The Restoration Starts Here: 275GTB Shortnose 07333 | Page 11 | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by 275GTB, Apr 6, 2010.
  1. djaffrey
    djaffrey Formula Junior
    Apr 11, 2004
    547
    London, England
    DJ
    Oooeerrr....I am down the road in Richmond (well Ham Common to be precise) so on your timezone and tuned in for the next chapter. Great story Mark so far.
    I also know Macari's well. Top shop and well chosen.
    Darren
  2. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    #252 275GTB, Apr 21, 2011
    Good Evening, this is my favorite part of the restoration so far, it is the giant leap where we make a significant change to the car forever, where we give it life for the next 50 years.
    For me it is also the time where we see the true craftsmanship of the the restorer, everything that has happened so far on the job could have been achieved by an amateur DIY restorer, here we take it to a new level - only a true artisan would dream of doing this to such a magnificent machine.
    Joe Macari I have a lot of faith in you and your team, but even my jaw dropped at the next one!
    Drum roll.................pictures 1) before, 2) during & 3) after.........
  3. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    In the above picture you can see we have completely removed the offending rear section, it has been done in such a way to preserve as much of the original metal as possible - mainly the boot floor. I am also very fortunate that all the structure is in great shape and avoided any impact damage over the years.
    The left corner has only been cut off a fraction, the right has lost a much larger area, but this had to be done to get to good metal.
    Also if you look into the boot area you can see light thought the corners of the wheel archers where the metal perforated by rust (earlier pictures) has been removed.
  4. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    #254 275GTB, Apr 21, 2011
  5. Hawkeye
    Hawkeye F1 Veteran
    8,177
    That is impressive to say the least, great work!
  6. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    #256 275GTB, Apr 21, 2011
  7. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    In the above picture, again we have had to remove a great chunk of the offending nose cone and wing before getting to good metal.
    Once more I am hugely fortunate, in that the inner wings and structural metal work is in fantastic order and again seems to have survived the test of time without any impact damage or rust.
    If you look at the baulk head, you can see that the rotten metal that used to form the battery tray (earlier pictures) has already been removed and replaced. On the opposite side you can see the area where the brake fluid reservoir and servo used to sit, has been cut out and awaits its new metal.
  8. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    #258 275GTB, Apr 21, 2011
  9. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    Above a nice picture of the already repaired battery tray area.
    I love the way the guys have no reservation about cutting large areas of metal out!
    The way the channel that runs around the engine compartment where the hood sits - just stops!
    The way the windscreen surround is retained although only about 1 inch wide in places, it continues on round to retain the perfect shape!
    Just stunning work - thank you Joe and team!
  10. stevenwk
    stevenwk F1 Veteran
    Apr 12, 2007
    5,517
    Metro Detroit/Encino
    Steven
    Fantastic!!
    Again, thanks for sharing.
  11. alberto
    alberto Formula 3
    Aug 25, 2001
    2,404
    San Diego
    Alberto
    In putting this metal back in place, is it all done to a pattern or simply by eye?
  12. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    Hi Alberto, the areas of replacement metal will all be reformed on a buck of the 275GTB as per original. The craftsmen will make them slightly oversized for the area - i.e. so they have a small overlap. They will then trim them to fit the space exactly - resulting in an absolutely perfect fit. All done by hand and eye, along with 40 years experience - some of the guys worked on the cars of this era originally.
  13. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    #263 275GTB, Apr 22, 2011
  14. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    #264 275GTB, Apr 22, 2011
  15. Sig. Roma
    Sig. Roma Formula 3
    Mar 11, 2007
    1,106
    Bella Italia
    Dom T.
    Fantastico !! Job well done. Complimenti per gl'artisti !!!
  16. gilach
    gilach Rookie
    Nov 23, 2009
    6
    So i just figured it out. your car is a mule. the actual purchase price is inconsequential. I suspect that all that 'filler' is either cocaine or heroine. save it. chuck it in a tub and process it, i can hook you up with an afghani friend, and you will be ahead. bob's your uncle, and fanny's your aunt...as it were. keep searching, likely more contraband = more money.
    best, Paul.
  17. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    damn! i have ben rumbled! The car certainly gives you a few "uppers" and "downers".
  18. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    #268 275GTB, Apr 23, 2011
    Morning, hope everyone is having a fantastic Easter weekend.
    Here are a couple of shots of the perforated areas in the wheel arches getting cut out (pictures of the rust on an page 10 earlier).
    First picture is the front wheel arch, second the rear - similar job done on both sides of the car.......
  19. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    #269 275GTB, Apr 23, 2011
    Making progress with the new metal!
    on page 5 of the restoration thread we had the before, during and after pictures of the boot lid - we concluded that the skin had to be remade and the frame re-skinned.
    This picture shows the freshly fabricated boot skin. A few things to point out here, you can still see the pressing tool sitting in front of the new skin, that makes the indentation for the boot lock button recess.
    Also below the workbench you can see the old cut off tail section.
    The second picture shows the old boot lid skin leaning against the workshop wall.
  20. 275gtb6c
    275gtb6c Formula 3
    1,942
    europe
    oscar
    Hi Mark, once again great thread!
    Regarding the boot lid, did you use aluminium for it, as I guess that for the steel cars all the panels are from alloy, or is this only till the lusso? (mine is full alloy so I never actually tested if the steel ones have alloy lids). Those guys are doing a great job!
    Ciao
    Oscar
  21. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    Hi Oscar, Thanks.
    I know the engine lid is certainly made of aluminum, i think the boot lid is but i will have to check, with the car in Italy at the moment I don't get to see or touch it very much at the moment.
    Cheers
    Mark
  22. readplays
    readplays F1 Rookie
    Aug 22, 2008
    2,614
    New York City
    Dave Powers
    Hi Oscar,
    AFAIK, all 275 (okay, I really only 'know' about 4 cams- but then 2 cams would logically follow) had alloy/aluminum hoods, trunks (f+r bonnets), and doors.
    That's my understanding and your question gave me the chance to state it as 'fact' in front of the experts here to see if that actually was the case.
    Hi Mark,
    Thanks for keeping the great posts coming on this fantastic thread! Congrats to you on such a wonderful project and I'm glad you found Macari- someone who is doing wonderful work to such a high standard.
    Best/Cheers!,
    Dave
  23. Ryan S.
    Ryan S. Two Time F1 World Champ
    28,869
    Whats going to happen to some of the scrap parts? The old lid may be kind of cool on a wall.
  24. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    Many thanks Dave glad you are enjoying it. When Joe and myself first discussed the project, we had one aim - to do the perfect restoration, the way it should be done, with no corners cut - everything to the highest standard available anywhere in the world.
    cheers Mark
  25. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,967
    London
    Mark McCracken
    Hi Ryan, I am keeping all the old part the are removed, they will all stay with the car. I was thinking of getting the old nose cone painted in a clear lacquer (to stop surface rust) and have it mounted on my garage wall.
    Cheers Mark
