The Testarossa heater thread! | Page 2 | FerrariChat
Discussion in 'Boxers/TR/M' started by uzz32soarer, Sep 10, 2008.
  1. uzz32soarer
    uzz32soarer F1 Rookie
    Sep 9, 2006
    3,090
    Melbourne, Australia
    Robert Hayden
    Well I learnt a few new things today. I have manufactured a new passenger side air deflector and today fitted it to the heater. With both motors off I needed to know which set of wires was left and which were right so I hooked them up and watched the flap motors work.
    Quite interesting that the flap motors have no limit switch on them. I mean, you push the rocker switch and watch the LEDs move one way or the other, but when you actualy do this and watch the flap, it gets a lot of force applied to it from the motor. The two halves of the vent are like a clamshell in configuration, held together by a few drops of some sort of glue. Not very strong. The flap motor actually pushes so hard on thes two shells that on a stock heater box, the floor vents actually can crack apart just from the pressure applied by the rotating steel flap.
    Makes me wonder if this is why so many TR's have either broken or missing floor vents with the flaps simply spinning in mid air.
    I'll post up some images of the passenger side vent that I manufactured before fitting it into the car. Today was another day spent with fibreglass but much more difficult as I'm trying to fabricate the drivers side floor vent from the images posted by Shamile.
    Stay tuned!
  2. uzz32soarer
    Sep 9, 2006
    3,090
    Robert Hayden
    #27 uzz32soarer, Oct 19, 2008
    Here's the passenger side vent.
    I got some kids putty from the toy shop and made a two part mould then used fibreglass with liberal amounts of resin to create this shape. Then out with the dremel for some very carefull grinding to get the shape right. Worked out pretty well but too time intensive. But now at least both cars have perfect passenger side floor vents with fully operational flaps.
  3. uzz32soarer
    Sep 9, 2006
    3,090
    Robert Hayden
    #28 uzz32soarer, Oct 19, 2008
    Next it was on to the drivers side. Thanks to Shamille I had a bit of an idea of what it was supposed to look like, but it appears that there are very few drivers side vents that are actually intact, or if they are, nobody could send me an image of an intact unit to study.
    Here's where the vent needs to fit:
  4. uzz32soarer
    Sep 9, 2006
    3,090
    Robert Hayden
    #29 uzz32soarer, Oct 19, 2008
    As can be seen, there is very little room to fit the vent in and it's a totally different shape to the passenger side.
    I started out with some solid foam block that I got from a florist. I shaped this to fit into the base of the vent which actually attaches to the heater box and holds the motor. This is the part that we all should have and it will be pretty much intact.
    After shaping the foam to the required shape I started to lay up the fibreglass over it. Once I had a couple of good solid layers then I removed the foam and did the same thing on the inside. After each layer dried I got the grinder out and redid the shape to keep it flat and to maintain the correct size. It's a right PITA, but I had no other way to do it. The garage is full of fibregalss grinding dust as it creates a right bloody mess everywhere.
    Finally I was pretty happy with the shape and it was then out with the dremel and hand cut the grooves to the inside so it fitted together with the existing part as they overlap each other along the join line. This was probably the hardest part as both sides needed to be perfectly parallel and if you cut too far, you had to go back and build it up again, then wait till that dried, then do it again...and again............aaaggghhhh!!!!!!
    So it took two days to make the first vent but as can be seen, it fits very well to the original heater part and the flap opens and closes fully. All in all a good result. Just needs a coat of black paint to make it look 'factory' and put it into the car.
    Now I just have to make another one for the other car!! Shhheeeess!!
  5. uzz32soarer
    Sep 9, 2006
    3,090
    Robert Hayden
    #30 uzz32soarer, Oct 19, 2008
    It was really difficult to make the first one of these vents. Mostly to maintain a squareness as the fibreglass shrinks and moves a lot as the additional layers are added to make the required thickness.
    One morning whilst sitting having breakfast and reading the drivel on the cereal box, I had an idea. After tossing the cornflake (minus box) back into the pantry, I headed for the garage with cornflack box in hand. I cut up the box to the required shape and used the foam just to maintain some solidity for the first coat. Then I layed two layers over the light cardboard cereal box, letting the resin soak fully into the material and the cardboard.
    Once this went off, I repeated the same on the flip side until the thickness was attained. Then I went to work with the dremel tool to create the grooves and fine shape. Then to perfect the whole thing I used some fibreglass reinforced automotive filler (bog) and laid a fine layer over inner out outer. Once sanded back, this gave a really great result, very square edged and an even better fit that the first one.
