News
The Holey Daytona
Discussion in 'Vintage (thru 365 GTC4)' started by Wheels1, Jan 27, 2008.
  1. Wheels1
    Wheels1 F1 Rookie
    2,716
    Grant
    Mike has asked me to put the record straight with regard to the windscreen rake of the Spyder and the coupe.
    There is a certain Daytona web-site in the UK that states, that the spyders windscreen, was at a different angle to the coupe.
    This is not true. Mike has confirmed this, and i also checked with Ferrari and they said not, also Ferrari confirmed the windscreens, quarter lights and door glass were all the same so that would make it impossible for there to be a difference.
    I hope that clears it up, as ths is how the wrong information gets put about.
    When i asked the web-site host of the Daytona site about it he told me he had looked at a lot of pictures!!
  2. Wheels1
    Wheels1 F1 Rookie
    2,716
    Grant
    When i said the door glass was the same, i ment the exact size and shape, other than, the angled cut off on the rear of the door glass furthest from the screen [ which is to make the hood fit nicely ]
  3. shill288
    shill288 Formula Junior
    Feb 24, 2005
    899
    West Coast
    Steve Hill
    Well, I own several original Spyders and Coupes. The windshield/screen sure looks the same to me. Since I'm restoring them, I'll have the all the glass pulled and compare them. It will be obvious if they are different or the same.
    I wouldn't trust what Ferrari says without checking up on it yourself. I've already found a couple of things they stated to be on way when, if fact, it was quite another. Having owned at least ten of these cars from the 10th one built to close to the last, Spyders and Coupes, Euro and USA, I've just about seen it all. But, just when you think you've seen everything, you see something like a one bolt steering box on a 1973 build date car that looks original. That's a good year after the changeover (one bolt to three bolt), in theory, happened.
    Steve
  4. Wheels1
    Wheels1 F1 Rookie
    2,716
    Grant
    #129 Wheels1, Oct 3, 2008
  5. Ed Niles
    Ed Niles Formula 3
    Honorary
    Sep 7, 2004
    2,438
    West Hills, CA
    Edwin K. Niles
    This is a fascinating thread---I'm astonished at the effort going into this project, and congratulate you and Grant. I don't think there are too many people who would undertake such a nightmare! Thanks for the thread and for your efforts. I can't get the term "underwater" out of my mind!
  6. Wheels1
    Wheels1 F1 Rookie
    2,716
    Grant
    #131 Wheels1, Oct 12, 2008
  7. Wheels1
    Wheels1 F1 Rookie
    2,716
    Grant
    #132 Wheels1, Oct 15, 2008
  8. Wheels1
    Wheels1 F1 Rookie
    2,716
    Grant
    #133 Wheels1, Oct 23, 2008
  9. Wheels1
    Wheels1 F1 Rookie
    2,716
    Grant
    #134 Wheels1, Oct 25, 2008
  10. Wheels1
    Wheels1 F1 Rookie
    2,716
    Grant
    #135 Wheels1, Oct 30, 2008
  11. Wheels1
    Wheels1 F1 Rookie
    2,716
    Grant
    #136 Wheels1, Nov 11, 2008
    Here's some more of the latest pic's.
    Mike has most of the front repaired and is busy making it in to one complete section before removing it as a complete unit, he will then complete the arches and inner panels before fitting the complete front clip back on the frame for the final time and welding it all together.
  12. Wheels1
    Wheels1 F1 Rookie
    2,716
    Grant
    #137 Wheels1, Dec 5, 2008
    Here's a couple of pic's i took today. Mike has been busy doing parts you cannot see like the boxing to house the fresh air hose, that go's underneath the front wings. The back will soon be coming off, and then it's time for the paint work.
    I spent a few hours with Mike today at his house and he showed me part of his collection of photos of cars he has worked on. I lost count of how many Daytona's, 275, Dinos, etc etc, even later cars like F40's and F50's. There must be over 10-20 million pounds + worth of cars he has put back together.
    any way i am waffling a bit so pic's below.
    Grant
  13. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,267
    Cape Town, South Afr
    Jack Verschuur
    Grant,
    Amazing and beautiful. You're a brave man.
    What is the motivation behind the steel inner front wings? The spyder can probably use every bit of added stiffness it can get, on the other hand there's more metal to be attacked by the little rust creatures.
  14. Daytonafan
    Daytonafan F1 Rookie
    Oct 18, 2003
    2,680
    Surrey, England
    Matthew
    Genuine Spyders have steel inner wings as opposed to the GRP on the Berlinetta's.
