the lvferraripilot engine rebuild thread | Page 7 | FerrariChat
Discussion in '308/328' started by Ferraripilot, Mar 29, 2010.
  1. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,988
    Atlanta
    John!
    #151 Ferraripilot, Apr 26, 2010
    Called Ferrea, they told me to cut the stems of the valves IF the valves were made correctly and have correct installed height. This sounds like a big if. When I asked them about the hardening material at the stem, they advised they only area the hardening matters is at the shaft and the face.
    For recording purposes, installed spring height is 1.521
    Also, my head guy mentioned the exhaust and intake cuts were both light and could not understand how it could be so off. Good to know.
  2. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    #152 Verell, Apr 26, 2010
    Yes, that's the WSM spec for the outer spring's length with valve closed (aka installed spring height).
    Is that what yours measure, or were you just providing the WSM spec?
    You're probably well ahead of me on this, but I can only come up with a few causes:
    - NEW VALVES ARE OFF: The new valves are different dimensionally. Measure against the OEM ones. A 2mm difference should be pretty obvious to the eyeball.
    - SEATS ARE OFF:
    1) Seats were off to begin with:
    .Possibly they were badly worn & while a light cut cleaned them up, excessive wear accounts for the difference. If the seats had been previously worn & re-cut, then they wouldn't have looked very worn this time.
    .The seats may have not been fully seated in the head at the factory, then subsequent valve operation drove them deeper into the head. When shim-cam clearance was measured, this would be indestinguishable from valve & seat wear. I've heard this from a couple of professionals. They ended up having to replace & re-machine the valve seats on engines where the valve & seat sealing surfaces didn't show enough wear to account for the shim-cam clearance reduction.
    3) Seats were cut too deep in spite of what your guy believes.
    - BOTH VALVES & SEATS ARE OFF:
    If both are off in the wrong direction, the combined error is the sum of the individual part errors.
    Hmm, what were the original shim-cam clearances, and what were the original shim thicknesses?
  3. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    #153 Ferraripilot, Apr 26, 2010
    Exhaust AND intake valve shim thicknesses ranged from .152-.158. All exh clearance were still in spec ranging from .011-.012. The intakes are sitting lower and will need .190 shims to put them in spec.
    These heads have never been off, and the original mechanic advised me this morning of this engine requiring very little shimming throughout its lifespan. I am unsure of the installed height at the moment.
    Included are pics of the original exhaust valve. Margin looks good and if this were not a sodium filled exh valve I would say it is, like the intake valves, still very serviceable. The back cut may be different then the new valves but that is no way going to sink them that much deeper into the seat.
    I looked at the seats a little further and popped them open and found the cuts on the intake and exhaust are not deep cuts. Not even close. Look at the pics I have previously posted showing the seats. All of them look like that. Tons of meat in those things. The more I look and think, the new valves appear to be the culprit here......
  4. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    Not sure what current intalled seat height is. The heads are in the car and I did not bring my depth tool with me to work. Dropping off at machine shop at lunch.
  5. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    Heads at machine shop.......again. And now we wait.........again
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,879
    The twilight zone
    I'm sure you'll hear something quickly....they want to sort this out.
  7. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    #157 Verell, Apr 26, 2010
    That 0.190[4.826 mm!!!] intake shim is also a problem. The factory shim sizes are: 3.25mm[0.126"] up to 4.60 mm[0.181"]. I wouldn't go outside that range without someone(preferably at least 2 someones) with a LOT of experience building up modified 3x8 engines saying it's OK. Risk is if the shim is too thick, at high engine revs, the cam lobe can whip it out of the cup & launch it!!! Even then there's going to be the problem of getting custom shims made & hardened. The shim hardness must be matched to the cam hardness or either the cam or the shim will undergo rapid excessive wear!!
    Definitely time for some careful measurements of both the intake & exhaust valves. Especially the stem lengths & valve keeper groove locations relative to the valve seating surfaces.
