the lvferraripilot engine rebuild thread | Page 5 | FerrariChat
Discussion in '308/328' started by Ferraripilot, Mar 29, 2010.
  1. jgoodman
    jgoodman F1 Rookie
    3,271
    Central PA
    Jay Goodman
    Wow! Beautiful job there!
  2. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,920
    Atlanta
    John!
    #102 Ferraripilot, Apr 17, 2010
    Lots of cleaning and scrubbing today. Crank cleaned. Deck cleaned. power washed block and a few other parts. The main bearings have little to no wear.
    I notice the bell housing a spacer plate must be cast from a different type of aluminum as I was not able to get them nearly as clean as I was able to with the block. As you can see, the block is super shiny while the other pieces are quite dull grayish.
    I will use a flex-hone on the cylinders later tonight or tomorrow. I am using a 240 grit hone and will lubricate with 5w/30. I have used these in the past with great success. You just have to make sure you don't overdo it. I usually do 6 strokes clockwise and then 3 counter-clockwise at a pace of about 1 stroke/second.
  3. i-velocita
    i-velocita F1 Rookie
    2,520
    Colorado
    James
    Great work John. I have really enjoyed this thread. Please keep the photos and details coming!
  4. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Man, i wish my mechanic would work this fast. :(
  5. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    #105 AZDoug, Apr 17, 2010
    I used to be motivated once. ;)
    When I was in my 20's, it was sex and money (and cars), in that order.
    Now that I am in my 50's, I have money and am not as interested in sex anymore, and cars are a lot of work, so things take longer to get done than they used to. :)
    Doug
  6. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    Timing driver cover and bearings are out and cleaned up. New bearings should be delivered Monday. The rings required very little filing. Top and second ring gap is set to .015. The heads should be ready Tuesday. I am going to wait until I have those on hand to drop the crank and pistons in so I can assemble all those items in one evening. Everything is looking good. I know I am going to hit a snag when I go to set those cams up.
    Going to run with the stock early carb cams at first set to 110 lobe centers, as opposed to the stock 98 intake center (yikes!). With this compression that should put peak power around 7600ish. I know a little about the cam cogs/pegs/holes and their degree values but I have never actually set one up before. On paper I am good to go, but we all know how these things go once one is knee deep in this crap. Let's hope I don't win a Darwin award :)
  7. ztarum
    ztarum Formula 3
    Mar 30, 2008
    1,302
    South Jersey, USA
    It can be done in only two tries. One initial measurement, and one calculated adjustment. The tricky part part is figuring out what combination of pin/hole moves will get you the number of degrees you want. It can be done, but it does take a bit of head scratching. I found it helpful to draw everything. I drew each of the pulley hole, with each of the cam flange holes underneath. It made it easier to visualize what I was doing.
    Don't forget that you only need to rotate the cam 1/2 of the amount you read at the crank.
  8. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    The cylinder liners were flex-honed last night. Man I love that tool. Quick, easy, but dirty. Pics later.
    I test-fit a piston and ring pack. The oil scraper rings were incredibly tight. A call to Newman calmed me down a bit (thanks Paul!). I called Total Seal this morning to see what I am working with here and as it turns out these are a standard 25lbs tension oil ring, and they are supposed to be hard to move! They relax a bit after a few cycles, but not much.
    Pics later. At work yelling at people now.
  9. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    I wish I could find these specs, but they are not in the manuals I am searching in. If anyone knows, I could really use the following torque specs:
    mains bearing caps/nuts
    rod bearing caps/nuts
    cam caps/nuts
    ring nuts on timing gears
    ring nuts on drop gears
    cam bolts to cam pulley
    flywheel bolts
  10. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    finally found some answers:
    the 'Ferrari' way of torquing the heads is to first apply 35lbs of torque and then turn all the bolts 120 degrees from that 35lb position.
    pulleys to cams: 72lbs
    main bearing caps: 65lbs
    camshaft caps: 6.5lbs
    pressure plate to flywheel: 18lbs
    connecting rod caps: 47.5lbs
    flywheel to crank: 61.5lbs
    ring nut to mainshaft: 129.5lbs
    ring nut to clutch shaft: 144lbs
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Where did you find this? My 308 WSM says 10dam, about 73 ft-lb. Evereything else looks like a match
  12. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    Mark, I found that method in a 328 tech manual.
  13. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
  14. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    #114 Ferraripilot, Apr 21, 2010
    Crappy pic from my iphone on my way out this morning. Short block assembled last night. Engine turns very smooth. My concerns regarding the tight oil scrapers is no longer there. A quick measurement for deck height with these pistons showed .047. Stock is .052. .005 does not make much of a difference with this motor, maybe .05-.07 compression, but the giant domes on these pistons bump things up quite a bit. I figure with these being forged rather then the stock cast pistons that these will expand to a yield a little bit taller deck height. Maybe another .003.
  15. Harry
    Harry Karting
    Nov 1, 2003
    101
    Germany
    Maybe I missed this in your previous posts - but it seems like you did not remove the cylinder liners, i.e. you did not change the o-rings.
    Is this common practice to leave the liner alone in a complete engine overhaul?
    Regards
    Harry
  16. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    Correct. I did not remove the liners as the liners themselves had less than .001 wear and taper. Had a couple of the liners required removing then I definitely would have removed them all and bored or replaced them correctly.
  17. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,523
    Canada
    Newman
    I was wondering about the o-rings as well, the ones that seal the liners to the block. Two schools of thought on these. I prefer to remove the liners and replace the o-rings for liability reasons and to save headaches later and get a look at where they actually seal addressing any issues now, others like to cross their fingers and leave them be.
  18. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    I considered getting them out, but was advised to not mess with them if the cylinders and rest of the engine was in good shape. A former dealer mechanic from Griswold Alfa/Ferrari and Ferrari of SF advised me this way. Different schools of thought for everyone I suppose.
  19. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,007
    Cape Town South Afri
    Dave
    Good to see those pistons back in a motor . Keep at it John you are getting along nicely . A whole lots better than Chris and myself !!!!
  20. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    You and Chris are going to have a couple serious engines once completed. I wouldn't be half as productive if it were not for my need to feed fchatters pics of my progress.
    As a side note for anyone who knows Lotus engines. I was reviewing some cam profiles and came across the old Lotus '104' cam profile which was a rally cam they used years ago which is now a very popular upgrade for early NA Esprit owners (with hi-cpr setup). The 104 cam is nearly identical (other then lift figures) to that of the early US/Euro carb cams. It's funny that just 5 years ago I was 'upgrading' a Lotus engine to a 104 cam only to find this is a stock Ferrari profile. I made 90bhp/liter with that 104 cam at 10.5:1.
  21. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    John is on a roll alright.
    Good thing there wasn't money involved when i said June 2011. ;)
  22. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    On my top ten list of things I absolutely detest doing is scraping stubborn gaskets. What a waste of time IMO. Anyway, yes I scraped all old the gaskets off of everything last night. Waiting for my heads to come back (shop said they would be done last week!).
  23. duck.co.za
    Jan 9, 2007
    1,007
    Dave
    Now that you have done it !! Wurth make a great spray on gaskit remover
  24. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    I sprayed the gaskets with gasket remover for a solid week because I knew many of them would be very stubborn. Indeed they were still stubborn :/ Maybe I should have used the gunk you speak of.
    mixedgas likes this.
  25. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    Just received a call from the machine shop. Heads are done. WIll pick them up at lunch.
