the lvferraripilot engine rebuild thread | Page 11 | FerrariChat
Discussion in '308/328' started by Ferraripilot, Mar 29, 2010.
  1. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,922
    Atlanta
    John!
    question for those who might know: Should I perform a leakdown test prior to the engine firing up the first time, what numbers should I expect considering the rings have not seated at all? Or should I even waste my time performing such a test prior to firing.
  2. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    I always do, before installation. I'd like to see 5% maximum leakage, with zero leakage allowed through the valve train. This might be a good time to pressure test the cooling system, as well...
    David
  3. 350HPMondial
    350HPMondial F1 Veteran
    5,336
    Edwardo
    Yep, I got the Mondial 8 Workshop Manual.
    Follow this as a guide,, but the leakdown pressure Ferrari recommends is too high. Use your shops judgment.
    Looking nice,
    Edwardo
  4. Ferraripilot
    May 10, 2006
    17,922
    Atlanta
    John!
    thank you David. as a side note, the valves were of course vacuum tested prior to installing and they tested well. shooting for 5% now
  5. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,523
    Canada
    Newman
    Unlike gadget-boy's car. :)
  6. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    You are a cruel, cruel man...
    (but don't stop, I laughed for 5 minutes on that one!!)
    Rick
  7. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    You guys are too much.
    I'll come threw, you just wait and see.
  8. jratcliff
    jratcliff Formula 3
    Sep 7, 2004
    1,024
    Texas
    Ohhh, thats not nice at all. Just when I was going to tell you where my 308 was you go and say something like that. Now your going to have to wait. BTW, this is all your fault anyway. :)
  9. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,007
    Cape Town South Afri
    Dave
    #259 duck.co.za, Jun 16, 2010
    John you have certainly got on with it , even with a little hic-cup in the middle , well done . Chris they are just jealous of all the things that you are going to be able to tweek !! and wait till they see the HP .
  10. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    LOL lets see some shots!
  11. Ferraripilot
    May 10, 2006
    17,922
    Atlanta
    John!
    Back from a horrid trip to Dallas. Ugh, the traffic and the poorly constructed/thought out roads. Almost as bad as Boston.....almost. Don't get me started.
    Anyway, still drilling out that stupid bolt. I am recruiting a friend of mine who is locally well-known as a diesel mechanic who has a knack for unsticking the very stuck.
  12. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    #262 Verell, Jun 17, 2010
    Bolts are hard, get a set of cobalt drill bits, they go thru them like they were mild steel!
    Center punch the broken off bolt and drill a pilot hole at least 3/8" deep, then drill with the drill size closest to the bolt thread's minor diameter. Done right this will leave the bolt's threads in place where they can be easily picked out with an angle pick. Done wrong & you get to drill & tap the hole for a TimSert.
    Be careful as the drill bit gets to the end of the bolt. Go very slow as the bit will tend to grab as it breaks thru the end & you end up with a broken off cobalt drill bit the length of the bolt(been there!). Only thing worse to have broken off is a screw extracter, they're harder than cobalt bits(been there 2).
    Gee, I'm in Dallas today, I was just thinking how much better the roads & traffic are than back in Massachusetts! ;^) Guess it's a matter of perspective!
  13. duck.co.za
    Jan 9, 2007
    1,007
    Dave
    Good advice , I've had to remove to many brocken off easy-outs in my time .
  14. airdelroy
    airdelroy Formula Junior
    May 10, 2007
    420
    Austin, TX
    Aaron Richardson
    Dallas roads/traffic is a lot better than it was even 5 years ago.
    Aaron
  15. Ferraripilot
    May 10, 2006
    17,922
    Atlanta
    John!
    oh yeah Dallas is 10 x better then Boston roads. those old cow trails in beantown make less than zero sense, if that's possible.
    cobalt bits. check. should be done tonight. engine in and fired by father's day
  16. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,256
    Snohomish, WA
    Eric L
    I recently removed a broken engine cover bolt and had this very thing happen. My neighbor loaned me a set of mini carbide-tipped rotary cutting bits. Using these in a Dremel, I was able to slowly grind away the broken bolt around the broken extractor and pick the pieces out of the threads.
  17. Ferraripilot
    May 10, 2006
    17,922
    Atlanta
    John!
    Turned the engine over with the starter for the first time at lunch today. Cylinders are bone dry and the rings were installed dry. Also, the intake valves are closing 11 degrees later then they were before. Getting 165lbs per cylinder over a slow turning engine (guessing either the battery I am using is a bit weak or the engine is a bit tight, or a bit of both). Leak down is about 10%-13% all over. Once the engine is run and oil is circulating I am sure leak down will be better. Pleased with what I have so far though.
  18. Ferraripilot
    May 10, 2006
    17,922
    Atlanta
    John!
    Drilled the bolt out. All went swimmingly well. Will post pics
  19. Ferraripilot
    May 10, 2006
    17,922
    Atlanta
    John!
    #269 Ferraripilot, Jun 19, 2010
    engine in! started at 8:00am. engine dropped in, headers bolted up and a couple other things attached by 11:30am. Not bad at all. Also included is a pic of yours truly basking in the satisfaction.
    below are pics showing the level of the engine which I thought was best for reattaching the 5-8 header. There seems to be a sweet spot right when the center of the alternator is parallel with the gutter at the base of the rear window.
  20. wachuko
    wachuko Rookie
    Dec 24, 2003
    42
    Orlando, FL
    Jaime O. Diaz
    Congrats! Almost there!!
  21. duck.co.za
    Jan 9, 2007
    1,007
    Dave
    Well done John . now lets see it run on Fathers Day !!
  22. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Wow! Great job John!
    With that little bump in the road, you still got it done.
    Congrats man.
  23. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    Woo HOOOO!
    Nice step forward.
    Rick
  24. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    Looks GOOD! Congrats!
    But please tell me that that is not a FRAM oil filter???
  25. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    Yeah, that sounds more than adequate.
    I'm at 135 mains, F24 tubes, 52 idles. Runs like hell, an easy pull to redline in 5th gear (@ 165 mph indicated), and 215 rwhp (257 crank).
    I'm still wondering how everybody seems to need bigger jets than I do, while I seem to have one of the better performing 308's out there....
