The Purosangue Thread | Page 137 | FerrariChat
Discussion in 'Purosangue' started by MDEL, Dec 6, 2017.
  1. Frank_C
    Frank_C F1 Rookie
    3,055
    Whistling through the wheat field in Texas
    Frank
    Black is not slimming, hides curves and a royal PITA to keep clean in an SUV.
    tomc likes this.
  2. jumpinjohn
    jumpinjohn F1 Veteran
    7,896
    Texas
    Black is hard to keep clean on any car, not just an SUV…. :)
    At least where I live. ;)
    tomc and LVP488 like this.
  3. Tommy Boy
    Tommy Boy Karting
    Aug 27, 2020
    199
    Thomas
    Agree that if you're driving the car normally, or as a daily, CF doesn't make much sense on the Purosangue.
    Would you do outside CF if you're getting one of the initial ones, especially if a V-12 that is then not offered on the regular production runs?
  4. ScottS
    ScottS F1 Rookie
    2,953
    Winter Park
    Scott S
    Maybe. Of course Not all Nero is the same.
    Nero Daytona, Nero Setoso or Nerotto come to mind
    Not sure on the CF yet in general. I suspect the V12 will be visually distinguished from the other from the get go but like other “sport” suvs one may need a PhD in Porsche Ferrari design language to do so.
    The Lusso T was only distinguishable by the wheels
  5. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,184
    Denmark
    Max
    Well, this and the fact that we received an official email from Ferrari saying their new "thoroughbred" car is having a V12.
  6. 4re4ever
    4re4ever Formula 3
    2,276
    Auckland/London
    Simon
    It having a V12 is old news, most have know this fact for quite sometime.
    The question on alot of peoples minds has been the size of the V12 due to the front being smaller than the lusso. Many are thinking maybe it will be a smaller V12 like 4L. My observation about the massive dash shows hope it will be a Big V12, 6L like it should be.
  7. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,184
    Denmark
    Max
    Ok I understand what you meant. Im curious how much shorter would a 4L V12 be vs a 6L. For the same stroke, the cylinders only have to be 22% wider to account for a 50% displacement increase. From the 94mm bore from the 812SF, this would take it down to about 77, so 10cm shorter overall. But they would also most probably reduce the stroke in order to keep it supersquare. So overall length difference would be less than 10cm I assume.
    sailfly and spyderman like this.
  8. Jljr
    Jljr Rookie
    Feb 25, 2018
    49
    Miami Beach
    Assume one must order 4….but, anything goes these days.
    Marcel Massini likes this.
  9. 4re4ever
    4re4ever Formula 3
    2,276
    Auckland/London
    Simon
    Personally that's just to much Time, development cost etc for them to really consider. It would affect sound, performance, nor would the customer base be happy with it. Then as you have shown it won't make much difference on size. So based on all the factor it will be in the 6L range. which makes me very happy. Then the Next question is will the other version be hybrid V8/V6 or both?
  10. camshaft
    camshaft Karting
    142
    MA
    Austin
    Why would they want an oversquare bore on an SUV though? I would think on an SUV they would want the increased torque of a longer stroke with smaller bore, which also decreases engine length.
  11. MDEL
    MDEL F1 Rookie
    4,132
    Southern Europe
    Mario
    The first picture was taken yesterday outside Maranello's factory and it's of a Purosangue mule on a Levante body with a higher ground clearance than that seen on the last version of the mule and also on the older versions with the Levante bodies. Being a mix of a sports GT a Crossover and an SUV the Purosangue will have to be able to adjust the ground clearance substantially in order to cope with the very different driving conditions. I don't see how that can be done without using an air suspension but I wait to see what they come up with because Ferrari is well known for its inventive and unorthodox solutions.
  12. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,184
    Denmark
    Max
    I would imagine to keep it high rev, as this is an expectation from the customers? Also, big bore means big valves and more air/fuel mix.
  13. [gTr]
    [gTr] Formula 3
    Mar 11, 2008
    1,056
    Hamburg, Germany
    I would be very surprised if they would change their tried and tested formula. My guess is they are going to take the 812 engine and wet sump it and lower the redline to 7700-8000 rpm.
    350MH83 and Kavir like this.
  14. jumpinjohn
    7,896
    Texas
    What is the advantage of those changes?
  15. Chicko
    Chicko Formula 3
    pcht5 and Maggio23 like this.
  16. MDEL
    MDEL F1 Rookie
    4,132
    Southern Europe
    Mario
    Let's hope it improves once undressed...:)
    pcht5 and 456-boy like this.
  17. [gTr]
    [gTr] Formula 3
    Mar 11, 2008
    1,056
    Hamburg, Germany
    This is what Ferrari has been doing with its V12 GT cars. It was the same with the FF and GTC4Lusso, both had wet sump versions of the F12 V12 with reduced redlines. I believe this tones down the manic free revving nature of the V12 in the 2 Seater cars and also reduces the wear/stress on the engine making it more reliable.
  18. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,184
    Denmark
    Max
    Both FF and Lusso have dry sumps though. They also had the exact same bore x stroke than the F12. The California had a wet sump. Not sure about the Portofino.
    Caeruleus11 likes this.
  19. [gTr]
    [gTr] Formula 3
    Mar 11, 2008
    1,056
    Hamburg, Germany
    Apologies, I was clearly mistaken! I thought all GT Ferrari cars had wet sump engines.
    jumpinjohn and 350MH83 like this.
  20. Maximus1973
    Maximus1973 Formula 3
    Oct 29, 2016
    1,547
    Hell freezes over before Ferrari will develop a new (smaller) V12 engine in the current political climate.
    It would be an insane cost to do so for a very limited time.
    They will keep the current V12 with perhaps few very, very small changes; if any.
    Caeruleus11 and ScrappyB like this.
  21. MDEL
    MDEL F1 Rookie
    4,132
    Southern Europe
    Mario
  22. Maggio23
    Maggio23 Formula Junior
    Jul 16, 2013
    286
    God Almighty, with such a clearance and an SUV body, it's just a freak!
    Chicko likes this.
  23. Chicko
    Chicko Formula 3
    An overweight freak and 100% pointless. No owner will ever take it off road, so its high centre of gravity is for absolutely no reason at all. It's a mini van but with a bit more clearance... Sad and bizarre times.
    Maggio23 likes this.
  24. jumpinjohn
    7,896
    Texas
    No worries!
    [gTr] likes this.
  25. Maggio23
    Jul 16, 2013
    286
