The squeaky wheel--does it need oil? | FerrariChat
Discussion in '308/328' started by JoeZaff, Apr 17, 2009.
  1. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    Took my Mondial for a drive today and noticed a pretty bad squeaking sound from just behind the steering wheel. It is a lower pitched squeak, and its pretty loud. It only occurs in the first 45 degrees of rotation. At first I thought the plastic cover was rubbing, but I have ruled that out. Unlike the higher pitched squeak I occasionally get from just behind the wheel in really cold weather, this one is not weather dependent. I am reluctant to keep driving it until I know what is going on because its not a very pleasant sound and would rather not destroy an otherwise sound steering rack. My options are (1) take off the cover and start going to work or (2) taking it to Algar Ferrari and letting them figure it out. I have no problem getting my hands dirty, but have no interest in taking the column cover off, only to find out there is nothing I can do with a set of hand tools and the suggested grease or oil to correctly address the problem.
    Any thoughts?
  2. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    Ok, I took the cover off and the sound is coming from right behind the Steering wheel hub and inside the Commutator housing. Its sounds like something rubbing together--sort of like a door squeking. The steering column is dry and I don't see any signs of leaking. The sound has a rubbing sound to it, like two things scraping together. It started without warning, which leads me to believe something has come loose within the housing, rather than a lack of lubricant or something, which I would imagine would start small and get louder. It also begins occurs before enough steering is induced to even activate the lower shaft. Another words, I don't have to put any stress on the rack whatsoever for the sound to occur.
  3. jgoodman
    jgoodman F1 Rookie
    3,260
    Central PA
    Jay Goodman
    Jooe, did you ever figure out what that sound was? How did you fix it?
  4. efinn
    efinn Rookie
    May 25, 2010
    42
    Stamping Ground, KY
    Eric
    Joe: When I 1st got our Mondial home, I noticed a terrible squeak from the area of the steering wheel. I unlocked the tilt and raised it a 1/4 inch or so, squeak was totally gone. Just a thought for you to look at.
  5. viper_driver
    viper_driver Formula Junior
    Jan 1, 2009
    978
    Vegas
    Jason
    I drove my car once with the tilt bolts both loosened. Scary. If the tilt is all the way down the steering joint can catch on the mount and keep the wheel from turning....made for some interesting driving til I figured out what was happening and why I couldn't turn. I suppose it could cause a squeak as well.
  6. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    #6 JoeZaff, Aug 29, 2010
    Yes. Funny story. From what I recall our mechanic was on vacation at the time so I called Algar Ferrari, who wanted to take my entire steering column apart to "find" the source of the squeak (estimated labor 5 hours). I thought that sounded silly since I knew exactly where the sound was coming from, but they flatly ignored me. So I waited until our mechanic returned from vacation. When i called him he told me to drive by and he could fix the problem in 5 minutes. When I got there he was waiting with a Qtip filled with some kind of grease (I forget the type now), which he put right behind the wheel as I turned the wheel side to side (on a lift of course). Over a year and almost 4.5K miles later, the problem never returned.
    I heart Mike Pechstein (Jay and my mechanic)
  7. 4right
    4right F1 Rookie
    So did the squeak come back or is there now a second squeak, I thought that you said that it just started yesterday.
    I am experiencing something similar and would be interested in the solution.
  8. 4right
    4right F1 Rookie
    Nevermind, just noticed the date of the original post.
    Would still be interested in where the grease was applied though.
  9. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    I wish I remembered. My gut tells me that it right behind the steering wheel hub. I will call him on Monday and ask him.
  10. ClydeM
    ClydeM F1 World Champ
    11,645
    Wayne, NJ
    Clyde E. McMurdy
    There's probably a more recent thread - but search didn't bring it up, so.....
    I've suffered through a slight squeak for quite some time. like leather with new shoes. Well, about a month ago it got significantly worse. Louder and more frequent.
    Today I shot a little WD40-Dry Lubricant behind the wheel, through the washer stalk hole in the column. I didn't go crazy - just a couple short bursts.
    Voila!
    No more Squeak! It's the little things in life that make you smile. Life is good.
