'The Ratarossa': The Testarossa Spider Rebuild Project | Page 19 | FerrariChat
Discussion in 'Boxers/TR/M' started by spiderscott, Sep 15, 2015.
  1. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,591
    romano schwabel
    inside this box 1 relais has an additional fuse. this you only can reach when you take out the box. when I still had this in my car I removed this fuse. connected 2 wires to the fuse socket and then those 2 wires out of this box and put the fuse then so outside, that I can change it fast without opening this box. this fuse once was blown at my car and it took me long time to find.
    spiderscott likes this.
  2. MisterT
    MisterT Karting
    Feb 2, 2011
    87
    Fleet, Hampshire, UK
    Simon Taylor
    Maybe there is a set of these relays for each bank. It should be interesting to find out if the relays in the other wing were seated well of not, maybe for you to un-seat them and see if the rough cold start re-appears back? Good find, maybe others can improve their cold starting from this.
  3. ago car nut
    ago car nut F1 Veteran
    5,523
    Madison Ohio
    David A.
    Good info, would of never guessed about hidden relay.
  4. spiderscott
    spiderscott Formula 3
    1,662
    Ratarossa HQ UK
    Ratarossa
    Just putting the opposite side rear arch in as we speak, can confirm there is no other box on drivers side rear with an additional relay. Only the one on the passenger side rear. I will look it up later and figure out exactly what its for.
    As Turbo Joe said, the relay has a 10amp fuse, mine was intact but should that ever blow it would be a ***** to diagnose and also not to easy to access.
    turbo-joe likes this.
  5. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
  6. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    Really handy tip that one Romano :cool:
    DonS likes this.
  7. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    It was 100% the relay not seated. Was the only job I was doing at the time and I had moved the car around earlier with the rough start and idle.
    Theres nothing on the other side, so this relay must control the entire system.
    Have tested the car again today and it fires up and idles (from cold) so much better, the transformation is quite amazing.
  8. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    Me neither, it was an absolute pure chance find and fix.
  9. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,742
    Argent/Brasil
    Guido
    We should all parting out our cars and re-install everything to find out those hidden things ! :D
    Guido
    steved033 and spiderscott like this.
  10. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    This next post is 'Riveting' :D:D:D
    On to my final wheel arch (Drivers front). I had started this a few weeks back, then removed it again as it is much easier to do the suspension with the arch liner out.
    Not an easy job, the hardest of all 4 corners. My brake booster pipe was in the way and without rerouting it to the opposite side which would involve somehow lengthening the pipe, I decided the easiest path forward was to make a small incision in the fibreglass then make a patch panel to cover it and allow the access to the pipe and union. I then had to trim a bit more here and there to get the arch to fit in place.
    Finally Ive started to rivet it all together (a few more to do in the morning) and then I will start to seal it and finally give it a coat of paint.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  11. turbo-joe
    Apr 6, 2008
    9,591
    romano schwabel
    as I already mentioned in my post 422 in this thread. it could not be fixed with rivets because of the large holes, and only the one sheet under the fuel tanks is fixed with screws
    you may have much time then, but later if you would have some problems you just know where to go and look. on my competition I know meanwhile so so much, but sometimes I also see something new. only things I have not worked on until now is the AC and the heating with all what is around
  12. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    Few jobs completed today.
    Finished drivers side front wheel area. All now riveted and sealed inside and outside.
    Started the rivet in place the passenger front now.
  13. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    With so many loose panels kicking around in my garage and sat in the car, I am now trying to create some space and fit the to the car, this also helps me work out finally the few items I have missing and need to acquire.
    Today was a bit of a milestone as I have managed to get the front of the car pretty much watertight (few rubber grommets needed), with the wheel arches in place I have now installed the front corner trunk panel, the a/c condenser cover, even re-riveted the fuse box front panel.
    A few jobs to complete it all but I have broken the back of it and its nice to see an area far different to how the car arrived.
    Eventually after a few other key jobs I spray this all up and make it look pretty :D
  14. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
  15. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    Being the first nice day of weather for a while here in the UK, I spent the rest of the day outside in the sunshine trying to get the front ride height to a point I am happy with.
    This took considerably more time than I expected, The wheels came off and on countless times, jacked up then down, made adjustments then moved the car to get the suspension to settle ....repeat, repeat, repeat. Im somewhere near the height I want to have the car now.
    Image Unavailable, Please Login Image Unavailable, Please Login View attachment 1141274 View attachment 923336 View attachment 823874 View attachment 591504
  16. turbo-joe
    Apr 6, 2008
    9,591
    romano schwabel
    looks much better now with this clearance between the road and the car.
    I would do all inside what you not see at first sight perfect, and only from outside the rat-look
  17. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    I have completed riveting the front passenger arch into place. Ive had to order some more sealant, don't want to run out half way though. Its such a messy job ( my hands are the proof of this, currently covered in black goo, anyway i don't want to run out half way and have to get fifty again, so have ordered another coupe of tubes to be safe :D
  18. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    Exactly thats the plan. Outside 'Rat' look, mechanically and everything out of sight, under a hood etc all as good as can be.
    In my head thats how envision the car. Then at a certain point if I ever want to change the car and have it looking good, it should be just a retrim of the interior and a respray and work to the exterior body.
  19. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
  20. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    So heres my dilemma .... when this car arrived, it was box of bits. I have fitted the heater before and managed to figure out the wiring. But the pipe work was a whole different animal !! This is my next job and its highly likely I will need some advise from you experts.
    The reason I am doing this now is I have the new dash on rout e and before fitting that and all the steering back in place its easier to at lease get the heater system piped up correctly before having to rip it all out again.
    Starting at an easy point 'The AC condenser' housed infant of the drivers side wheel arch.
    A few weeks back I fitted and wired (with your help) this into the car.
    The top pipe runs from the condenser (number 45) under the car across to the passenger side and into the dryer filter (number 40)
    Bottom pipe route to middle of the car and down the tunnel (I presume to the engine bay) .... I need to check connection at engine end.
  21. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
  22. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    There are a few broken plastic bits on the unit which i'm wondering of its possible to repair, they are just part of the plastic housing that holds the motors etc into place. I will try to figure out what the function of each is then work out how to repair.
  23. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
  24. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    #475 spiderscott, Mar 8, 2018
    First question.
    This pipework looks wrong.
    Currently the pipe comes from the back of the car joins together then goes back to the rear of the car (down the centre tunnel) ???
    I believe these should pipe into:
    1. The vent on the heater system (see arrowed picture)
    2. One (of the two ports) on the Electromagnetic valve (number 41)
    Is anyone able to confirm this ?
