the lvferraripilot engine rebuild thread | Page 6 | FerrariChat
Discussion in '308/328' started by Ferraripilot, Mar 29, 2010.
  1. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,007
    Cape Town South Afri
    Dave
    Oh dear Chris looks like this motor is going to be together this weekend . John you have certainly shown us how to get on with it !!!
  2. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,920
    Atlanta
    John!
    Picked up the heads. Man they are pretty. Very smooth and shiney deck. pics coming. Waiting on my timing gear bearings to show up........ I ordered them over a week ago now.
  3. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    #128 Ferraripilot, Apr 23, 2010
  4. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    WOW
  5. jgoodman
    jgoodman F1 Rookie
    3,271
    Central PA
    Jay Goodman
    Very nice. But please educate me....what is the purple stuff around the valves?
  6. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Ain't it the truth. :eek:
    John, those look soooo sweeet!
    I have to bow to you my friend cause I'm not worthy.
  7. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    IIRC, it's called bluing spray and it helps the machinist know the radius of the cut. I am sure this is not the complete answer so anyone feel free to chime in.
  8. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    Ran into a small snag today. The exhaust seats were cut a little too deep making the exhaust stem sit up too high. It sits so high that when the shim bucket is placed it gets in the way of the base circle of the cam lobe itself and has zero clearance. What a mess. I am not entirely sure how the machine shop is going to fix this. Perhaps it is a matter of removing .020 or so from the valve stem?
  9. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,685
    Honolulu
    Kevin
    Blue stuff is dykem. It's hard to see the material removal on bright metals like aluminum so the machinist uses the dye to identify the before condition. It's useful to dye and then scribe material also for lower tolerance applications to give one a witness line to cut/mill to
  10. duck.co.za
    Jan 9, 2007
    1,007
    Dave
    #135 duck.co.za, Apr 25, 2010
    How much valve stem sticks past the cotters ? Shortening the valve stem is not a problem . When I was rebuilding a Honda RC30 V4 bike motor we could not get different size schims and the Ferrari machine shop at the time set the valve clearance by machining the valve stems !!!
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Hits the bucket itself as in you have a 3mm problem or hits the shim that sits is in the top of the bucket? I suspect its the latter because I just don't see any way to grind 3mm out of the seats.
    So, pop the shims out and check the clearance that way then check what shims are available and see if you are still in a useable range. If not shortening the stems a little is ok just watch that the bucket has clearance to the spring retainer. Beyond that you can have the seats replace.
  12. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    #137 Ferraripilot, Apr 25, 2010
    Here's what I'm dealing with. The exhaust stems have quite a bit of room to remove material so I am thinking I will be ok. The bucket, not the shim, literally poke out a good .020 from the bottom of the cam bearing bottoms. I have no idea if they cut the seat too deep/removed too much material from the valve mating portion or if the valves are too long. Ferrea has made umpteen thousands of these valves so I suspect it is not the latter.
    On the opposite end, the intake valves will require another .040 shim to get them into spec so it appears they cut those either very shallow or something else.....
  13. duck.co.za
    Jan 9, 2007
    1,007
    Dave
    John what paste are you using on the cam bearings ?
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    The cam won't touch the bucket I don't think. Pop the shims out and see what you have.
  15. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    #140 Ferraripilot, Apr 25, 2010
    more info. Removed shim from bucket and found the the cam shaft portion has .010 clearance from the bucket, but the base circle has no clearance and upon rotation the lobe itself comes into contact with the bucket. The bucket has a depth of .120. After measuring all the cam specs, I am coming up with the base circle being .008 in the bucket. Not sure how much will need to be removed from the stem to correct this. .030-.040 sound about right?
    Dave, I am using Lubriplate 105 engine assembly grease. I like the stuff.
  16. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    #141 Ferraripilot, Apr 25, 2010
    Some pics of the cuts themselves. It appears the shop sprayed with red dykem first, made a cut, sprayed with blue dykem, then made another cut. I have no way of telling how good a job they really did.
    The stock intake valve with its respective cuts is shown compared to the Ferrari 'super-flo' valve which they claim flows much better. The second back cut of the 'super-flo' valve appears to be 2-3 times wider compared to that of the stock. Can anyone make sense out of this?
  17. duck.co.za
    Jan 9, 2007
    1,007
    Dave
    John are all the exhaust valves at the same depth ? In a previouse pic the third combustion chambers ex valve looks to be deeper ( may just be the pic !! )
    Possibly you could back cut the valve to narrow the seat width on the valve as long as the seat in the head is on the outer diameter of the valve seat ( does that make sense ? )
    How wide are the seats in the head ?
  18. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    Ex valves all measure up about the same (within .002 of each other). I follow what you are saying regarding essentially swapping areas of the valve which meets the seat which pushes the valve out a bit. The machinist would know once it's apart if that can be done, but the easiest way is probably cutting down the stem a bit.
    The seat diameter at the widest area is about 1.398 (35.52mm).
  19. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    OK I think I have this intake valve back cut thing figured out. The stock intake valve shows a much steeper angle of back cut while the Ferrea valve shows a more shallow cut (Ferrea says 18 degrees) which is also a bit longer. I can see how this type of cut provides a smoother contour at the throat yielding more flow.
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Maybe try dropping the stock exhaust valve in? It could be a problem with the new valves??
  21. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    I agree the issue is probably with the new valves. Plenty of room atop the valves to remove a bit of material to correct this. No worries.
  22. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    My thought was maybe compare to the stock valves....it is possible that the new valves were just plain made wrong. It happens.
    Also, if the valves are truly sitting a couple mm deeper than they should be you'll need to shim the springs back to spec installed hieght. Also also if the exhaust valves are sitting 2 mm deeper than they should be you've added about 2 cc to the combustion chamber volume id my math is right.
  23. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    How far above the top of the spring retainers (not the keepers) are the valve ends? That - a reasonable clearance & wear allowance is the max the valve stem ends can be safely trimmed.
    Doesn't look like there is 2mm it reads like you need, but hard to tell from the camera angle.
    You don't want the shim bucket to ever contact the retainer's top, even after wear.
    BTW, standard shim thicknesses are supposedly 0.015", 0.030", & 0.060". However, depending on the mfg, the mfg. tolerences will surprise you. When I was looking into shims for my SC project I found that one mfg's tolerences for the 0.060" shim was +0.000/-0.006 thou. & another was something like 0.060 +/- 0.005". These were 'precision' shims! Found this out the hard way when out of one set of 50 0.060" shims, a very large percentage measured 0.054", & IIRC NONE were over 0.056".
    Step back & think about this some:
    To compensate for the shop's machining error you're now shimming your valve springs & trimming valve ends. I know it will be painful, but you seriously should consider having the shop get another set of valve seats & machine them correctly.
  24. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    Thanks for the input guys. First thing I will do is have the machine shop compare the stock ex valve to the new one to see what the heck is going on there. It could be that the stem is too long, or the seating part of the valve itself is just that much different that it required a different style cut (unlikely).
    I measured the stem height to the retainer with a delth gauge yesterday, and all valves show .084 extra room before the retainer has contact. I suspect a safe amount of removal to be no more than .070. I will have the shop check the installed height of new one vs old to decide what the best plan of action might be.
  25. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,523
    Canada
    Newman
    Agreed.
