Thermister location on a 328 | FerrariChat
Discussion in 'Technical Q&A' started by JohnnyS, Nov 27, 2006.
  1. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,284
    Illinois
    Does anyone know where the thermister is located on a 328? My temp. gauge has stopped working and I think it was due to some work on the radiator.
    My manual doesn't give the location and I wanted to check and make sure it didn't get disconnected.
  2. Glassman
    Glassman F1 World Champ
    What in the hell is a Thermister?
  3. JohnnyS
    Oct 19, 2006
    15,284
    Illinois
    It is that thing that senses temperature so the gauge can register temperature. The thermister is more acurate than a thermocouple.
    It should be connected to a point where the coolant temperature should be as representative of the engine temperature. So I would think either at the coolant exit point from the engine or radiator inlet. But I am not sure about these cars.
  4. Glassman
    It sounds to me like you are talking about what I call a "temperature sending unit". That unit on a 308 anyway is on the lower side of the radiator on the passenger side. It has a harness with two wires connecting to it. On my car it is also the only way to drain the radiator.
  5. DGS
    DGS Seven Time F1 World Champ
    73,072
    MidTN
    DGS
    The temperature switch on the radiator controls the electric fans. Another switch on the coolent reservoir (aft) is for the CIS loop control.
    The thermistor that runs the gauge is on the coolent manifold (from the upper water pump pipe) for coolent to the heads that sits under the intake manifold plenum, on top of the engine. The wiring doesn't go anywhere near the radiator.
  6. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Clever!
  7. JohnnyS
    Oct 19, 2006
    15,284
    Illinois
    Thanks, took a look and couldn't see anything obviously disconnected.
    Just got the car back from a major service and while sitting on the highway, I noticed that the temp gauge was not registering any temp. The oil temp was fine.
    I guess it is back to the shop. There was work done on the water pump so something must have happened.
  8. DGS
    73,072
    MidTN
    DGS
    ?? - Wiring diagram and spare parts catalog.
    (And 3-1/2 decades experience with Italian cars ... which is why the first thing I buy after the car is all the manuals I can get. ;))
  9. Glassman
    Well the thermister is a new one on me. Thank god for this informed forum.
  10. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Not discounting your knowledge/experience in anyway...thought you were being clever by your choice of words given the thread topic.
  11. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Proper spelling is thermistor. That's obviously what threw you.
    Thermocouples work well for wide temperature variations, are cheap, but are difficult to calibrate and stay calibrated. They are dissimiliar metals and like a small battery which produces a voltage which varies with temperature.
    Thermistors are temperature sensitive resistors. They have a large output variation for smaller temperature ranges, are exceptionally stable over time and inherently more accurate. But they do require special meter circuitry to avoid car battery voltage variation from affecting the reading.
    Nothing but the best...
  12. DGS
    73,072
    MidTN
    DGS
    Nah -- the temperature switches are off/on switches, and the gauge sender really does show as a thermistor on the wiring diagram.
    One of my ongoing projects (suspended for lack of time now) is a thermistor based aircon thermostat to replace that Coke-machine capillary tube unit. (You have to remove half the interior to replace one of the capillary units.) It uses one unit of a quad op-amp as a constant current source, run across a radio shack thermistor (in parallel with a fixed resistor) to eliminate voltage variations and non-linearity of the thermistor output.
    (The other units scale the output, compare a potentiometer setting, and drive the switching transistors to push the relay. -- The first prototype failed because those Bosch relays pull a heluva lot more current than I expected. I also realized that radio shack (non mil-spec) parts wouldn't last long inside the console, so the electronics have to be relocated to the evaporator -- where Ferrari put the fan speed transistor.)
  13. JohnnyS
    Oct 19, 2006
    15,284
    Illinois
    Okay, thanks for all your comments.
    Called the dealer where the work was done, and they came out with a covered trailer to pick up the car. I was told that the Thermistor is located in a spot that I could not get to. I suspect that with what I just spent on the major, they don't want me to have to fix that.
