did anybody replaced the thermostat body cover with the engine inside? the drainplug ( 10300240 ) is broken and I can not remove the rest from the hole without taking this cover out. it is soooo hard to reach there and the front 2 nuts for removing the cover are not reachable when the complete thermostat housing is inside. any good idea???
already nearly done not such a big deal as I thaught at the beginnig had to drain the coolant out of the 2 radiators to safe the fluid. then I loosen the upper 4 short hoses ( 2 directly at the thermostat housing and the other 2 from the pipes left and right going to the radiators ), unscrew the upper termostat housing from the lower one ( only 2 screws M 6 ) and took the upper housing out. rest of the bleeding screw is drilled out. a larger thread ( M10 x 1,5 ) is in the housing. I will make a 2 piece bleeding screw ( a screw with thread M10 x 1,5, inside a small hole with about 2,5 mm, then the half of the screw inside thread M6 x 1,25 and inside this thread then a normal bleeding screw form a brake caliper ) and hope all will work fine later
Here they are Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
I hate to say it....but I know exactly what that plank is for hahaha. I used a twin mattress, dont tell the wife.
