the lvferraripilot engine rebuild thread | Page 4 | FerrariChat
Discussion in '308/328' started by Ferraripilot, Mar 29, 2010.
  1. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,880
    The twilight zone
    Well, they need to be 81mm and almost 81mm won't do so they will need to come out and go to the shop to be honed to size.
  2. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,988
    Atlanta
    John!
    check. thanks Mark!
  3. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I was taught by an old guy many years ago to always take three measurements. If any one of the three dont match, you start over and take three more. Cylinders are hard because the bore guage is difficult to get into dead center. Any lateral tilt up or down makes your readings higher, any horizontal swing left or right makes them lower. Then there is the physical accuracy of your mic, and your accuracy measuring the guage. A mic should always bottom at zero, and I usually check them against my proofs before each session. Also, all tools and parts being measured should all be at 70 degrees. Just handling a light piston can rise its temps enough to make slight changes, which is why you see guys in measuring labs wearing gloves. An example might be a cylinder thats maybe 50 degrees, and a mic thats at 80 degrees. Is it enough to make a .001 inch change? More? Less? Now add in human error's.
    Obviously you cant have a cylinder smaller than the piston, and all that measuring with a bore guage, then a mic, etc., adds so much potential for small errors, there has to be a better way. And there is. Slide your new piston into the cylinder, and start slipping feeler guages in between until you find the "real" piston to cyclinder clearance. That doesnt lie. As long as your well within the specs in the OWM......
    Another thing to loos at are the wear patterns in the old cylinders and its matching piston. As long as they are all about even to one another and nothing looks wierd, your in good shape. These motors are far more plastic than many may realise, and the cylinders distort in varying degrees through each and every heat cycle. IOW,they are never, and can never be perfectly straight and true. But none of it is enough to matter much, as we see each time one is torn down; very minimal wear, nice patterns, etc..
    See you have dirty mess too. I wonder how long it really takes for these cars to get that nasty. Probably not as long as we would like to imagine.
  4. BigTex
    79,420
    Houston, Texas
    Bubba
    3.0L is 172 cu inches....:)
    I'd keep the charcoal canister and associated tubing, that's tank vent system. The air pumps and rails,......not so much!!
  5. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    I have taken about 10 measurements in each cylinder in every possible direction. Once the pistons are out, I will get the very bottom area. I agree it is incredibly difficult to take accurate measurements with these bore gauges, but I am certain what I have now is accurate.
    Once things are torn down further, I will slip a piston in with a feeler and wrap this up once and for all. Thanks for that Paul
    The mess is nothing that a good pressure washer can't take care of!
  6. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,642
    Along the Verde , AZ
    Doug
    If you are using a spring loaded T type bore gauge, they are real easy to use and get accurate readings.
    The secret is to put the gauge in at an angle, tighten the spring loaded rods and then rock the gauge out , it will compress to actual bore size during rocking and you won't get any undersize or oversize readings, as during the rocking process, the gauge finds the widest part of the bore,a nd once it snaps free, it had reached minimum measurement on the widest part of the bore.
    Doug
  7. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,642
    Doug
    BTW, you are quite motivated for only 20 HP. Though if your car is visible blowing some oil smoke, I would get motivated also.
    I would personally be more interested in getting rid of the hard corner carb stumble than adding 20 HP, given the choice, but I am not sure it is possible to eliminate the stumble without going to EFI and throttle bodies.
    Good luck.
    Doug
  8. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    Burning a quart every couple hundred miles. That's too much for me to be able to sleep at night with. Realistically, I am thinking I will get 30bhp+ at the flywheel out of this, but I don't want to set my hopes too high :)
  9. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    #84 Ferraripilot, Apr 14, 2010
  10. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    Pistons came out last night. Sorry, at work now and pics are at home.
    The rod bearings are SHOT. I can't see any copper showing through, but they look gruesome. The pistons are pretty much flawless and very clean. The old ring end gaps have about .028 wear throughout the entire engine. So if they started at .015, that amount of wear at 83k miles is not terrible, but still time for replacement. The cylinder wear at the bottom of the engine is also matching that of the top end. Very little to none.
    Machine shop called. Valve guides have about .008-.010 wear.
    This goes to show us all that this really strong old engine which still pulled impressive numbers was worn to hell, except the cams. This tells me even a fresh broken in engine will yield maybe 1% more power if a worn engine was making as much as it did. The original (and only until me) mechanic on this car advised me the one and only other owner really babied the car and broke in the engine TOO properly and gingerly in his opinion. This car was his daily driver in the bay area of CA for 4 years where it racked up it's first 40k miles. After sifting through receipts, I personally believe the oil was not changed often enough. For instance, it went a year and a half without an oil change, but only 500 miles. I change it every 5-6 months regardless of mileage unless I happen to put 3k miles on the stuff within that time frame.
