The Purosangue Thread | Page 212 | FerrariChat
Discussion in 'Purosangue' started by MDEL, Dec 6, 2017.
  1. Scudmsl
    Scudmsl Formula Junior
    Aug 12, 2014
    856
    Confirmed as well. They are trying to weed out the “uncommitted” due to higher than anticipated demand.
    Glenn Quagmire and elmadi like this.
  2. Moopz
    Moopz F1 Veteran
    5,587
    Orlando, FL
    Send him a PM! Maybe he will change his mind...
    Sent from my SM-N975U using Tapatalk
    Bmill and Glenn Quagmire like this.
  3. Bundy
    Bundy Formula 3
    May 18, 2011
    2,474
    Arizona & Kentucky
    Anir
    Crazy to think that “15 Ferraris all same dealer” doesn’t gain one legitimate cache in Ferrari Land…
  4. U-Boat Commander
    U-Boat Commander Formula 3
    1,339
    It does. You just won't be a Top without owning a hypercar or Icona or possibly doing Challenge.
    Maximus1973 likes this.
  5. U-Boat Commander
    1,339
    This is silliness. I am a lowly VIP, I was invited to Italy but did not go and I ordered the car months ago.
  6. Ferrari 308 GTB
    Ferrari 308 GTB F1 Veteran
    Feb 21, 2015
    8,096
    Tropical
    I know my place;)
    paulchua, 350MH83 and MDEL like this.
  7. MDEL
    MDEL F1 Rookie
    4,131
    Southern Europe
    Mario
    The new suspension system of the Purosangue seems to be revolutionary and therefore I look forward to the evaluations of those who will test the car in the near future. Meanwhile, I put here some information about the Multimatic suspension system that equips the Purosangue.
    The Multimatic TASV system equipping the Purosangue is the first production active suspension in the world to integrate an electric motor with spool valve damping. The high-power density, three-phase brushless electric motor was co-developed for this application by Ferrari . The advantages of this type of suspension are the following:
    1 It eliminates the need for any anti-roll devices and additional mechanisms for dynamic ride height and rate adjustment.
    2 It can also control the wheel motions with more authority and at higher frequencies than adaptive or semi-active suspension systems.
    This makes the steering wheel less sensitive to road irregularities and braking.
    3 The active suspension system uses accelerometers and position sensors on each suspension corner and interfaces with the Side Slip Con.
    Ferrari’s proprietary control logic, together with the TASV dampers supplied by Multimatic, electronically manages every performance
    element of the fully active suspension system.
    4 This technology optimises maximum cornering performance thanks to the variable and continual distribution of roll stiffness and the
    actively lowered roll centre (reduced by up to 10mm), to the benefit of the side force acting on the tyres and the balance between over and
    understeer.
    5 The high-frequency control regulates both body motion and wheel movement, thus reducing roll and pitch as well as absorbing road
    surface irregularities.
    elmadi, inox, FLU and 5 others like this.
  8. JackCongo
    JackCongo Formula Junior
    911
    Jacques
    Does anyone knows if the All Wheel Steering system also allows to improve the steering angle at low speed (like on the latest Audi RS6 or Porsche Cayenne), thus making maneuvering easier in tight areas?
  9. Caeruleus11
    Caeruleus11 F1 World Champ
    11,779
    The suspension system seems very very impressive. Might we see this on other Ferrari models in the future?
    My guess on the rear steer is it could be utilized to improve low speed maneuverability. Whats wild is its a similar setup to the 812 C- so the rear wheels can be moved independent of each other. In theory they can create toe in, neutral toe, toe out, situations, and vary them independently. If done with nuance and precision, I think they could give you more agility on turn in, a mix of agility and stability in mid corner, and then some more stability on track out. Im sure the purists would cringe, but I think if this is done very well, it could make the vehicle very enjoyable to drive on the road.
    ScottS, plastique999, ouzo12 and 3 others like this.
  10. Moopz
    Moopz F1 Veteran
    5,587
    Orlando, FL
    My Lusso has the same system. The wheelbase is literally 12 inches shorter than my Yukon XL (130" vs. 118") and it is supremely maneuverable for that length. Low speed and high speed you can tell that it's working.
    ARAUJO77, elmadi, Caeruleus11 and 3 others like this.
