Those with garage door openers should look at this! | FerrariChat
Discussion in 'Other Off Topic Forum' started by Mera, Aug 30, 2008.
  1. Mera
    Mera Formula Junior
    Aug 13, 2005
    768
    Milwaukee, WI
    Rodney Dickman
    #1 Mera, Aug 30, 2008
    I have been doing some work on my three car attached garage. One of the things I have been doing is taking the original drilled angle iron braces out for the tracks for the doors and the braces/brackets for the openers and I made custom heavy steel pieces that look much cleaner. I'll do a write up on that later. When I was installing my new brackets I made for the electric openers I found the original brackets had been installed with very short lag bolts. They went into the studs maybe one inch at best. Each opener brace/bracket had 3 of these short lag bolts. I have heavier industrial door openers. One could have easily one day just fallen down. Yikes! With my new brackets I put in 4 inch long lag bolts. No chance of that ever happening!
  2. Mera
    Mera Formula Junior
    Aug 13, 2005
    768
    Milwaukee, WI
    Rodney Dickman
    To answer the question before some one asks it: I did have to go in my attic and put in joist hangers between the studs and put in 2 x 4"s so there was something for the lag bolts to go into. Originally the installer just puts a long piece of angle iron on the ceiling to pick up the studs. I wanted to be able to put lag bolts anywhere I needed them when I installed my brackets.
    Rodney Dickman
    1990 348 TS
  3. wetpet
    wetpet F1 World Champ
    10,210
    all i can say is you must have alot of free time.
  4. JAM1
    JAM1 F1 Veteran
    8,674
    FL, NY, and MA
    Joe
    Nice work on the new brackets... they look much better and I'm sure they are installed better than most people's!
  5. CornersWell
    CornersWell F1 Rookie
    Nov 24, 2004
    4,896
    Notwithstanding the aesthetic benefit, I'm not sure the longer bolts will do much of anything. The motor mechanism isn't a weight bearing element (at least not of the garage door itself). Not saying it can't ever come down. But, this could well be overkill. Regardless, if you feel better about it, go crazy.
    CW
  6. Mera
    Mera Formula Junior
    Aug 13, 2005
    768
    Milwaukee, WI
    Rodney Dickman
    #6 Mera, Sep 1, 2008
    I disagree. I felt I could have easily turned them a few turns tighter and easily stripped them out. They had very little holding ability only going in the wood around 1 inch. You have to remember that at least 1/4 inch or so is the tapered end. So there was in reality maybe 3/4 inch or less of the threaded lag into the 2 x 4. Plus my commercial grade openers are much heavier than standard home use garage door openers.
    Rodney
  7. CornersWell
    Nov 24, 2004
    4,896
    Well, enjoy.
    CW
  8. URY914
    URY914 Formula Junior
    Feb 17, 2004
    608
    Temple Terrace FL
    Paul
    #8 URY914, Sep 1, 2008
    I would add a piece from your motor mounting plate to the your ceiling mount but have it angled. Say from the end of the motor to the ceiling piece. This will provide diagonal bracing of the motor.
    But it is a much cleaner install than the previous job.
  9. Mera
    Mera Formula Junior
    Aug 13, 2005
    768
    Milwaukee, WI
    Rodney Dickman
    My braces I made are 5/16" by 2" cold rolled steel wire welded. There is no need for a diagonal brace. They have no give. They are very strong. You can go and push on a opener and there is no movement.
    Rodney
  10. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    Rodney,
    I think they look great, and you did a great job...and, it not only looks better, but will likely last longer and be safer in the long run.
    Nice!
    Mike in Kuwait
  11. jk0001
    jk0001 F1 Veteran
    Oct 18, 2005
    6,706
    Sun Coast
    Jim
    Looks great
  12. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,958
    MD and NE
    Robbie
    Way to beef it up Rodney--Looks nice!!
  13. Mera
    Mera Formula Junior
    Aug 13, 2005
    768
    Milwaukee, WI
    Rodney Dickman
    #13 Mera, Sep 2, 2008
    As you can see I also did the brackets for the rails. They had the typical punched hole angle iron and diagonal braces. Now they are just a single heavy duty angle iron. No cross braces. They are very strong and have no need for a cross brace of any type. For that I also had to add some 2x4's in the attic to bolt them to. Once the dry wall work is done and the garage repainted it will look so much cleaner. When I bought this house I loved the attached garage. It looked so clean. Custom made cabinets. Epoxy painted floors etc. But as I lived here that last 5 years I did start to notice how unattractive the brackets holding the openers and rails were. I finally took the time to redo them.
    Old picture from when I was buying this house.
    Rodney Dickman
    1990 348 TS
  14. Mera
    Mera Formula Junior
    Aug 13, 2005
    768
    Milwaukee, WI
    Rodney Dickman
    I'll also be redoing the low voltage signal wires. They will be relocated to be close to the bracket where they come out of the ceiling. I will also redo the outlets. Since the outlet only needs one plug I will change them all to single plugs. Hopefully white if they sell single white outlets and covers. That will clean things up even more.
    Rodney
  15. URY914
    Feb 17, 2004
    608
    Temple Terrace FL
    Paul
    #15 URY914, Sep 2, 2008
    Looks like the motor mounting plate is bolted to the vertical angles. What is keeping the motor mounting plate from rotating around on the bolts? Maybe there is no need for anything else. Like I said before, this is much better than the original installation.
  16. toddjw73
    toddjw73 F1 Rookie
    Feb 5, 2004
    3,506
    Nor-Cal
    Todd Westbrook
    I like the upgrade! Much cleaner and less to see. Way better than the Erector set look
  17. UroTrash
    Jan 20, 2004
    40,486
    Purgatory
    Clifford Gunboat
    Post more pics of your car. :)
  18. Mera
    Mera Formula Junior
    Aug 13, 2005
    768
    Milwaukee, WI
    Rodney Dickman
    #18 Mera, Sep 2, 2008
  19. Mera
    Mera Formula Junior
    Aug 13, 2005
    768
    Milwaukee, WI
    Rodney Dickman
    I would love to reloacte the outlets closer to the brackets but that is a lot of work for so little cosmetic gain.
    Rodney