    So now put away in the cupboard are a spare fibreglass floor vent for both drivers and passenger sides and a full set are now fitted into my car and operating perfectly.
  6. curtisc63
    curtisc63 Formula 3
    Dec 13, 2005
    2,290
    Maryland
    Curtis Campbell
    Awesome work Robert. Thanks for sharing your project with us.
    Curtis
  7. Beta Scorpion
    Beta Scorpion Formula 3
    Jun 22, 2006
    1,379
    Fantastic work on those ducts!!
  8. Testarossa Lover
    Testarossa Lover F1 Rookie
    Dec 31, 2006
    3,622
    Newport Beach, CA
    Haig Barsamian
    Can anyone help me with this?
    While I was driving A/C was working great and suddenly the FAN stopped. I changed the AC relay on the main Board and nothing happened. A week later I was driving around tried switching the A/C on and off and still no Fan. After driving for an hours, I pushed the On switch and Fan and cool air came on and stayed on all the way home about 40 min.
    This week and started the car and tried to turn A/C on and we are back to the old thing NO FAN. I own a 1990 TR. Can anyone help?
  9. Steve Magnusson
    26,933
    #34 Steve Magnusson, Apr 19, 2009
    Unplug the "k" white connector at the bottom of your fuse-relay panel -- if the terminal with the M (brown) wires looks like this photo you've found the problem (this terminal supplies the +12V power to run the whole TR AC system) -- very common for this to be "intermittent" when it starts getting really bad:
  10. kerrywittig
    kerrywittig Formula 3
    1,668
    Ithaca, New York
    Kerry David Wittig
    In a word concerning the duct fabrication......WOW!
    Very impressive, very very impresive.
  11. gbi162
    gbi162 Rookie
    Jul 10, 2014
    39
    Macon, GA
    Mike Hemstreet
    Yeah this 1988 Testarossa I just got a few weeks ago has a heater issue, everything works great but I did notice that the heater inside the car will only work at idle once you are on the highway it will only blow cold air? But when you come to a stop or slow way down like in a parking lot it will start blowing hot air again? Anybody have any ideas?
  12. OptimusPrime
    OptimusPrime Formula Junior
    May 10, 2011
    291
    Florida
    Tom
    Just a thought, make sure that you check to see that all air is blead out of the coolant system as strange things happen with this car when there is an air pocket. I had some trouble with bleading mine the first time and the car got too hot and the heater did not work.
    Tom
  13. Santino1
    Santino1 Karting
    Jun 4, 2014
    101
    Sacramento, CA
    Daniel
    Since this is a heater thread, I'm in the process to replace the (2) 5/8 heater core hoses that run down the center of the car. I'm in the middle of a major, engine out, have done a bunch of work on the coolant system. Recore radiators, new fans, DH hose kit. During the course of all this, close inspection of the heater core hoses, they were breaking apart internally. Question, does the HVAC assembly need to come out up front to access the hose clamps for the hoses, looks to be a major pain, any help would be appreciated.
  14. Steve Magnusson
    26,933
    I don't believe so as the hose connections are more up in the RH footwell -- but it is a huge job/pain! Make sure that you keep the flow direction correct -- the valve is designed to seal properly only when the hoses are connected with the correct "polarity" (I spent a year thinking my hot water valve wasn't working right when, in fact, the shop that did my last major got the hoses switched around -- the symptom was/is the heater seems to always be "on").
    peteficarra likes this.
  15. UpNorth
    UpNorth Formula 3
    Sep 30, 2006
    1,769
    Quebec, Canada
    Francois
    +1
  16. evolutzione
    evolutzione Rookie
    Sep 27, 2014
    2
    Finland
    Mika Raudasoja
    Hello Steve..
    I have Testarossa 1988... one relay is missing on the heater.. Its this timer relay.
    Is that important relay?? and what doest it do?? I buy this car last year and
    the relay was already away.My english is not good..
  17. Aki ellahi
    Aki ellahi Rookie
    Sep 16, 2017
    1
    Aki ellahi
    Great ideas !
  18. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,283
    Mel
    Any help ?
  19. ago car nut
    ago car nut F1 Veteran
    5,523
    Madison Ohio
    David A.
    The heater water valve is under the removal metal foot panel on the passenger side. Lift carpet at food well, Four screws and remove. Then check hoses.