  11. gilly6993
    gilly6993 F1 Rookie
    Aug 20, 2009
    2,573
    Longmeadow, MA
    Eric
    Does it have a PTU?
  12. MisterMaranello
    MisterMaranello F1 Rookie
    Apr 5, 2011
    3,335
    Europe
    This is incorrect. I have been offered to place "an order" by my dealer, but he says the final allocation of cars is based on client status. So anyone can try to get a car, but the lower your standing in the client CRM system, the lesser the possibility of you getting an allocation. I have four cars in my name, so by no means anything close to VIP. Considering if it´s worth a shot trying to order a car, which I will sell on to someone in my circle who wants one with zero Ferrari history. If I get an allocation, I will let the forum know.
  13. Gh21631
    Gh21631 F1 Veteran
    9,365
    East
    My understanding is that orders haven't been placed, only deposits towards orders. At least this is what my dealer is telling me. I believe FNA or Ferrari will determine the order by priority in which they will be released.
    JAM1 likes this.
  14. jumpinjohn
    jumpinjohn F1 Veteran
    7,867
    Texas
    Well my dealer says I am special. ;)
    I do love the Ferraris but if I can’t get one, perhaps I will just order a Pagani!
  15. Moopz
    Moopz F1 Veteran
    5,587
    Orlando, FL
    Yes
  16. Im not drinking the Ferrari Kool-Aid.
    If it was so revolutionary, why not introduce it on one of their mid-engine models like the 296 or SF90.
  17. MDEL
    MDEL F1 Rookie
    4,131
    Southern Europe
    Mario
    We have again the profile view of the Purosangue side by side with the DBX 707 and with the Urus Perfomante. In aesthetic terms IMO we are dealing with three very different cars. The Urus seems to me to be one of those cars that you either love or hate and it's hard to find a middle ground. As I belong to the group of those who do not identify with the aesthetics of this Lamborghini, with all due respect I can only say that I find it ugly and overly big. As for the DBX when looking at its profile view what I see is another SUV similar to many others.
    If there is something that this comparison allows, it is to see that Purosangue in terms of design and lines is in a completely separate category.
    elmadi, Bundy, Caeruleus11 and 9 others like this.
  18. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,545
    Bournemouth, UK
    If anything, a taller, larger car, is in more need of such technology. We will find out if they use it on future sportscars too.
    LuxRes, elmadi, Caeruleus11 and 2 others like this.
  19. Gh21631
    Gh21631 F1 Veteran
    9,365
    East
    A big appeal of the Urus for me is its size. Its large enough to carry 4 or 5 people and plenty of luggage or golf clubs while still remaining agile and sporty. There is no point in having a larger vehicle like this if you cant fit people or stuff in it.
    JAM1, elmadi, paulchua and 1 other person like this.
  20. Moopz
    Moopz F1 Veteran
    5,587
    Orlando, FL
    Yeah, PS not even a small leap over my Lusso for utility. Having a hard time justifying it outside of shiny newness.
  21. Don’t forget the revolutionary suspension
    Gh21631 likes this.
  22. Gh21631
    Gh21631 F1 Veteran
    9,365
    East
    I'm looking forward to seeing one in person, I don't need Suburban type space but certainly needs to have some utility.
    elmadi, Bundy and paulchua like this.
  23. Gh21631
    Gh21631 F1 Veteran
    9,365
    East
    Suspension looks interesting
    Caeruleus11 and paulchua like this.
  24. footsoldier
    footsoldier Karting
    Sep 18, 2009
    246
    Urus (being an Audi..) is also proper 4WD. It’s a real SUV, PS is obviously more of a crossover.
    Ironically the Urus Performante is moving to simple steel dampers for a better response. Manthey do the same with Porsche GT cars.
    I’m sure PS will handle brilliantly and disguise its weight, but will you feel connected to it? Does that matter for most? We’ll find out soon
    elmadi, Bundy and Caeruleus11 like this.
  25. inox
    inox Formula Junior
    Oct 11, 2017
    628
    These comparison pics clearly display difference between FUV and SUV. FUV is elegant and SUV is just... an ordinary, massive SUV.
    Purosangue interior is so rear biased and sides so waisted that I doubt normal rear door arrangement could have been even possible/functional. It is nice too see such a different approach.
    elmadi and MDEL like this.