  8. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    I told the shop about the intake valve issue and that they are probably seated a bit too shallow. They have yet to measure the installed spring height on those or do anything to the heads for that matter, but I am guessing it is off. Anyway, they want to charge me to recut the intakes setting them deeper. I guess I am ok with that? Kind of a drag they didn't ask me important questions like this when they had them apart the first time.........
    BTW Verell, shims are available up to .200 now. International Auto has them
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,879
    The twilight zone
    I'm now very concerned. It is absolutely impossible to grind a seat and have it come out bigger than is was to begin with so there is NO WAY the intake valves are seated to high. what you want to do is pick up the heads and either bring them home to measure or take them to a shop that knows what they are doing.
    You most likely have the wrong valve part numbers....they are probalby for another ferrari model but they are not 308 valves. Pop the valves out and compare to your old ones and you will see your problem.
  10. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,007
    Cape Town South Afri
    Dave
    I'm no pro here , but surely you don't want to sink/drop the inlet valve ? The short side radius in the port it so short already sinking the valve only makes it worse !
    With a new seat and the valve as high as possible ( original spec ) you minimise the combustion chamber volume and maximise the short side radius of the port ?
  11. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    Their explanation (which I can see) is the back cut on the intake is different compared to that of the stock valve which makes the face of the intake valve poke out a bit more making shim clearance huge! So instead of having .008 intake shim clearance, I know have like .048 because the back cut on the intake is so different. This is strange because common sense would tell me that a higher flow intake with a more acute back cut would push the intake further up into the seat rather than have it poke out a bit......... totally confused
  12. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    #162 luckydynes, Apr 27, 2010
    Here's something you might find interesting.
    When I do heads I'm still doing them caveman style with grinding stones vs. a form cutter with all the angles or radii on it.
    There is not a lot of room on the 308 seats for the angles that define the top and lower edge of the seat ... a person learning on 308 heads will be in the surrounding aluminum of the combustion chamber in no time using the standard 30 deg top angle. Now I have a set of stones all cut and sized specifically for the 308 heads.
    I also lap the valves so you can really see the exact conctact patch.
  13. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    #163 Verell, Apr 27, 2010
    They should be working against a copy of the WSM, it's very explicit as to the dimensions in this area, INCLUDING valve stem height relative to the cam centerline. In which case they have no come back as their work doesn't comply with the WSM.
    I'm having trouble fullowing what you're saying about the back cut angle, could you post a sketch of the seat profile & valve profile with angle dimensions? Did Ferrarea provide a seat profile drawing? If so, could you also post it?
    I share mk e's concerns about these valves.
    I know that thicker FIAT & VOLVO shims are available, BUT the largest that the FERRARI FPC lists is 4.60 mm[0.181"].
    I wouldn't exceed Ferrari's specs without some strong reassurance from someone with a LOT of experience that a thicker shim would stay in the cup at redline. For example, the FIAT cups might have a higher side wall around the shims, & I doubt that the FIAT engine revs to 7500+ RPM.
  14. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    I see that Sean & I were posting at the same time. Yes, I meant a dwg of your valves & seats like he posted.
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,879
    The twilight zone
    #165 mk e, Apr 27, 2010
    They are morons. The back cut is for air flow and doesn't touch anything in the head...it sit below the seat surface on the valve and that's way they call it a cut not an add.
    YOU NEED A NEW SHOP!!!
    I called my localish Ferrari dealer for a shop recommendation the other day and they gave me a couple names. I called both places and they both knew what they were doing…and you know I wasn’t asking for easy stuff. This might be a good way for you to find a decent shop.
    Looking at the pics of your heads I don’t see anything wrong so you probably don’t need a shop at all, what you need are the correct valves.
  16. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    +1
    Like Verell, I'd be real cautious of the larger shims too.
    Rick
  17. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    Shop called. Valves are NOT out, but they can already see per measurements of the OEM valves compared to Ferrea that the valves from Ferrea are dead wrong and are the cause of the issue. They will call and confirm with me later today.......
    Shop had a copy of the manual (which they looked up!) and installed height was done correctly.
    Thanks for the help and support guys.
