348 - Thinking of taking the plunge 348ts belt advice | FerrariChat
348 Thinking of taking the plunge 348ts belt advice
Discussion in '348/355' started by eddie348, Dec 3, 2024.
  1. eddie348
    eddie348 Rookie
    Nov 20, 2024
    8
    edwin JOHN buckland
    Hi folks , I am hoping to purchase a 348 soon here in the uk ready for the long hot summers o_O
    The car I am hoping to purchase has had a major service belts changed in 2019 in this time its been well cared for in a heated garage and over the last 6 years travelled less than 600 miles but started regularly.
    My question is, is this an abosulute must replacing the belts or could it wait while i get used to the car then introduce my own service rountine. How resilient are modern belts
  2. ChoonHound
    ChoonHound Formula 3
    2,082
    Saint Michaels, MD
    Lucas
    My recommendation: find a mechanic you trust who you intended to care for the car while in your ownership and ask them
    Actual wrenches and engineers will have their own opinion and I’m sure they’ll share it here. In a sea of opinions, I prefer to listen to the person who has the responsibility for doing and warranting the work.
    chas-3 and eddie348 like this.
  3. A348W
    A348W Formula 3
    Jun 28, 2017
    1,843
    North Wiltshire, UK
    Personally Id have them done. They have been stood for 6 years! It not just the belts you need to worry about but also the tensioners.
    You'd also want all the fluids changed; brake fluid for example is hyrdoscopic.
    And check date on tyres as you will probably want new ones as they will have gone hard.
    With that length of inactivity don't be surprised if you get a few other issues.
    Belt service isn't stupid money here and you can use it as a bargaining chip when negotiating on price. Indie and some main dealers expect to pay £2-2.5k. Budget £4k total to cover other bits and bobs. Tyres are readily available from the usual places.
    eddie348 and 308 GTB like this.
  4. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    747
    Yorkshire UK / Switzerland/ Antibes France
    Portofino
    There’s only one cam belt .
    Two auxiliary, alternator and AC pump ( AC pump taken off above pic ) . You might be able to visually inspect the two auxiliary belts for cracking , age etc from underneath? Remove a panel ?
    Personally I can’t see a show stopper issues with running your car another year considering its milage history .
    What exactly has it had done maintenance wise since it’s last major in 2019 ?
    Figure on dropping £3 K every 5 yrs for a pro to remove the engine and give it a proper Major , tackling those belts .
    The in between lub changes , g box oil , coolant , and brake fluid , plugs , leads etc are like A N Other car that a John Doe DIY er can do @ home . I would do a lub + filter annually.
  5. ylshih
    ylshih Shogun Assassin
    Honorary Owner
    Mar 21, 2004
    20,267
    Northern CA
    Yin
    If you search for "348 timing belt life" here, you'll find 100+ results and links to a few threads on this topic. You'll find a spectrum of opinions. At least one user has gotten away with over 10 years, while some others discuss the consequences of a failure. If you can't easily afford an engine rebuild, it's probably a better choice to do the belt.
    eddie348 likes this.
  6. ChoonHound
    2,082
    Saint Michaels, MD
    Lucas
    Really? Here in the US the only tires available in the factory size are all seasons.
    Longstone has factory pirellis but I wonder what the date code is in them.
  7. eddie348
    eddie348 Rookie
    Nov 20, 2024
    8
    edwin JOHN buckland
    Hey thanks for the response I think it’s been serviced by well known specialist recently and has a very good history and presents really well. I think I’ll need to get over the shock of the purchase then set a date for the belt change.
    I’m based near Bristol so will be searching for quality Ferrari specialist.
    I’m very handy having restored another Italian v8 ( a triumph stag ) tenuous I know
    The 355 was my poster car but having seen a 348 at the nec recently I fell in love. They look much better in real life than in pictures.
    Wish me luck.
    Regards edd
  8. ChoonHound
    2,082
    Saint Michaels, MD
    Lucas
    So true. I am convinced that if the 348 photographed better they’d be much more revered.
    chas-3, Ferrarium and eddie348 like this.
  9. Portofino
    Sep 17, 2011
    747
    Portofino
    @“ choonhound “The go to U.K. performance tyre seems to be Michelin PS 4 s .Readily availability here in the U.K. in standard 17 inch 348 sizes F + R .
    I run them on my daily boxster and can recommend . Just had a fresh set fitted on my new to me 348 SP .
    Experienced F car Indy recommended them over Pirelli P zeros .Some Pirellis ( sporty versions ) have poor results on damp , pot holed , leaf infested cold U.K. roads . Although OEM on many brands guys who switch to Mich PS 4 never look back ….no pun intended. Bentley , BMW , and Porsches with far more Hp to play with than a F 348 l
    Having said this whilst not making the top road sports car tyre , being eclipsed by Michelin, Pirelli beat the competition with the all season Pirelli scorpion Verdi . We run these on our SUV Macan and they grip incredibly on snow / ice / winter conditions.
    I think Land Rover OEM fit them too .
    Obviously completely unsuitable for Ferrari summer usage .
    ChoonHound likes this.
  10. ChoonHound
    2,082
    Saint Michaels, MD
    Lucas
    #10 ChoonHound, Dec 3, 2024
  11. Portofino
    Sep 17, 2011
    747
    Portofino
  12. A348W
    A348W Formula 3
    Jun 28, 2017
    1,843
    North Wiltshire, UK
    PZeros are available here, new. I find them marmite; once warm and you push through the initial but that feels squirmy you can really lean on them.
  13. A348W
    A348W Formula 3
    Jun 28, 2017
    1,843
    North Wiltshire, UK
    There are a few of us around Bristol. I help run the Cotswolds FOC group, and the welsh group is very active.
    For indies you have about 6 ferrari specialist within 1.5-2 hrs. Do ask before using as some are more suited to these cars than others. I use main dealer, Carrs in Exeter. Not much more than the indies, just more convenient logistics wise for me.
    With regards servicing, in the Uk car price/salability is very sensitive to the service history. A stamped up history is well regarded. I get mine serviced annually, but do other stuff myself. just so i have that stamped up service history.
  14. AceMaster
    Feb 6, 2009
    34,749
    Ontario, Canada
    This is an impossible question to answer.
  15. ChoonHound
    2,082
    Saint Michaels, MD
    Lucas
  16. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,711
    Lake Villa IL
    Let me rephrase this for you.
    "What's my risk tolerance"
    Only you can answer that.
    I would roll the dice on it if everything -seemed- to correlate.
    You might lose sleep over it, I don't know :)
  17. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I'd be less concerned about the new belt breaking, Id be more worried about the belt breaking because of prior owner issues. That is usually the cause of a belt failure outside of the odd actual high mileage, belts not changed, abused car type failure.
    Personally in your position I would not be worried about it mechanically, the engines are far from brittle. I would be worried about prior owner issues more than anything.
