Thin air problem F40 | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by roger_l, Nov 17, 2011.
  1. roger_l
    roger_l F1 Rookie
    Apr 27, 2002
    2,782
    Netherlands /Utrecht
    Roger
    In May this year I drove (as a navigator) the Mille Miglia Tribute with a F40. There were several F40's (including ours) with serious engine problems when driving in the mountains. According to specialists it was a combination of hot petrol and thin air. The engine suddenly starts losing power and eventually stops. After waiting 15 to 30 minutes we were able to restart the engine, drive a couple of minutes, and then the same problem occured. It was definitly a problem related to the mountains/ thin air, as soon as we got lower all problems disapeared. About half of the F40's had these problems, the other half didn't have any problems.
    As we plan to drive the 2012 Tribute again we would like to solve this problem.
    Is anyone familiar with this problem and does anyone have a solution ?
  2. Tomax
    Tomax Karting
    Apr 27, 2004
    217
    This is going to sound very rude and blunt, so also putting here I dont have and have not driven an F40 - but have driven other Ferraris, and have driven problematic overheating turbos.
    If the problem hit half the cars, then yes - it's a common problem, but if it didn't the other half - may be a problem between the footwell and the seat. I find I can drive an automatic Toyota very calmly, but always tempted to walk a Ferrari through any corner, if needed or not because it's just too much fun. Likewise always tempted to walk an R32 Turbo around corners in a close group with other cars.
    Are you guys easing the cars around or walking the cars around corners with both feet. If it's not driving - would go through the same basic checks for a Nissan turbo, that you have clean path from hole in bodywork through intercooler and such. You've not got bent mesh, build up over filters etc. etc. Also would be interesting to look at who was driving with hot-air blown on them by being in a group, and who was easing out of hills and running clean-air space for the intakes.
  3. roger_l
    roger_l F1 Rookie
    Apr 27, 2002
    2,782
    Roger
    Thanks for your reply. To put it short: we were al in a hurry !
    Nevertheless, after leaving Florence, driving in a traffic jam and going up a rather steep road the same problem occured: losing power (cilinders ...? ) and then a total stop of the engine. After several stops (each 1-2 miles) of 10-15 minutes the road descended again, and the problem disappeared.
  4. roger_l
    roger_l F1 Rookie
    Apr 27, 2002
    2,782
    Roger
    Both situations occured, a 'clean' road with no one in front and in a traffic jam
  5. Napolis
    Napolis Three Time F1 World Champ Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    This could also be caused by fuel icing.
    In the mountains even in the summer fuel systems are prone to icing when you move from sea level high temperatures and pressures to mountain low temperatures and pressures.
    I would add a fuel additive that removes condensed water from fuel and see if this helps.
    You might also want to install a cockpit adjustable duct that ducts hot air (Carb Heat) to the fuel injector lines.
    In our P 3/4 (mechanical FI) Ferrari routed the fuel lines inside of the water lines to heat the fuel. Our 166 has cockpit controllable carb heat which makes it work a lot better in the mountains.
  6. ross
    ross Three Time F1 World Champ Owner Silver Subscribed
    Mar 25, 2002
    38,010
    houston/geneva
    Ross
    roger, i was there and sometimes close behind you ;)
    my guess is that something needed servicing on your car. o2 sensor, air filters, gas filters, etc. the altitude difference is one thing, but it should not have stopped your car dead in its tracks. did you talk to the ferrari mechanic who was tagging along?
  7. roger_l
    roger_l F1 Rookie
    Apr 27, 2002
    2,782
    Roger
    Thanks for your advice. Do you know who trades this additive ?
    There's just one problem, to test it we have to go to Italy as there is no thing like 'Dutch mountains'. Holland is as flat as a pancake and most of it even below sealevel ;)
  8. Napolis
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    I'm not sure who sells it in Europe but we found and used it in Italy. A lot of cars in Italy use it because of moisture found in fuel there.
    Basically any fuel stabiliser/octane booster will do as long as it contains "dry gas" which is an alcohol with a free radical that attaches itself to H2O to form burnable fuel.
  9. roger_l
    roger_l F1 Rookie
    Apr 27, 2002
    2,782
    Roger
    Ah ha, you tried to overtake us but didn't succeed ;) I'll see if I have any pictures....
    The Ferrari mechanic just told us it was a problem with hot petrol in combination with thin air, he has not solution (yet).
    Do you drive a standard F40 or are there any mod's made, as I suppose you didn't have any problems ?
  10. roger_l
    roger_l F1 Rookie
    Apr 27, 2002
    2,782
    Roger
    Thanks ! I'll Google on that !
  11. Napolis
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    I think Ross didn't have any problems because when he watched us race the 24 Hours of Nurburgring I saw him filling his water bottle with race fuel and he probably added that to his F40.
