Thermostat stuck do I need one? | FerrariChat
Discussion in '206/246' started by johnvwatts, Apr 30, 2009.
  1. johnvwatts
    johnvwatts Formula Junior
    Jul 7, 2007
    522
    England
    John v watts
    Just started using the Dino after 6mths of winter storage. Noticed that it seemed to start running hotter than normal and throwing coolant out of the expansion tank. Suspected the usual air locks but bleeding didn't cure the problem. Water was coming to the rad (top pipe hot) but didn't appear to be coming through (bottom hose cold). So suspected a block rad. Fushed rad (which looed pretty new) and water flowed through fine. Next step was to remove the thermostat which was stuck int the closed postion . Car now runs fine. One to watch as it could easily lead to boil over and head gasket failure.
    As I only ever use the car in the summer do I actually need a thermostat as car seems run fine without it? Obviously taked longer to warm up but otherwise fine.
  2. dm_n_stuff
    Dec 10, 2003
    43,661
    26.806311,-81.755805
    Dave M.
    I'll tell you what my mechanic told me some years ago. If it didn't need a thermostat, it wouldn't have one.
    All other BS aside, superformace.co.uk has them for not a whole lot of money. Stick one back in there, and then you'll have no worries.
    Ferrari dealer wants like $80 for one. I had to buy one there in a pinch a few years ago when I was having a similar problem.
    It turned out to be my water pump, BTW.
    DM
  3. ferrari dino
    ferrari dino Karting
    Feb 16, 2006
    180
    Southern California
    John Kennedy
    If there is no thermostat the problem would be that the coolant will pass through the radiator too fast. The cooling system won't be as efficient. The coolant needs time in front of the fans.
  4. Motob
    Motob Formula 3
    Nov 11, 2003
    2,355
    Frederick, Maryland
    Brian Brown
    The thermostat has a block-off plate on the backside, it closes off the bypass passage once the engine is up to operating temperature. If you run with no thermostat, the coolant will take the easier path, recirculating through the engine rather than going through the radiator. You must run a thermostat or block off the bypass passage, or the engine will overheat on a hot day.
  5. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    all of the above AND the car will take much longer to warm up, the longer it runs cold the more engine damage you are doing. Motors are designed to be run at specific temperatures, running cold is not good for the motor.
    Superformance has them cheap and its super easy to change out.
  6. johnvwatts
    Jul 7, 2007
    522
    England
    John v watts
    Ok thanks for the input everyone. Will order one up from superformance and fit it asap!
  7. dm_n_stuff
    Dec 10, 2003
    43,661
    Dave M.
    ATTA GUY!!!
    And now, thanks to the boys, I have a more complete explanation than the one I got from my mechanic all those years ago.
    DM
  8. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Looks like others have had great success with the $15 German Behr T-stat in this post:
    http://www.ferrarichat.com/forum/showpost.php?p=138598112&postcount=65
    The Behr "Made in Germany" thermostat showed up today. Looks exactly right. It's cool, it has a little ball-bearing "valve" in the bleeder hole that will shut off the bleeder when there is flow, but allow you to bleed air when the engine is off. I ordered part number 100 200 07 15 (this is a Mercedes number) from Autohaus Arizona on their website.
    http://www.autohausaz.com/search/product.aspx?sid=gfbbcy55rkxwx3zoaroqzomz&partnumber=100%20200%2007%2015
    There is a 79 degree C and an 87 degree C version. 79 degrees is the standard one.
    (The 87 degree will allow the engine to run hotter, not good for a Ferrari).
    $15.90 for the thermostat and $8.00 shipping. This is a good German thermostat for the price of a cheapo stant, and this seems to be the thermostat that Superformance UK is selling as the replacement thermostat for a 308.
    To summarize this thread, the problem is that the original 308 thermostat manufacturer (Savara) no longer seems to be in business, so to buy an "authentic-looks-just-like-the-one-that-came-with-the-car" thermostat means paying $200+ for an NOS part which is 20+ years old to begin with. My investigation showed that Behr makes most later-model Ferrari thermostats, including 308 replacements. They used to be made by the Behr Italian Division, but they are now available through the German division. There are cross-references to other cars which makes them easier to find. I called Behr and found out the Behr Part number for the 308 thermostat, and it was also used extensively in 1970s Mercedes, which makes it easy to get from Mercedes parts dealer. Voila.
    The thermostat I just got in the mail from Behr is a much better looking piece than the cheapo Stant I bought at NAPA and was no more expensive, so I recommend that you buy the Behr!
    Birdman
  9. johnvwatts
    Jul 7, 2007
    522
    England
    John v watts
    #9 johnvwatts, May 2, 2009
    Hey thanks for that, will try and order this route as I haven't yet phoned superformance. Notice they're in Arizona hopefully they will post to here or might try part no and search in england. If you don't mention Ferrari (I'll just say an old Fiat (100 % correct technically! anyhow )), the price stays low!
