the official gothspeed 5.2 F355 intake project ........ prototype ...... | Page 3 | FerrariChat
Discussion in '348/355' started by gothspeed, Dec 13, 2008.
  1. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,980
    MD and NE
    Robbie
    I am waiting for my set to arrive by Xmas...:D
  2. rketex7
    rketex7 Formula Junior
    Jan 8, 2004
    511
    Midwest
    K.C.Y.
    :) You have to be nice Goth first....
  3. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    lol ......... you guys are awesome :D!!!!! Here is the latest .......... the 'gothspeed' tops were dynoed on Saturday ..... and here is some info ......
    Using 'stock' exhaust w/hyperflow cats ........ net gain was 5-6 RWHP at 8000rpm and above :) ..... but mid range power went down a bit ........ :eek:
    Since the velocity stacks I used were designed for very high volume/air-flow ......... it seems the demands of the engine only began to use the huge velocity stacks flow capacity at higher RPMs where it showed the gains. A possible example of 'too big a hole' ruining a good time ..... :(
    So next I will be shaping new velocity stacks that will increase air velocity at slightly lower 'air demands' and stick them into new air boxes. That way I will have two intake options to test, when my new higher flow exhaust gets completed .... :D!
    side note: as speedy_sam predicted ......... K&N filters made no noticeable difference vs stock paper elements in this test example.
  4. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    #54 gothspeed, Dec 22, 2008
  5. UConn Husky
    UConn Husky F1 Rookie
    4,425
    CT
    Jay
    #55 UConn Husky, Dec 22, 2008
    Thanks for the details Goth! so given the 355 is no torque monster the factory designed the airbox angle to keep velocity up at lower rpm's to help the low end, sacrificing a bit on the high end (just repeating what you said pretty much :D )
    And they do look sweet...is that painted or powder coated? Inside too?
    Edit: So I guess the next step is an active intake that keeps velocity up at low revs then opens up for better breathing at high revs. Maybe some kind of rubber flap? Or something like the afterburner flaps on the back of a jet engine? Just brainstorming for fun...
  6. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    #56 gothspeed, Dec 22, 2008
    Satin nero powdercoated inside and out :) ................ I have some other theories as to why the mids mellowed out a tad, but the matter is still under investigation .......... ;)
    As I mentioned above, the goal on the next set of intakes is to strike a better balance between the two dynamics ............. also this effect may only be the case with the 'stock' exhaust ......... when I get the monster done it could be a very different story ........ but by then I will have a few different intakes to test with to achieve the ultimate 'combo' ........ :D
    Edit: Variable intake is a good option and may come into play should a 'best of both worlds' size be too elusive ......... ;)
  7. PAP 348
    Dec 10, 2005
    100,245
    Mount Isa, Australia
    Pap
    Very interesting mate!!! Well done! :D:D
    They look cool. :):)
  8. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
  9. PAP 348
    Dec 10, 2005
    100,245
    Pap
  10. eyboro
    eyboro Formula Junior
    989
    Chicago
    Eitan
    #60 eyboro, Dec 23, 2008
    Why don't you eliminate the upper muffler like fabspeed?
  11. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    I did that once and it changed the intake sound a tiny bit :eek: ......... it could be a 'sound resonator' of some sort ............... though when I get my new exhaust installed there may not be a real need for it then ......... your suggestion will definately be taken at that point ....... :)
  12. 285ferrari
    Sponsor
    Sep 11, 2004
    20,980
    MD and NE
    Robbie
    I think all needed is a plug of some sort to get rid of that little black box...Wonder how these would fair on my car with Fabspeed headers, HyperFlow cats and the Capristo race exhaust!! Goth will they be already powdercoated from you when sold?
  13. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Yes ........ a tapered heavy plastic disc is what is needed to engage and seal using the stock v-band clamp :) ......... on your heavily modded 355, I don't think the 'resonator' sound effect would even be noticed ............ :eek: ............ I will make a couple of those 'discs' this weekend if you want to try one out Robbie ....... no charge .... ;)
  14. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    I think it might be some kind of reverse pressure wave equalizer/canceler, but what do I know. It's there for a reason though.
  15. UConn Husky
    4,425
    CT
    Jay
    Common on many cars, there's a huge one that comes stock on the STi. At least on the STi it's for noise only, definitely makes a difference.
  16. PAP 348
    Dec 10, 2005
    100,245
    Pap
    Thats all it would be. :):)
  17. 285ferrari
    Sponsor
    Sep 11, 2004
    20,980
    MD and NE
    Robbie
    Sounds good!!
  18. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    #68 gothspeed, Jan 1, 2009
  19. 285ferrari
    Sponsor
    Sep 11, 2004
    20,980
    MD and NE
    Robbie
    VERY cool!!!! Can I paint it nero??? Or you suggest leaving it as is---Almost looks to pretty to paint..
  20. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    I normally recommend everything nero ............. but that v-band clamp has some sharp edges and will surely scratch it ...... :eek: ......... though if it must be nero ...... I would paint only the 'outside' so if any paint decides to flake off, it will not go into the 'un-filtered' engine intake ....... ;) ................. if/when I install one of these ....... I will leave it natural aluminum ....... :cool:
    What do you guys think ............... natural or nero??
  21. 285ferrari
    Sponsor
    Sep 11, 2004
    20,980
    MD and NE
    Robbie
    Looks really cool like that
  22. FullChat
    FullChat Formula Junior
    Jan 1, 2007
    339
    San Antonio, Texas
    As a style question, the natural contrasts nicely with the nero everywhere else to me...
  23. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    Oz:
    Your work is impeccable. You have my vote for the 348/355 section MVP. Thanks for taking the time and energy to develop these performance enhancing products at a reasonable cost.
  24. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    Very nice Ozzy!
  25. PAP 348
    Dec 10, 2005
    100,245
    Pap
    VERY nice work Oz!! :D:D
    I would paint it black. Stick it in, clamp it up and mask the surrounding area as best as possible and give it a quick hit with some black spray paint. ;);)
