Throttle cable access | FerrariChat
Discussion in '206/246' started by possum, Sep 7, 2009.
  1. possum
    possum Formula Junior
    Sep 27, 2008
    307
    australia
    johnno
    #1 possum, Sep 7, 2009
    Sick of taking the complete fiberglass under belly off because of throttle cable problems thought I would attack the inspection covers that were covered in rust and the screws wouldn't budge.I ended up drilling a hole through the middle of each screw and then knocked the head off,sourced some similar screws,a coat of paint and all finished, under belly back on didn't take that long and something you can do if you have the same problem.
  2. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Nicely done....
    Jim S.
  3. possum
    Sep 27, 2008
    307
    australia
    johnno
    #3 possum, Sep 11, 2009
    Thanks Jim S,
    Its amazing the jobs you can do yourself if your not afraid of the word Ferrari,I dont pretend to be a mechanic or a panel beater but I will have a go at simple things and Im sure a lot of us do and it gives you a great deal of satisfaction.Have noticed the paint flaking on the front chassis member looks like brake fluid is leaking somewhere,another job to investigate.