  15. Wheels1
    Wheels1 F1 Rookie
    2,716
    Grant
    Thanks for the kind comments Jack.
    As Matt said the original Spyder had steel inner wings for extra strength and mine, and Mikes intension is to make the best and most accurate Daytona conversion there is.
    Mikes philosophy is the job has to be done properly or not at all, which he has proved to me time and time again, as you can see by the detail shown on the work he has done, which is no small feat as there are no drawing showing the difference between the Spyder and the coupe, and i believe there are only 5 Spyders living in the UK at the moment so it is very very very hard to see one to use as a reference.
    My Motivation behind it was, i had always dreamed of owning a Daytona Spyder [ and when i say dreamed that's the truth, i never never thought i could own one] and when this one came up i jumped at the chance. I went in with my eyes wide open and new it needed a lot of work to get it right before i bought it, and the price reflected this to some extent.
    Between the, as you say "rust goblins" and EG Autokraft the car was nearly undriveable [ i did enjoy driving it for a few months though] with so much flex in the body/ chassis, the wheels would hit the inner wings on corners. I could have given it a £5000 tart up as a few Ferrari specialist said, but i new i would never be happy and the rust would not just be eating away at the car but also on my conscious. so i had only had one way to go, at the hard part was finding the right person to do the job. I got lucky [ mainly thanks the F Chat] and found probably the best and most experienced person i the world to do the job and of that i am sure.
    So it may upset some purist with what i am doing, but so far all i have had is positive comments.
  16. IanB
    IanB F1 World Champ
    Jun 15, 2006
    12,292
    Grant,
    you will be amazed by the difference when you get it back on the road. Under advice relayed from Mike, we also "bit the bullet" and changed the A-posts in my car (14397, the blue car in the pics above) to the correct dimensions, plus added some clever gusseting to the sill rails where they join the chassis. The result is a car that is dramatically stiffer and much more pleasant, not to mention safer, to drive.
    In hindsight it was of course a travesty to cut original coupes in the late 70's and early 80's, but neverless these cars exist and finishing the job correctly makes them into a usable and respectful homage to the factory cars. I doubt if market values will ever justify the cost of converting back to a coupe, but that option is always there!
  17. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Returning a spider to a coupe will make an ugly duckling into a swan again ... enough justification IMO ;).
    Pete
  18. IanB
    IanB F1 World Champ
    Jun 15, 2006
    12,292
    #143 IanB, Dec 7, 2008
    And you have owned how many vintage Ferraris? (just to qualify the IMO)
  19. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    #144 PSk, Dec 7, 2008
    None (and very unlikely that I ever will) ... but I still know what I believe looks better.
    Just like a coupe Alfa Romeo GTV looks better than the GTC, again IMO :). But ofcourse everybody is different, but on a Daytona the coupe window line and roof are the most defined shape to the car ...
    Pete
  20. IanB
    IanB F1 World Champ
    Jun 15, 2006
    12,292
    #145 IanB, Dec 8, 2008
    Apropos of nothing, I've been meaning to post this photo for a while. Its from our pre-73 V12 rally back in April. I owned and restored the black 365GT in the late 80's - it was great when it turned up at the rally and I posed this shot of it next to my Daytona. Happily, there were some other interesting cars in the frame!
  21. Wheels1
    Wheels1 F1 Rookie
    2,716
    Grant
    Hi Ian.
    Glad to hear Mike's advise helped. It just go's to show, what a small world the Ferrari one is, with your old car turning up the the same meet, it looks like ther was some great cars there. Your car look great, I wish the weather was the same over here as it was in your photo. The roads are white with frost.
    Happy Christmas
    Grant
  22. Wheels1
    Wheels1 F1 Rookie
    2,716
    Grant
    #147 Wheels1, Jan 13, 2009
  23. Wheels1
    Wheels1 F1 Rookie
    2,716
    Grant
    #148 Wheels1, Jan 28, 2009
  24. omd78
    omd78 F1 World Champ
    12,442
    Breda, Netherlands
    Martin
    Nice thread Grant! Any chance of sharing the pics you refer to?
    Gr. Martin
  25. Wheels1
    Wheels1 F1 Rookie
    2,716
    Grant
    Hi Martin
    They are not mine to share i am afraid, but they are similar to the ones in the book Super Profile, by Nathan Beehl of the cars being made at the factory. [ Great book by the way] The good bit is, we have now been able to confirm that everything Mike has done, is correct by viewing one of the 7 Uk Spyders.
    Grant
