'The Ratarossa': The Testarossa Spider Rebuild Project | Page 29 | FerrariChat
Discussion in 'Boxers/TR/M' started by spiderscott, Sep 15, 2015.
  1. spiderscott
    spiderscott Formula 3
    1,662
    Ratarossa HQ UK
    Ratarossa
    Car booked in for an MOT on Monday, lets hope it passes then The rat is back on the road again :cool:
  2. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
  3. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    It’s been a while since doing the wrinkle paint, I thought I would practice again on a 355 before doing the Testarossa heads
  4. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
  5. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Congratulations, Scott. A great moment for you. :)
    spiderscott likes this.
  6. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    Great weather again here in the UK so taking full advantage and doing a couple of jobs.
    Firstly my right headlight was always wrong height. I knew I had two left motors in the car as so just bought a replacement correct right motor. I then spent a couple of hours figuring out why no matter what I tried I could not get it to raise and lower correctly. Turned out to be the arm from the motor to headlight connection, somehow the arm that was fitted to the car was slightly shorter than stock and so I never had full travel up and down .... luckily I had a spare one and once fitted all is now good
  7. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    Next was whipping our the right side light to fix one (of the two) side lights. This was simply a case of loose connection and quickly rectified
  8. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
  9. mfaisal
    mfaisal Rookie
    Mar 19, 2017
    28
    Dubai
    Mohamed Faisal
    Good luck with the rest of the resurrection hehehe. Can't wait to see the end product!
  10. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    I’d have to check the connections on mine but those headlight motors look to be 1500cc X1/9 headlight motors, although the X units don’t have the thick textured paint covering them. The linkage piece shown appears to be the same as well.
  11. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    #712 spiderscott, May 9, 2018
    Correct :cool:
    I’ve got one 355 headlight motor on the left and a Fiat X1/9 motor now on the right.
    Work perfectly.
    The arm was originally with the old faulty motors that came in the crate of parts with this car. Luckily I had an old faulty 355 motor and simply switched the arm over.
  12. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    Cheers :):):)
  13. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
  14. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    In fact they worked so well I carried on and took the car out for a good half hour drive and shake down test.
    All temps etc reporting good and no overheating. :D:D:D
  15. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    Monday I have a well known car magazine coming to do an article and photo shoot on the ‘Ratarossa’
    Should be fun ;)
    steved033 likes this.
  16. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    Starting to make the upper interior trim piece for small area behind windscreen.
    I have cut up the old leather square from the coupe roof as clearly no longer needed. Then cover a fabricated panel to fit into place.
    Before fitting it I’m adding a nice thick rubber strip for added protection as I’m bound to whack my head a few times getting in and out of the car. The pitch of the 80s ferrari screens is much sharper than the modern day cars and I’m almost touching to top of the windscreen sat in the drivers seat
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    ///Mike likes this.
  17. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
  18. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
  19. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
  20. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,590
    romano schwabel
    the carpets around the speaker panels normaly have the same color as the carpets on the floor - oh sorry, it is a ratarossa :)
  21. kartboy1234
    kartboy1234 Formula Junior
    Nov 10, 2014
    727
    Palos Verdes, CA
    Michael L
    How'd you find a new one? And how much was it? I had my booster and master cylinder rebuilt instead of replacing.
    Sent from my ONEPLUS A3000 using Tapatalk
  22. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    Lucky find on Ebay brand new £200
    It’s the same as used in the 328 and a few other models
  23. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
    Yes I know, but remember I could only get hold of a set of the red carpets with speaker grills and speakers/ crossovers so dying red to tan was near impossible, hence going darker to the brown :cool:
  24. spiderscott
    1,662
    Ratarossa HQ UK
    Ratarossa
