THE F70 (LaFerrari) Thread | Page 95 | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Greg23, Jun 6, 2012.
  1. DriveAfterDark
    DriveAfterDark F1 Veteran
    Jan 1, 2007
    9,148
    Norway
    I agree re high reving NA engine (love them from 1.6 liters and upwards), but the F40 sounds nice. Lots of supercharged engines sound great too... But yes, NA > FI!
  2. Skovbo
    Skovbo Formula Junior
    Aug 8, 2012
    296
    #2352 Skovbo, Oct 1, 2012
    The engine per se.
  3. arakisfilip
    arakisfilip Formula Junior
    Jan 25, 2004
    295
    okey, where the heck are the back suspension mounts and the dampers..
    Holly crap those are butloads of wires, and hoses :) looks like the new enzo will be a nightmare to service
  4. Skovbo
    Aug 8, 2012
    296
    The picture also gives us an indication of far how the rear will extent and in what shape.
  5. Traveller
    Traveller F1 Veteran
    Apr 10, 2009
    6,323
    Tim
    Very interesting image and I still dont have my magazine! Looks to be like the car might be quite 'wasted' given the Banana sills and rear packaging? But just where are the dampers?
  6. GTE
    GTE F1 World Champ
    Jun 24, 2004
    10,117
    The Netherlands
    Marnix
    and the headroom. Look at the space above Badoer's head!
  7. lucky_13_2002
    lucky_13_2002 F1 Rookie
    Nov 26, 2006
    3,026
    Colorado
    Michael
    Yes indeed. I think this is the result/benefit of making the seats fixed.
    So it looks like the car will be pinched a lot behind the doors. A true coke bottle design?
    Also since there are no dampers to be seen anywhere, is it possible this car could have some sort of pull rod suspension?
  8. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,554
    Bournemouth, UK
    With the dampers being under the gearbox? Hmmm...
    What I thought when I first saw this picture is that this is not an actual car, just an engine installation model. This is why it makes no sense to us. I could be wrong though.
  9. 4re4ever
    4re4ever Formula 3
    2,276
    Auckland/London
    Simon
    It's the back shot of the mule it's not the final car
  10. Traveller
    Apr 10, 2009
    6,323
    Tim
    The exhausts are the give away
  11. Skovbo
    Aug 8, 2012
    296
    Obviously the exhaust pipes will be a lot shorter on the final car.
  12. Traveller
    Apr 10, 2009
    6,323
    Tim
    I think alot more different than that!
  13. Flo400
    Flo400 Formula Junior
    Jun 8, 2011
    358
    Munich, Germany
    Florian
    No space for a moving wing...
  14. 4re4ever
    4re4ever Formula 3
    2,276
    Auckland/London
    Simon
    1.6 turbos which most teams were fighting at the time.. I think its a total joke 1.6 cost saving might as well races minis or something I love F1 but over the last 5 years its lost so much magic
    the f12 is a 6.3 and Ferrari will want a lot more power for the f70 800-900 then about 200 more with KERS I'd say very close or just on a 1000hp with 7.3 V12
    Not only will it be powerful, Ferrari has pushed the fact that the new powertrain will reduce fuel consumption by as much as 30 per cent, and produce around 40 per cent less emissions than an equivalent petrol-only engine with the same power.
  15. 4re4ever
    4re4ever Formula 3
    2,276
    Auckland/London
    Simon
  16. Traveller
    Apr 10, 2009
    6,323
    Tim
  17. 4re4ever
    4re4ever Formula 3
    2,276
    Auckland/London
    Simon
    Maybe f40 style on finally
  18. 4re4ever
    4re4ever Formula 3
    2,276
    Auckland/London
    Simon
    Loads of space for that... but do remember this is a mule not final car
  19. maximilien
    maximilien Formula Junior
    Apr 27, 2005
    900
    Capitale of Europe
    Massimo
    Download the magazine and read the article it is very interesting!
  20. Traveller
    Apr 10, 2009
    6,323
    Tim
    Do you have the link?
  21. maximilien
    Apr 27, 2005
    900
    Capitale of Europe
    Massimo
    Download app in iPad and buy magazine 18
  22. Drive550PFB
    Drive550PFB Two Time F1 World Champ
    I don't use an iPad. Can you print the story here?
  23. Luque
    Luque Formula Junior
    Oct 16, 2009
    485
    Italy
    As far as I know,
    Ferrari patent about pneumatic system for controlling engine valves is not intended to permit highest rpm in performance engine for street use.
    A mechanical spring dimensioned to close valves in a > 9000 rpm engine is a waste of energy in all rpm range. The engine absorbes more power to work in comparison to another one that rev just up to 6000 rpm.
    So Ferrari system will provide :
    1) A mechanical coil spring dimensioned for low rpm (up to 4-5000 rpm) to permit the engine works also with pneumatic system failure.
    2) A pneumatic spring that start working over 5000 rpm
    The system will permit :
    1) Higher valve lift and more ‘fluid dynamics freedom’ to increase air intake and so the power output
    2) A better valves closing speed over 5000 rpm reducing efficiency losses
    Sorry for the ''maccheronic english'' .... :)
    Cheers
    Luque
  24. Traveller
    Apr 10, 2009
    6,323
    Tim
    Just read the Ferrari Magazine article on the F70 and it looks encouraging. Apparently the car will share a wheelbase no bigger than a 458 which suggests it will be very compact and thus true to the MC project, albeit no way will they make the 1000 kg mark. Any ideas how the Enzo wheelbase is to the 458 and does that suggest a much more compact car which I would hope?
  25. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,554
    Bournemouth, UK
    The Enzo and the 458 have exactly the same wheelbase; 2650 mm. ;)