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,880
    The twilight zone
    When I got my QV it ran fine but leaked oil everywhere so I decided to pull the engine to re-gasket it. Basically nothing inside was any good but it ran fine…..sometimes its best not to look.
  12. furnacerepair
    furnacerepair Formula Junior
    Feb 9, 2009
    744
    Wisconsin
    Martini
    #87 furnacerepair, Apr 15, 2010
    Brings back memories. Keep up the good work. Looking good. You know how it goes, as long as you are in there ,,,,,,,,,,,,,,,,,,, Hard to stop once you get going. I ended up with all new parts. I'm not sure how that happened. LOL I think all we reused was the castings and crank. Funny thing was the car ran great before we started. Oh well.
  13. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    Yeah that is just kookie that everything would look so sour with such a strong running engine, albeit was burning a bit of oil
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,880
    The twilight zone
    A good design works with large component tolerances. You didn't want to just change the cams anyway did you?
  15. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    #90 ramosel, Apr 15, 2010
    When I got my car it was leaking everywhere and burning more than a bit of oil. We jokingly called it the "Enzo Valdez". The PO was a good friend and wanted to pay for any repairs so we yanked the motor and had it looked through. All the oil issues were in the heads. The bottom end looked good and showed leakdown at the block of less than 1% on all holes. But that started a long journey on a road that you started down.... Here's a look just before it went back in a month ago.
    Rick
  16. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    #91 Ferraripilot, Apr 15, 2010
  17. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    cleaned up the rods last night and mounted the new pistons. pics later. also removed both pans on the transaxle. surprisingly clean. almost disturbing how clean they are actually. getting ready to install Verell's quad seals
  18. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    As others noted, the two motors ive torn down looked simular. What I hate seeing though, and we see this all the time, is filthy black oil and black internal engine parts and castings. Anyway you want to play it, its a sign of someone running extended oil change intervals. This doesnt 100% mean the cause of wear, but it sure doesnt help.
    My first engine was black inside like that, but I ran some motor flush and MMO through it and it cleaned it up very nice. The second engiine was so dirty that even after 2000 miles and 4 oil changes, etc., it was still dirty.
    I hope you stay on course and are able to get her back up and going soon. As you can see by the previously posted motors, "while your in theres" can take over and can really slow you down. But a lot of that becomes justified as the costs spiral upward. Its far easier to slap a motor back together without everything being 100% when you only have a few bucks wrapped up in it. But when the parts bill starts exceeding $$$$$$, you start thinking different. I certainly am not able to justify putting an engine back together after blowing almost $10K in parts unless its fully done. Yet in reality, as noted by how well these engines run in marginal condition, we probably dont need to be so damned anal. Long as its pretty on the outside and runs like a scalded cat, who cares?
  19. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    The PO def did not change the oil as much as I would have. I changed the oil like clockwork at least 3 times a year regardless of mileage. The cam covers were very clean, as opposed to the first major I did when I first received this car when the inside of the cam covers were filthy. Oil pain was very clean, pistons clean, but the walls etc were black and gross. Hate it when that happens.
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,880
    The twilight zone
    Over heating is the normal cause of black internals....I needed paint remover to degrease the inside of my QV engine and I know that was cronically overheated.
  21. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    wow! good to know. I was thinking of using lacquer thinner or acetone to clean the really black and gritty areas
  22. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,642
    Doug
    That and your engine blackness can often both be attributed to fuel dilution of the oil. You really need a good 50 mile or more drive fairly regularly to get the fuel out of the oil.
    Short drives on carb'd cars tend to accumulate unburned fuel from start up, in the crankcase.
    Doug
  23. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    As a general rule, I do not drive the car unless I can put at least 40 miles on it. As to what the PO did, I have no idea. No doubt it's filthy in there. Since I have had the car, I have racked up about 5500 miles and have changed the oil about 10 times. When I first took ownership, the cam cover insides were filthy from lack of frequent changes. Clean now, but I guess no matter how often one changes the oil you can't make up for previous years of negligence.
  24. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,642
    Doug
    #99 AZDoug, Apr 16, 2010
    Wasn't implying you did it, but this highlights that a low mileage car can have trashed motor.
    A 30 year old car car with 5K miles on the motor can have more wear than a 70K mile motor, due to being driven only a few miles each month, or worse yet, being started every week and idled for 5-10 minutes without a chance to thoroughly warm up and evaporate the water and gas out of the oil.
    Doug
  25. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Very true. And some people think the ones with less than 1000 miles in 30 years are even better. What a waste.