  18. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    Suspect they won't make that mistake again any time soon. Their faces have to be pretty red.
  19. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    No one with any experience with these engines would ever suggest going to such thick shims. A QV or 2-valve engine with the installed heights done correctly will always fall into the 3.80-4.35mm range. Going with a super thick shim almost guarantees that the shim will be knocked out of the bucket at high RPM. And, why would you want the excess mass of a heavy shim sitting "that much" above the bucket edge.
    We're doing two QV motors now. Everyone involved knows the importance of the installed heights...and the proof is in the pudding when the baseline valve clearnaces are set.
    David
    Ferrari Service of Bedford
  20. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    John,
    Sorry, but this is not possible. If the installed height (of the valve) is correct, then you'd have adequate bucket to cam base circle clearances. If they had measured all of the installed heights prior to disassembly, they would find that, on average, it would be very close to what Ferrari specifies. The thickness of the cam buckets (which does vary slightly) must also be taken into consideration.
    Personally, your heads are at the wrong shop...
    David
  21. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    #171 Ferraripilot, Apr 29, 2010
    I completely agree with you David. I have no idea if they are pulling my chain or not. Whatever shop that does not check the new valves vs the old valves is not ok with me or anyone for that matter. I used this shop per recommendation from several people in town from various walks of sporting automotive brands. So long as this ends well I will be happy. This HAS to be a valve issue. I spoke with James Patterson at Norwood who advised he uses Ferrea valves all the time on these engines and ALWAYS sends a sample to Ferrea no matter what they say. Should have done that.......
  22. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    #172 Verell, Apr 30, 2010
    I'm confused & having trouble parsing the preceding statement:
    1) Are we talking about the same installed height? It commonly means the valve closed spring height, which is what I (& I'm pretty sure mk e) were referring to earlier. We're concerned that it's probably off. I don't know of a WSM procedure for directly measuring it as it's the distance between the valve spring seat & the valve retainer's bottom with the valve in the head & closed.
    I believe David is referring to the valve stem clearance (ie; valve end - cam lobe bottom) measurement shown in the WSM figure from the 308-328 WSM pg. B26 below. Which has got to be way off or we wouldn't be having this discussion.
    2) What dimension are you saying the shop measured as 'installed height'?
    3)When was the measurement done? ie: when installing the valves, or shortly before you posted the above statement?
    4)What was 'done correctly' setting the 'installed height', or the measurement procedure?
  23. 350HPMondial
    350HPMondial F1 Veteran
    5,342
    Edwardo
    John,
    I am really enjoying the photography.
    My heads are in the shop now, new guides and exh. valves.
    Your shims are way too thick. This is not good.
    I sent an exhaust valve from my 1981 Euro 2V 308 motore'
    to Si Valves.
    And, they made me correct valves, the first time.
    Edwardo
  24. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    Update...... Heads pulled apart yesterday and the suspect valves were confirmed to be the culprit. From the bottom of the exhaust valve margin to the top of the back cut on the new valve is very different to that of the stock valve which is causing the exhaust valve to sit far deeper in the seat than stock. Tip length and keeper height is the same. The intake valve ispretty much the opposite. Intake margin and back cut is thicker causing it to poke out further AND the tip of the intake is A good .040 shorter compared to that of stock setting. I called ferrea who swears up and down these are the correct valves and they have been making these for 15 years now. Bullcrap. Sent them back with a stock sample yesterday. As shown in the pics the seat cuts are perfect. Not too deep.
    Icing on the cake. Machine shop dropped one of my heads directly on the exhaust cog oil seal causing a substantial injury in the form of a serious deformation of the oil seal hole. They are fixing this right now and showed me some pics of stuff like this they have repaired in the past....... What a predicament
  25. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,879
    The twilight zone
    The valve are of course wrong, but it has nothing to do with the back cut being high or low. The back cut is a basically cosmetic feature and does not and cannot contact the head or affect the way the seat contacts the head. Your machinist is an idiot, is feeding you a line of cr*p, and clearly has no idea how to measure a valve. I really would not trust him to continue the project......
