The Purosangue Thread | Page 246 | FerrariChat
Discussion in 'Purosangue' started by MDEL, Dec 6, 2017.
  1. anunakki
    anunakki Seven Time F1 World Champ
    79,978
    Las Vegas Nevada
    Jerry
    The new Prius is gorgeous, as is the Puro. but they dont resemble each other.
    paulchua, therryzsx and F2003-GA like this.
  2. elmadi
    elmadi Formula 3
    Apr 25, 2009
    1,506
    The front light copy has started :-(................ thank you for sharing
    therryzsx likes this.
  3. PATRIEK
    PATRIEK Formula Junior
    Oct 2, 2004
    450
    Patriek
    this is
    this is not in the Ardennes, but at the dealership in Brussels …
  4. Xrayv8
    Xrayv8 Formula 3
    1,020
    New Jersey
    Xray
    The car has not even started production. This is a prototype that is being sent around to dealers and events to showcase the car hence why the rear plate says Purosangue. The US market has the red one going around which is currently sitting at the NYC TM shop.
    Caeruleus11, AMN and MDEL like this.
  5. DavidJames1
    DavidJames1 Formula 3
    Mar 6, 2010
    1,818
    Bangkok, Thailand
    This is the list of what’s standard in my market when I look at the options, it doesn’t mention things like Carplay or the various safety functions like adaptive cruise etc. so have no idea if they’re included. Will check with factory/dealer when I actually do the spec which probably won’t be for a few months yet:
  6. DavidJames1
    Mar 6, 2010
    1,818
    Bangkok, Thailand
    Apologies for repeating the image!!!
    elmadi likes this.
  7. Horsin'around
    Horsin'around Formula Junior
    Jun 14, 2017
    255
    Anyone know how long the PS will be at the NYC store for?
  8. Xrayv8
    Xrayv8 Formula 3
    1,020
    New Jersey
    Xray
    Its been there since early December and heard that by the beginning of February it will be moving around the country.
  9. ScottS
    ScottS F1 Rookie
    2,953
    Winter Park
    Scott S
    Someone above was asking about the plates. Here is one. I have the others from the event in Tuscany. Have to find. This one was another event.
    Caeruleus11, paulchua and MDEL like this.
  10. MDEL
    MDEL F1 Rookie
    4,132
    Southern Europe
    Mario
  11. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    6,200
    France
    It's amazing that with such a (relatively) tall car, the ground clearance does not make a "lift" option redundant.
    Caeruleus11 likes this.
  12. sailfly
    sailfly Karting
    Dec 21, 2020
    101
    There is no lift per se but there is an electric motor connected to a ball screw to move the damper tube and thus the wheel up and down within its normal travel.
    The AF suspension in the 296 and SF90 is just a spool valve with a high speed blowoff I believe. Most normal dampers regulate the valving with shims which is not so accurate so most cars dampers are tuned within a pretty wide tolerance. The spool valves allow you to get much closer to whats intended. And the blowoff helps when you go over bumps but there are limitations to the passive, which the Puro suspension should be able to solve.
  13. MDEL
    MDEL F1 Rookie
    4,132
    Southern Europe
    Mario
  14. Meow_x2
    Meow_x2 Rookie
    Jan 22, 2023
    24
    Hello,
    Have any Purosangue(s) traded? Does anyone know at what values or overages?
    Thank you
  15. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,738
    South East
    Jimmie
    This post might be more appropriate in abut a year's time once cars have begun to be delivered
    Sinnerman and paulchua like this.
  16. 456-boy
    456-boy Formula 3
    Jun 23, 2005
    2,058
    France
    Victor
    ryalex, Maggio23, Caeruleus11 and 6 others like this.
  17. MDEL
    MDEL F1 Rookie
    4,132
    Southern Europe
    Mario
    the rear diffuser of the Purosangue design is the result of in-depth optimization. The air flow that strikes the diffuser is gradually expanded and controlled. At the end of this expansion, a subtle nolder detaches the flow after slightly recompressing it. This boosts the system’s efficiency, simultaneously maximizing hot air extraction from the area around the gearbox and exhaust system compartments through the grilles.
    Maggio23, Caeruleus11, tomc and 4 others like this.
  18. 456-boy
    456-boy Formula 3
    Jun 23, 2005
    2,058
    France
    Victor
    That for sure will help the drive on Megève, Gstaad, London or Monaco [emoji56]
    (Joke apart, thanks again for your analysis and explanations!)
    Spet00 and MDEL like this.
  19. footsoldier
    footsoldier Karting
    Sep 18, 2009
    246
    I’m sure it’s going to be a great car, and I’ve been trying, but just can’t get excited and have cancelled today.
    May regret it after reviews come out! (But probably won’t… )
  20. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,610
    Menlo Park, CA
    Paul Chua
    You shouldn't have any regrets, this car is not meant for everyone. If you ain't feeling it, trust your instincts.
  21. AMN
    AMN Karting
    114
    NYC, Minneapolis, Bozeman
    A M N
    Not sure it makes sense to cancel it now unless you need your $30k back...
    soulsea likes this.
  22. soulsea
    soulsea Formula 3
    1,407
    29464
    Agreed. I really liked how it looked in the flesh, so now it's a $30k placeholder to kick the can down the road until I get to test drive it to decide if I want it or not.
  23. Frank_C
    Frank_C F1 Rookie
    3,055
    Whistling through the wheat field in Texas
    Frank
    #6149 Frank_C, Feb 3, 2023
    Ah. Life is short- no regrets. Don’t blame you. Back in the day I asked for my deposit back after I saw the 599.
    That car (599) is a two bagger and you certainly can’t drive with a bag over your own head…….
    ryalex likes this.
  24. Lukeylikey
    Lukeylikey F1 Rookie
    3,708
    #6150 Lukeylikey, Feb 3, 2023
    I’m kind of the reverse. Didn’t place an order despite our DP repeatedly checking with me. He kept gently mentioning it because if he gave the spot away he didn’t think it would come again - demand was really strong and Ferrari were insistent it was a limited run (they’re still adamant about that today but who knows). After a while I decided that I would place the order but was still concerned I would have no use for it. Today we did one of the early TM slots for it. I saw the car for the first time in the factory and I’m thoroughly impressed. They have done a magnificent job on this car. The TM came out completely different to what I intended (mostly because my wife had better ideas about it than I did) but I think it will be a great car in the spec we have chosen. They have somehow managed to come up with a design that disguises its proportions and feels effortlessly sporty despite the added height (which is actually much less than I expected). The surfacing is impeccable and shows just how clever the design team has been with PuroSangue. I’m really looking forward to it. It’s a Lusso perfected in my view.
    LeapFrog, ACW44, MDEL and 4 others like this.
