compartment is a work of art. Beautiful.
  11. Noblesse Oblige
    Noblesse Oblige F1 Veteran
    Nov 7, 2011
    6,114
    Three Places
    Note that Milanno is having trouble incorporating quad exhausts in an attractive way. Maybe the big center exhaust is the way out. I do buy the warning about keeping heat away from the KERS battery, but that is what engineers do.
  12. lucky_13_2002
    lucky_13_2002 F1 Rookie
    Nov 26, 2006
    3,026
    Colorado
    Michael
    Does anyone have a picture of how the exhaust is routed in the Maserati Birdcage? Its exhaust is stacked in the middle. Maybe it will have a similar solution. I still think the exhaust will exit like on the 430 Scud / 599XX, somewhere between the lights and higher from the ground. And would not be surprised if there are is only one pipe on each side with one valve activated bypass pipe in the middle
  13. Milanno
    Milanno Formula Junior
    Feb 23, 2012
    949
    #4063 Milanno, Dec 17, 2012
  14. Garretto
    Garretto F1 Veteran
    Sep 3, 2003
    5,075
    Bilbao, Spain
    Rodolfo Di Pietro
    Might be just me but in Milanno's great render the actual 3rd/fog light seems now too low, out of place. Maybe Ferrari's design integrates this highlighted element better.
    In any case I'm finding it too low for the width of the car I'm expecting. It will be REAL close to the ground.
  15. lucky_13_2002
    Nov 26, 2006
    3,026
    Colorado
    Michael
    This render is really great, but I think it will end up being quite inaccurate.
    And I agree that if it is a foglight in the center, it is way too low.
  16. Traveller
    Apr 10, 2009
    6,323
    Tim
    Better, but simply not radical enough. Exhaust gases have proven beneficial in F1 so surely Ferrari will use that expertise here. I have posed the question before but any reason why they could not be incorporated into the diffuser?
  17. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    FWIW the rear foglamp in the f12berlinetta is mounted higher, such that the lower edge of the lamp is just about on a horizontal line with the top of the quad exhausts. If it is to be useful as a functioning lamp, one would think that it would be higher than the photo suggests. Maybe Autocar is not crazy and the central "pad" really is the exhaust. But if that is so, then there is no foglamp pad. And it does look too small for the volume of gases that will come out of the big V12.
    So it is a headscratcher.
  18. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Simply because for a road car people like to get off on seeing multiple exhaust pipes. All Ferraris made to this day could have simply had a single pipe ... but they don't purely for visual impact.
    Pete
  19. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,692
    Sarasota
    David
    Race car engines run in a higher, tighter RPM range too. Road cars don't produce the consistent high velocity flow that blown diffusers need.
  20. Milanno
    Feb 23, 2012
    949
    I have impression that people have too big expectations about F70.
  21. quasi C
    quasi C Rookie
    May 20, 2006
    26
    For it to be benficial they would have to map the engine so it would blow exhaust gases even when the throttle isn't applied. This was how it was used in F1 when they were blowing directly into the diffuser. I'm not sure, given the context of a road car, where that would put them in terms of long term engine reliability, fuel consumption and road/overall safety.
  22. DriveAfterDark
    DriveAfterDark F1 Veteran
    Jan 1, 2007
    9,148
    Norway
    The leap from F50 to Enzo was HUGE... Maybe that's the reason?
    I can't wait to see it, hope it's something visually unique like the Enzo was (and still is).
  23. Traveller
    Apr 10, 2009
    6,323
    Tim
    Given the competition, I somehow doubt it.
    I hope.
  24. subirg
    subirg F1 Rookie
    Dec 19, 2003
    4,370
    Cheshire
    If people are going to drop north of $1M, it had better be radical!
  25. TheMayor
    106,228
    Vegas baby
    That and McLaren has thrown down the gauntlet. Whatever they do will be directly compared, even if unfairly.
    From what I've seen so far, they have already beaten the pants off the P11 in the looks department. The fact that it's a V12 over a turbo 8 helps also. Now, it's up to it's performance.