  12. Scuderia-San-Antonio
    Scuderia-San-Antonio Formula 3
    Feb 27, 2005
    1,567
    San Antonio
    Wes
    need different Spark plugs...
  13. roger_l
    roger_l F1 Rookie
    Apr 27, 2002
    2,782
    Roger
    Why do you think so ? What kind of spark plugs ?
  14. roger_l
    roger_l F1 Rookie
    Apr 27, 2002
    2,782
    Roger
  15. Scuderia-San-Antonio
    Feb 27, 2005
    1,567
    San Antonio
    Wes
    that's what my car did or at least it sounds like the same thing.
  16. ross
    Mar 25, 2002
    38,010
    houston/geneva
    Ross
    i was in the red w/stripe 360cs with swiss plates. so i did not overtake you ! but i remember your car.
    the de-icing product that jim speaks of is certainly a good idea, but i really doubt that you had icing or condensation in the fuel - we ran hard all day from the flat to the top, and in the run up the mountain the fuel would not have had time to either condense or ice. that kind of event might show itself if you left it outside overnight up there and then started off in the morning, but not in a constant run. it just sounds like you were nto getting enough air into the cylinders, hence my guess that you need to check the 02 sensor, and the air filters.
  17. PAUL. S
    PAUL. S Karting BANNED
    Feb 11, 2011
    121
    A couple of problems that usually occur with Weber IAW equiped cars are easily resolved by either changing the water temp sensor, the map sensor or the crank sensor. Each is only under £50 if you buy direct from a weber dealer rather than ferrari. Its a robust system but as these cars get older the wiring harness at each of the sensor connections can also corrode slightly and send false readings to the ecu, so thats another area worth checking as condensation at higher altitude could be getting onto the wiring points.
  18. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    if carb icing is eliminated as a possible issue, what are the altitudes reached in the mountains ? Engines tuned at sea level will struggle as altitude is gained, especially if running toward the rich side of things at sea level. As the air gets thinner with altitude the fuel mix becomes too rich causing a loss of power as the engine struggles to breathe.
    A retune to the leaner side or rejetting for less fuel flow would go a long way at altitude.
    (think of what happens as the choke is applied). Give up a bit of performance at sea level and get it back at altitude
  19. Napolis
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    "Inhibitors may be added to reduce corrosion and oxidation. Anti-icing additives are also being blended to prevent fuel icing."
  20. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,370
    Only time I saw icing was when I ran 110 octane race gas. No problems with 100 octane at altitude; I live at 5500' and go over the mountain passes at 7500' without any problems, in 95 degree days. Not sure if it matters but my car is tuned at 5200' altitude, and I'm not running stock plugs.
  21. Napolis
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Being tuned at altitude would help. Italian pump fuel is very bad and often contains a lot of water. Regular cars routinely use additives there. We use it in every car we've run in Italy. Jesse's 208 GTB Turbo had issues in the mountians on Italian pump gas before we ran additive.
  22. kverges
    kverges F1 Rookie
    Nov 18, 2003
    3,179
    Dallas
    Keith Verges
    It's not "free radicals" in the anti-icing additives. I am pretty sure the active ingredient is just methanol that forms an azeotrope with liquid water that is miscible with gasoline and allows it to be consumed in combustion.
    As for the tune, any fuel injected car has a barometric sensor that will adjust A/F ratio for reduced air density in the intake manifold, and at cruise the O2 sensors provide feedback to fine tune the mixture.
    I feel confident it is not a tune or design problem. My first guess is a fuel issue like vapor lock (more common with oxygenated/alcohol-rich fuels) or maybe an icing issue, but icing in fuel injected engines is pretty unlikely. Fiel injected aricraft don;t even have the ability to add carburetor heat, bu I check for water in the fuel before every takeoff.
    Check the fuel filters and fuel system. My F40 did the same thing due to deterioration in the rubber fuel system components that clogged the fuel filters; after sitting the debris would settle enough that the car would run for a while, then it would clog again and be most noticeable under hard running and boost, when fuel demands are high.
    If the cars in question have not had their fuel bladders and other soft components and filters replaced in the last 10 years or so, that is one place I'd look for sure.
  23. Napolis
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Ferrari designed in the ability to heat the fuel in the mechanically fuel injected P 3/4 that raced the Targa Florio ( Mountains) and hill climb 206S Dino's.
  24. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    not familiar with the range of adjustment that the sensors allow for changes in altitude, or if the sensors are functioning properly. Fuel / air mix is a function. It is carefully considered by dragsters who adjust for altitude of each track they run in. The check list for possibilities is growing, each item should be examined, like the cliche'... each item may be small or seem insignificant, left unchecked the problem becomes large.
  25. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    makes sense, the volume / density of fuel changes with it's temperature,
