throttle body adjustment | FerrariChat
Discussion in 'Technical Q&A' started by enzoferrariphil, Dec 16, 2004.
  1. enzoferrariphil
    enzoferrariphil Karting
    Oct 26, 2004
    67
    Solana Beach CA.
    Philip Ponzio
    does any body know the amount of turns on the throttle body adj. screw? I have a 1980 308 gtsi.
  2. Rifledriver
    37,106
    Air bleed screw or throttle stop screw or?
  3. enzoferrariphil
    Oct 26, 2004
    67
    Solana Beach CA.
    Philip Ponzio
    Throttle stop screw!
  4. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    The butterfly stop screw should never need adjusting. It's primairily to ensure the butterfly can't close completely, thus avoiding the butterfly sticking & wear on the butterfly, throttle body, & butterfly shaft.
    However, if it's been miss-adjusted, here's how to recover.
    Factory procedure is to adjust it for about 0.003" butterfly-body clearance,
    then adjust the bypass air screw to set idle speed properly.
    Alternative procedure is to:
    1.Close the bypass air screw
    2.Open butterfly stop screw until the engine starts & runs,
    3.then adj it until idle is steady at ~750 RPM.
    4.Open bypass air screw until idle is steady at 850 RPM.
  5. enzoferrariphil
    Oct 26, 2004
    67
    Solana Beach CA.
    Philip Ponzio
    Thanks! Someone had it way out of adjustment. Ferrari Christmas!!!!!!!!
