Think I can drop the motor this way on my 348? | FerrariChat
Discussion in '348/355' started by carwhisperer, Dec 11, 2014.
  1. carwhisperer
    carwhisperer Formula Junior
    Sep 29, 2014
    426
    Sacramento, CA
    Brian
    #1 carwhisperer, Dec 11, 2014
    My 348 is in need of a major, which I intend to do myself right after Christmas. I have access to a 2 post lift at the Community College where I teach math. The problem is, however, that I don't want to leave the car there for days while I get parts. If I could anticipate everything I need ahead of time that would be great. But if I don't I'm not too thrilled with the idea of leaving the car there for a few days to a week. Yes I realize I could probably buy a relatively cheap 2 post lift but I really don't want to have it taking up space in my garage.
    Am I correct in saying that the main consideration is safely lifting the car high enough to roll the engine out from under it? I have read a little about the 2 floor jack method, which I might do. But how about this?
    I erect a structure using 4x4's in my garage. I use the rafters to steady, not support the structure. Then I use another 4x4 under the car and lift the back with two strong come alongs. My understanding is that the car weighs about 1500 pounds without the engine/trans assembly. So I would be lifting about 750 pounds with two come alongs. Even if it is closer to 2000 pounds and I'm lifting 1000 with the come alongs I'm sure it would be fine.
    I did something similar when I rebodied a C4 Corvette as a Jeep CJ7 a few years ago. The jeep body was very light, perhaps 300 pounds, but the principal is the same.
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    I hope you have 911 on speed dial :)
  3. Shootfighter65
    Shootfighter65 Formula 3
    May 13, 2014
    1,372
    Charleston SC
    Randy..alluneedtokno
    I want to hear more about the frankinjeep
  4. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,803
    Lake Villa IL
    I would not attempt!
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,651
    San Carlos, CA
    Mitchell Le
    I would go the 2 jack route before I do the 2 come along with 4x4 method. There is nothing wrong with the 2 jack method. I do it all the times with the 911 Porsche
  6. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    A 4x4 structure made of vertical 2x4s? To lift a car? You teach math or maybe comedy routines instead? Otherwise you're just yanking our cranks. ;)
  7. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,269
    Worcester, England
    Phill J
    #7 4rePhill, Dec 11, 2014
  8. jetfuel79
    jetfuel79 Karting
    Apr 19, 2014
    158
    Valdosta, GA
    David
    Sounds like a terrible idea (sorry). Why would you even attempt to save a few dollars on a lift (or leaving your car at a shop) and ghetto-rig something that you know is unsafe? The simple fact that you are uncomfortable enough to ask is probably an answer enough that it's a bad idea.
    a) leave your car at the shop and pay a small fee
    b) buy a lift. I got a MaxJax lift and it takes up minimal space in my garage. The "I don't have room" excuse is hard to make with the MaxJax
    c) use the two jack method as laid out by Earnie
    Creative solutions are always welcome...but your life is worth more than some shop fees.
    On the plus side...congrats on wanting to do the major yourself!
  9. F1moving
    F1moving Formula Junior
    781
    BUCKeYe!
    Marcus
  10. Eric C
    Eric C F1 World Champ
    11,136
    St. Louis, MO
    Eric
    I've seen worse. Go for it.
  11. spdrcr
    spdrcr Formula Junior
    Aug 2, 2004
    318
    San Jose, CA
    Matt
    Well this thread could get interesting ...
  12. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,914
    Richmond
    Pete
    I would go with a portable mid rise that you can move out of the way and store when not needed. I'm torn between a 4 post and one of those, bonus to the portable unit is that you can take it to the track with you (which should come in handy next time we blow a motor 2 hours into a 24 hour race and have to change it).
  13. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    I think your overcomplicating it. I did my major using the 2 jack method with no problem.
  14. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    I make my living doing things differently and creating things that most others don't envision, so I like your outside the box thinking but not sure this is the place to test it.
    By doing the DIY service you are already ahead of the game and picking up a portable maxjax or portable sissor lift still let syou come out money ahead and then have a very usefull tool for your continued automotive projects in 100% safety and efficiency
  15. Brewman
    Brewman Formula Junior
    Apr 3, 2012
    417
    NC Mountains @ Boone
    Joe
    Follow Ernies 2 jack method. It's safe (most important) and surprisingly easy. It took me 8 hours the first time I did it and that's including checking and rechecking each step a couple of times as I went thru the process. The other thing to consider is once you get in there you'll surely find some unplanned things that need attention.
    Brewman
  16. plugzit
    plugzit F1 Veteran
    7,789
    Redondo Beach, CA
    Bruce Bogart
    All of what he said. No time restraints short of a couple of weeks are acceptable.
  17. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    You have balls, I'd never do that. As a side note, I have a 2 post and it is taking time to get comfortable. Having a car 6 feet above your head is a bit nerve racking when you don't do it every day.
  18. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    I agree, I get nervous even in a shop when I walk under a car on a 2 post lift.
    I would have rather used a 2 post lift when I did my engine out. I contemplated buying one although I just couldn't make it fit satisfactory in my garage. Only have 9ft ceilings.
  19. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,053
    Indio Ca/ Alberta
    Grant
    I want to see pics. Maybe you can do a post after called "engine out 4x4 rafter method".
    You can buy those really tall screw jacks and once its up put them underneath at the jacking points. That way your only using the rafters as a temporary crane. Just keep in mind its closer to the 2000 ppound mark.
  20. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    Its not worth dying for........either buy an hoist or use the college hoist
  21. Eric C
    11,136
    St. Louis, MO
    Eric
    #21 Eric C, Dec 12, 2014
  22. driveitdaily
    driveitdaily Formula 3
    Jul 20, 2013
    1,041
    lake ariel pennsylva
    john
    Referring to the title of the thread , i think the key word is " drop " . Somethings going to get dropped , maybe a whole car !
    " serenity now "
  23. plugzit
    plugzit F1 Veteran
    7,789
    Redondo Beach, CA
    Bruce Bogart
    With the two jack method, you never have to be under the car without jackstands or the like as emergency support.
  24. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    #24 SoCal1, Dec 12, 2014
  25. Eric C
    11,136
    St. Louis, MO
    Eric
    Ha! I was waiting for that picture!
