The supercharger build has started. | Page 3 | FerrariChat
Discussion in '308/328' started by Todd308TR, Oct 15, 2014.
  1. Todd308TR
    Todd308TR F1 World Champ
    Nov 25, 2010
    11,074
    LA
    Todd
    Wade has been on a vacation.
  2. 308nut
    308nut Formula 3 Lifetime Rossa Owner
    Jul 22, 2002
    1,881
    NOLA/Covington
    Wade
    Im back, will get some updates to you shortly
  3. Todd308TR
    Nov 25, 2010
    11,074
    LA
    Todd
  4. Todd308TR
    Nov 25, 2010
    11,074
    LA
    Todd
  5. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Ooooh nice!
  6. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Looks pretty cool. Double check the length of those wheel locating pins. Too long and they will punch thru the wheel. Don't ask how I figured this out.
  7. 308nut
    Jul 22, 2002
    1,881
    NOLA/Covington
    Wade
    made me go check them, LOL have 10mm of clearance we good
    Wade
  8. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Never hurts to be sure. Sorry I caused undo concern.
  9. Todd308TR
    Nov 25, 2010
    11,074
    LA
    Todd
  10. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Looking awesome. .
  11. snowsports1
    snowsports1 Formula Junior
    Jan 31, 2013
    918
    Brian
    How are you doing the hand brake?
  12. Todd308TR
    Nov 25, 2010
    11,074
    LA
    Todd
    Rear calipers are stock.
  13. Todd308TR
    Nov 25, 2010
    11,074
    LA
    Todd
    The supercharger build is over due to a seller that wasn't honest about how much machine work was left. The seller was not Mark.
    I'm buying a plenum and intake from a junk dealer to modify for fuel injection, all original parts will be saved.
  14. Todd308TR
    Nov 25, 2010
    11,074
    LA
    Todd
  15. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Sorry to hear about the SC let down. It did look pretty cool in your mockup pictures. It looks finished in the pics. Curious what was needed to be done. Regardless the engine looks awesome!
  16. Todd308TR
    Nov 25, 2010
    11,074
    LA
    Todd
    Didn't get into the details, bottom line was more money and time and I want the car in Italy in May. I guess I'll just have to settle for my 1,000 horse power Testarossa.
  17. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Poor you haha!
  18. Todd308TR
    Nov 25, 2010
    11,074
    LA
    Todd
    Engine back in, rear heat shield cleaned up. Wade is currently looking for injectors that will flow the right amount and take the least amount of machining; remember we are using take off parts for machining, all original parts are being stored.
  19. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    If this helps, on my QV, I'm running 19lbs injectors designed for a Ford 302 HO Windsor engine.
    When I install the supercharger, I will replace them with 30lbs injectors. (Supercharger will be "geared" for 2 BAR pressure and 360 HP.)
  20. Todd308TR
    Nov 25, 2010
    11,074
    LA
    Todd
    What SC kit are you using?
  21. omgcars
    omgcars Rookie
    Mar 12, 2015
    10
    Boston
    how much does the body weight?
  22. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Kit from 928 Motorsports. Purchased it Dec 2014. I will start to conversion later this month after I do a belt / tensioner service. Installation looks straight forward. I figure there will be about $1000 in parts/ machining over and above the cost of the kit (new injectors, 2-bar MAP sensor, pressure gauge, drill stock damper, misc. "stuff", as well as, some dyno time for final tuning).
  23. Todd308TR
    Nov 25, 2010
    11,074
    LA
    Todd
    What body?
  24. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,194
    Kingsport, TN
    Lawrence A. Coppari
    I assume you will be installing a intercooler as well. When you compress 70 F air at 1 atmosphere to 2 bars absolute, you are talking about 70 degree F air ramping up to 185 F. My SC AMG Mercedes has that pressure rise and has an intercooler.
  25. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Initially, no intercooler. I'm only going to 7lbs pressure, so an intercooler not needed. Plus, my car has dual oil coolers mounted up front and a 3qt Accusump - engine has always run cool, even on the track. (But I do have an intercooler on the shelf for future consideration).
    One step at a time.
