The sound of 360 | Page 2 | FerrariChat
The sound of 360
Discussion in '360/430' started by Jompen, Jul 3, 2006.
  1. JOEL D.
    JOEL D. Karting
    Nov 2, 2003
    222
    Boston, MA
    Joel DeLuca
    Well I tried it and..... was a little disappointed when I took the car for a ride. When I got back, I had someone drive and I followed and what a difference!!! Car growls at low rpm's and screams at anything over 4000rpm's. Should I be waiting for the engine light to come on?
  2. MufflerMan
    MufflerMan Formula 3
    Jun 12, 2005
    1,564
    Sacramento Ca
    Colby Sandman
    You should have no issues with engine lights. There isn't anything monitered by the computer after the rearmost 02 sensors in the rear cats.
  3. tdb
    tdb Karting
    Apr 6, 2007
    120
    Toronto
    TDB
    What a difference :)
    Hey if the choice was spend $6K for a Tubi exhaust or go with this route - I like to keep green in my pocket. The car sounds great.
    Few words of caution.
    #1. To reach into the driver side unit - you either better have very small hands. Very difficult to wrap your hand around all the assemblies.
    #2. Don't - I repeat Don't - place any type of tools on top of the engine while performing this act. I accidently dropped a roll of electrical tape into the engine compartment. Landed on the diff and then eventually dropped into the under tray of the car. Took me 2 hours to snake that roll of tape out.
    Other than that - the baby growls !
    One happy F-Chatter.
  4. dwe8922
    dwe8922 Formula Junior
    Feb 27, 2004
    403
    FL
    David
    I just did the mod myself, and it sounds great, idling it in the garage. Can't wait to get it out and drive it!
  5. tdb
    tdb Karting
    Apr 6, 2007
    120
    Toronto
    TDB
    Some of you have mentioned you hard wired a switch to turn the by-pass on and off.
    Can you share the makeup of the system you put together. I would like to put the switch in the cockpit.
    Thanks in advance.
  6. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    http://www.capristo.de/ go to Exhaust Systems, Wireless Remote Control.
  7. Capristo Exhaust
    Dec 20, 2007
    152
    Sundern/Germany
    Hello Thread, we have a super new exhaust system that enables a change from sound 1 to sound 3. This sounds great!!! Due to sales of over 10,000 we have for the month of May only a `Jubilee Offer`. We are offering the exhaust system with valve at the same price of one without valve. The remote control will be sold free of charge. Any further questions please contact your dealer or myself at [email protected]. Regards ... Sharon Röttger
  8. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    Do you know the sound level of a Challenge Stradale from 50 feet (15 m) with the remote system installed? If it helps my car get under 92 db, I'll get one!
  9. alcatraz
    alcatraz Karting
    May 18, 2007
    87
    Austin and SF
    Ryan
    #34 alcatraz, Jun 29, 2008
    Anybody put the Capristo wireless switch into an F430 Spider? I am interested to hear results and what it cost for parts and installation. Thanks!
    Please post or PM me with any info...thanks!
  10. utah997
    utah997 Formula Junior
    Apr 24, 2007
    399
    Utah
    Doug
    Just did this last night on my '00 Modena
    The only tricky part was the drivers side, it's a little tight. The electrical connectors have little metal "Horseshoe" pins that you need to slide off before dicsonnecting it. Since I have the challenge grill on the back, I just put my light down inside by the taillight (inside) and I could then look through the grill from the back and guide in a screwdriver to pop off the metal pin. Then it's easy to pull the connector off.
    I'm suprised there aren't more comments on this easy inexpensive mod. I personally think it made the 360 come alive... sounds 100% better~!
  11. utah997
    Apr 24, 2007
    399
    Utah
    Doug
    Has no one else done this??
  12. csteve
    csteve Karting
    May 6, 2006
    172
    hong kong
    steve chang
    Anyone has sound clip with stock exhaust sound with with un-plugging the connector (so valves can be opened at all time)?
    steve
  13. Victor Li
    Victor Li Karting
    Sep 1, 2008
    74
    Hong Kong
    Hi Guys,
    Thanks for the intruction to unplug the valve for the stock exhaust. I did it last night and have a test ride. It is must better than plugged before. But I think it still cannot compare with the F360 which installed with aftermarket exhaust e.g. Tubi / Capristo.
    But when I unplug the switch and startup the engine, the screen shows that my engine cover is not covered well even I have done it. So I am not sure if this warning light will still on and also if this will affect the car ECU. Anyway, I've tried to turn off the battery for a while and restart the engine again. The warning light is gone.
    So is it normal for unplugging the valve for exhaust? I guess it is not harmful.
  14. zippyslug31
    zippyslug31 Formula 3
    Sep 28, 2007
    2,075
    PDX
    Kevin M.
    #39 zippyslug31, Dec 8, 2008
    I've been meaning to ask... what is THIS thing? Looks like an open vacuum contraption or something. Noticed it on my 360 too, but my vacuum lines have been capped so I don't believe it's part of the exhaust valve.
    Anybody?
  15. jjsaustin
    jjsaustin Formula Junior
    May 11, 2008
    579
    Austin, TX
    Jim
    Any know the answer to the question above??
  16. ANGELINO
    ANGELINO Karting
    Feb 18, 2009
    62
    Can you do this on 430's
  17. Matt Andrews
    Matt Andrews Formula Junior
    Dec 31, 2006
    515
    Newport Beach, CA
    So early in this thread, it said the Tubi does not use such valves. is this the case? because my factory installed Tubi sounds noticably louder at higher RPM. And I'd like to replicate it at lower rpm with no load.
  18. cookdesk
    cookdesk Karting
    Oct 17, 2006
    59
    Hi
    Is this the euro model or export model ?
  19. CarloR
    CarloR Formula Junior
    Sponsor
    Dec 13, 2006
    435
    9219 Mira Este Court, San Diego CA 92126
    Carlo Rubio
    We had it mounted on a US version 360 with catalytic converters.
  20. Rytt
    Rytt Karting
    130
    I-town
    Badda-Boom
    tubi is for *******, you want capristo level 3 twin sound (louder than level 3) or titanium exhaust
  21. fc2
    fc2 F1 Veteran
    Nov 2, 2006
    5,263
    Silicon Valley Ca.
    Frank C.
    Depends on the type of sound you want.
    I had a Stage II Tubi on my 360 which sounded perfect. Not too loud (which is what a Cap level 3 is to most people) and had the right growl.
    What type of exhaust do you have on your Ferrari, I wonder...
  22. F360_Spider
    F360_Spider Karting
    Mar 7, 2011
    180
    GREAT WRITE UP!!
    i have just done this and it sounds amazing :)
  23. ttforcefed
    ttforcefed F1 World Champ
    19,269
    id go with the CS exhaust or a tubi...360s with tubi sound great and a CS is heavenly
  24. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,456
    Dublin, Ireland
    Greg
  25. JuniorGTR
    JuniorGTR Karting
    Mar 6, 2005
    205
    NJ
    Jr
    I have a NGT on my car. It sounds absolutely menacing at 7k+, but it also sounds like I am going 100mph during cold idles in the AM. Neighbors love me for it.
    Jr
