The Ultimate 360/430 iPhone mount solution!!! | FerrariChat
Discussion in '360/430' started by Djack005, Dec 5, 2024.
  1. Djack005
    Djack005 Karting
    64
    Dave Jackson
    #1 Djack005, Dec 5, 2024
    I believe I have come up with the perfect iphone/stereo upgrade solution for my 360. Should work on the 430 as well.
    I 3D printed a replacement for the center AC vent and incorporated a MagSafe charger. I am very proud of how it came out. If anyone is interested in the .stl file for the mount, let me know. I'm happy to share
    Basically, I made a replica of the AC vent with a threaded socket to mount an ESR MagSafe charger.
    https://www.amazon.com/gp/product/B08HNBHSQV/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
    the notch on the bottom rim is to allow the USB cable to pass through
    I used a 12 volt to USB converter and wired the charger into the switched power supply for the stereo
    https://www.amazon.com/dp/B08RBWX2GL?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
    Came out better than I expected. Works flawlessly, holds a phone very securely in either landscape or portrait position and keeps the phone charged. The vent is very easy to remove and this mod did not require any irreversible modifications to the car whatsoever.
    If anybody is interested in this mount, let me know. I will be happy to provide the STL file
    3773680[/ATTACH]
  2. MaranelloMark
    MaranelloMark Formula Junior
    437
    Bay Area, CA
    Very cool! Nice job!
  3. Jaymac
    Jaymac Formula Junior
    970
    New Hampshire
    Jeremy McCurdy
    Very cool indeed! If you have free time on your hands, you should market and offer them for sale! May be a niche market, but that could be adaptable to many models across the lineup and would be a good option for people who don’t want to use an aftermarket head unit!
    Good job
  4. Djack005
    Djack005 Karting
    64
    Dave Jackson
    Maybe I will. Do you know how many other models use this type of round vent? I think it's quite a few from this era
  5. 430nof
    430nof Rookie
    Sep 9, 2024
    25
    IG @Queuedcars
    Ed
    I’d buy one (assuming it would fit a scud)!
  6. Djack005
    Djack005 Karting
    64
    Dave Jackson
    I think it would probably fit a 430 just fine. Here is the picture of the 430 vent. The front is a little different, but the changes just look cosmetic. The rest of the housing is exactly the same. If you can confirm that it will fit, I will be happy to make you one
    430nof likes this.
  7. 430nof
    430nof Rookie
    Sep 9, 2024
    25
    IG @Queuedcars
    Ed
    Thanks! Maybe someone can chime in before you send one my way
  8. 67bmer
    67bmer F1 Rookie
    2,954
    MD
    IMHO, Blaupunkt has always made some best looking radios for European cars, but I have had the worst luck with their reliability.
    I got so fed up I contacted them about a failure, and they claimed it was from getting "coca-cola" spilled on the unit. From the guy with celiacs disease that never buys fast food or eats food in the car! There was 0% that unit had coca-cola or any other soda spilled on it.
  9. Jaymac
    970
    New Hampshire
    Jeremy McCurdy
    430 and 360 are compatible. You can type the part number into any parts supplier and it will have a “this part fits” list. Chances are it will fit many. I believe even the Enzo uses them, as well as the 550/75/99… Just different ring colors and external vent designs. But the internals are the same
    430nof likes this.
  10. 430nof
    430nof Rookie
    Sep 9, 2024
    25
    IG @Queuedcars
    Ed
    Happy to test it on a Scud! I just want the phone mount magnetic part - don’t care at all about integrating charging
  11. Djack005
    Djack005 Karting
    64
    Dave Jackson
    you got it. Since you're the first to try it in a 430 this one will be on me. You can just pay me for shipping and the cost of the magsafe mount. I just ask that you post pics and a review here when you get it installed. PM me and we'll set it up
    430nof likes this.
  12. Djack005
    Djack005 Karting
    64
    Dave Jackson
    Thanks @Jaymac
    maybe I can go into business.
    Jaymac likes this.
  13. Djack005
    Djack005 Karting
    64
    Dave Jackson
    Mine has been great so far. It is really hard to find something that comes close to matching the color and does not look like it belongs in 98 Civic.
  14. vr4henry
    vr4henry Karting
    Jan 21, 2019
    120
    Henry
    if you wanted to fit a threaded bolt on your mount using one of these would be awesome - they're waaaay stronger than the ESR ones in my experience.
    https://www.shopmoment.com/products/multi-thread-mount-for-magsafe-1
  15. Djack005
    Djack005 Karting
    64
    Dave Jackson
    Thanks for the suggestion, that mount looks pretty cool.
    Doesn’t have an option for charging though.
    The ESR mounts seem to work quite well in this application. At least for me, I’ve never had the phone come loose. I also use an ESR branded case, which might help.
    It would certainly be very easy to incorporate that style amount into this build. I’d be happy to make one like that if somebody’s interested, but I think the ESR amount works perfectly and it’s nice to have the option of charging the phone.
    Dave
  16. vr4henry
    vr4henry Karting
    Jan 21, 2019
    120
    Henry
    Ah, the case + mount combo likely helps a lot.
    Very cool solution! I would absolutely try one but I’m back to just leaving phone in side pocket after installing the Power Acoustiks CarPlay head unit.
  17. Djack005
    Djack005 Karting
    64
    Dave Jackson
    The power acoustiks head unit was what got me started on this project. I installed one and it worked great, but I found myself taking my eyes off the road too much. It was hard for me to see due to the location low on the dash and the glare with the top down. Plus. I missed the volume knob/buttons, etc. Ultimately, this was a better solution for me.
    The mount pairs really well with the Blaupunkt Skagen head unit which looks old school but has bluetooth, built in mic and multiple LED colors that come really close to matching the rest of the dash. It even has a "Siri" button. I usually run waze on my phone, which, when placed in the mount is closer to eye level and has a nearly 100% success rate at finding speedtraps in my region.
    Jaymac likes this.
  18. ditpixs
    ditpixs Karting
    Apr 22, 2019
    231
    Nor Cal - Tracy
    Aaron
    Jaymac and vr4henry like this.
  19. Djack005
    Djack005 Karting
    64
    Dave Jackson
    Looks awesome, Thanks Aaron
    Dave
    Jaymac likes this.
  20. hessank
    hessank Formula 3
    1,920
    Canada, Florida
    Fred
    They certainly are compatible. I have been using 430s on my car over 5 years now
  21. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner
    Jan 19, 2004
    7,857
    San Jose, California
    This will even fit in an Enzo as they use the same vents.
  22. Driver1234
    Driver1234 Rookie
    Sep 1, 2024
    7
    Tampa FL
    Nice work. Great to see a folks being creative and productive with new ideas. Any other ideas in the pipeline?
  23. Swallowtail
    Swallowtail Rookie
    Dec 7, 2020
    30
    That looks like an awesome solution!
    I'd like to take you up on that offer. Should I send you a DM?
  24. Djack005
    Djack005 Karting
    64
    Dave Jackson
    Thank you for checking out my iPhone mount. I’ve been really flattered by the interest from people in this forum.
    I made a few modifications to the original, and I’ve got it really dialed in. Because of that, I would prefer not to send out the STL file instead, I’m happy to make you one and send it your way.
    Feel free to DM me if you’re interested and I’ll get started on it for you
    Dave
