the lvferraripilot engine rebuild thread | Page 9 | FerrariChat
Discussion in '308/328' started by Ferraripilot, Mar 29, 2010.
  1. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,920
    Atlanta
    John!
    This seems to be one of those things I hear all different numbers for. JE Pistons told me new undecked heads are about 40cc. Here I have seen 40.5, and Wiseco told me 39.5. Machine shop said they took about .012 off which is about 1.4cc. With this cc volume I get around 11:1 cpr.
  2. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    #202 luckydynes, May 20, 2010
    John,
    What piston to bore clearance did Wiseco tell you to run?
    Thanks,
    Sean
    edit: went back thru the thread ... I guess you didn't go with Wiseco but still curious about piston to bore clearance ... I've got a sleeve that's got .003" clearance instead of .0035" ... thinking of just running the one at .003" since I'm ready to assemble.
  3. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    Not running Wisecos or JE, but I do remember Brian from Wiseco advising me not to push .004 with this bore with .003 being optimal. I am at .003 with a couple cylinders closer to .0025.
  4. GrayTA
    GrayTA F1 World Champ
    15,130
    Deep South
    PDG
    I havent commented on this in a while, but I am still amazed at the work you have done. I cant wait to see it in person!!
    PDG
  5. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Thats strange. Wiseco told me 40.5, same as I measured on mine. Must depend who we talk to.
  6. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    #206 luckydynes, May 20, 2010
    Thanks for the feedback.
    I measured a .001" or more growth in the skirt direction from head tq.
    I had some scuffing on one engine with .003" clearance (Wiseco though ... different forgings grow different amounts) which had me concerned. It was only on the front bank which I think runs hotter.
    cheers
  7. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    #207 Ferraripilot, May 21, 2010
    Been super busy lately and have not had as much time as I would like to finish this project. Our new baby girl, Hannah, was born 5/4 and she combined with my 1 1/2 yr old have been keeping us stupid busy............and tired!
    Anyhoo, Hannah and pic of Hannah meeting big sister, Rachel (Rachel tried to kick her, but that's ok we'll figure this out!).
  8. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Congratulations John!
  9. gcmerak
    gcmerak Formula 3
    Mar 17, 2008
    1,664
    Engine Bay, Georgia
    George C.
    Ciao,
    George
  10. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,789
    Marin
    Geno
    John, congratulations. I have one that's 15, and you can have him for free ;)
  11. Easyrider7467
    Easyrider7467 Formula Junior
    Nov 3, 2005
    980
    Northen N.J.
    Congratulations
  12. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    Why does everyone say that about their 15 year olds!
  13. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    Think back....
    Rick
  14. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Congrats on the baby.
  15. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,686
    Honolulu
    Kevin
    Congrats on your addition. So much love is headed your way.
    now I can see why you were working so fast!!!!!
  16. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    #216 Ferraripilot, May 22, 2010
    16" repro wheels/tires arrived. They look pretty good. Very pleased with the quality. The rears weigh in at 48lbs each and the fronts are 42lbs each. Ouch! 40lb weight gain compared to the 14" Campys at 33lbs each. Not a big deal considering all the emissions equipment I removed weighs in at a stout 30lbs. Well worth it.
  17. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    big congrats on the new addition to the family...
    all the best
  18. 4right
    4right F1 Rookie
    Just wait, you will find out.
    Congrats on the new addition!
  19. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    Was messing around with valves and seat pressures etc last night. Almost done there.
    Once the engine is bolted together, I am going to run leakdown on each of the cylinders so I know where it is prior to break in. This way I will have a good idea if the rings are seated correctly once broken in. I figure I will run the engine 15-20 mins at a couple thousand rpm, then drive engine lightly while allowing the engine to decelerate in gear allowing the rings to push against the walls. After a couple sessions like this I will leakdown again and see where things sit.
    I read all sort of articles about breaking in an engine, but rarely do I see an article that actually suggests some sort of objectice checking of the rings to check and see if they are actually seated (duh!). This seems like a stupidly obvious way to know for sure if they are seated rather then wondering for 400 miles if they are doing what they are supposed to be doing. One is shooting in the dark without checking IMO.
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Yup. It will take at least 500 miles to get the rings fully seated. Personally I would keep it BELOW 2000 rpm for the 45-60 min, 3000 the next 45-60 min, ect and use a load and recover cycle with ever decreasing recovery time at each rpm point and also ramp up the allowed load as the rpm is ramped up so you'vve never been to WOT until you've gotten to the 7000 point. Check the leack-down at 500 miles and you should be under 1% leak....by 2000 miles you should be under 0.5 leak.
    Or you could just hammer it for 20 minutes and call it broken in like you can find various places on the Web ;)
  21. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,523
    Canada
    Newman
    I built an SBC for my nephews stockcar. We had no time to break it in because we were pressed for time before raceday so break-in was set timing, check fluids and put it on the track where it saw 7200RPM at the end of the straight every lap. Never broke and we freshened it up at the end of the season, I found nothing unusual. We still laugh about that break-in method.
  22. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    #222 Ferraripilot, May 28, 2010
    My break-in concern sits with the fact that I am using a steel ring with chrome facing as a top ring. What I know about chrome is that they take a stupid amount of time to break in at times, but they are great for carbureted applications (used to run them on dirt track late model engines with great success). I have never used NPR rings before, but Brian at Wiseco swears by them.
    Brian stated these chrome faced rings seat quickly, are about 5 times smoother than other chrome rings, and leak down better than any ring pack they have used prior. The outer chrome facing is a little dull and a bit soft to allow for quicker seating. When broken in with dino oil, they seat super quick. I am considering running a non-detergent oil for the first few miles. That's a bit old school though. We shall see.
  23. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    At the end of the day it probably matters little how you do it unless you baby it. That could in fact make the rings never seat.
  24. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Did you check the leak-down or measure the cam or bearing wear? Normally you get a lot more wear breaking in like that and never get the rings to fully seat giving a leak-down in the 1-2% instead of 0-.5%. at least that's what I've seem. I've also seen spun bearings and destroyed cams if things weren't just right going into a hard breakin....there is just no room for error when you run it hard out of the box.
  25. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    Some info here for anyone who cares!
    Stock piston weight: 331 grams
    new piston weight: 300 grams
    This weight savings of approx 250 grams across the engine is worth a few bhp on its own merit. Losing weight on a quick and heavy rotating mass is always a great way to pick up bhp. I forget the formula, but one is out there which gives a rough figure for bhp gained per gram of rotational mass subtracted.
