Throttle Cable | FerrariChat
Throttle Cable
Discussion in '308/328' started by GrayTA, Sep 20, 2011.
  1. GrayTA
    GrayTA F1 World Champ
    15,130
    Deep South
    PDG
    A few weeks ago I had this thread about my pedal sticking:
    http://www.thebestemployee.com/forum/showthread.php?t=334898
    Well, it gave out about a week and a half ago as I was giving a ride to a local policeman. Yeah, that wasnt too cool, but he understood. Fortunately, it happened when I was only about a half mile from my house. I let the car pull itself along in idle back to the house - I even went through all the gears no less!! LOL!!!
    Now the pedal is just floppy on the floor. :(
    So, I guess I need to get in there and fix it. My assumption would be that its the throttle cable is gone out/broken/disconnected.
    Anyone got any step by step instructions I can follow so I am not just guessing at what I am doing???
    PDG
  2. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
  3. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    First, find out if it broke or just disconnected at one end. That happened to me once. The cable disconnected at the thottle pedal. If it broke near the thottle body / carbs, then tape a string to it and pull the cable out by the pedal. Then tape the string on to the new cable, lube the cable, and pull /push the new cable through. In any case, the new cable can be pushed through the tube starting at the pedal. Then it's a matter of connecting the ends and adjusting the slack out. Not a difficult job.
  4. GrayTA
    15,130
    Deep South
    PDG
    Everything looks to be ok at the throttle body (QV) so I can pretty safely assume its at the pedal.
    I will try to take another good look down in the footbox and see what I find. Maybe it just came loose, but I suspect its broken as that would be just my luck.
    Thanks for the suggestions!!
    PDG
  5. SteveG75
    SteveG75 Formula Junior
    Nov 23, 2010
    380
    FL
    Stephen
    Not sure about the QV cars but on my '77, the access to the pedal/cable connection is under the car. There is a small panel held on by about 6 screws that covers the linkage. I had to adjust my cable to get full throttle opening (probably due to stretch).
  6. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    My car does not have a center console, but I think on a stock QV, there is a panel on the forward console that, when removed, gives you access to the pedal/cable connection. It is from there that you feed the new cable to the engine compartment. On the QV, most, if not all the adjustment is made where the cable passes through the intake manifold / runners and at the TB connection.
  7. viper_driver
    viper_driver Formula Junior
    Jan 1, 2009
    978
    Vegas
    Jason
  8. GrayTA
    15,130
    Deep South
    PDG
    Excellent!!!
    I think thats pretty much exactly what I needed to see. I feel a LOT better about what I will be doing after seeing that. Thank you!!!
    PDG
  9. guido ferrari
    guido ferrari Karting
    Jul 21, 2011
    99
    I replaced the throttle cable on my gt4, it frayed badly at the pedal end and effectively became too long. Memory is fuzzy but I've got a replacement cable in my hands now, the non-removeable ends are too big to pass through the housing/sheathing. So at least on the gt4, there's no pushing it through from the pedal end, it has to be fed forward through the firewall.
    Or, I could be wrong.
    GF
  10. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    You may be correct. It's been a few years since I replaced the cable. Either way, the procedure's the same, just now not sure which end to push / pull from. I'll check next time I get the car down from the lift.
  11. GrayTA
    15,130
    Deep South
    PDG
    #11 GrayTA, Sep 29, 2011
    So, I got out there and spent a little time with the car to see if I could figure the problem out.
    What I discovered:
    1. The cable does NOT appear to be broken.
    2. Both ends are attached and the cable moves freely.
    3. There is slack in the cable between the pedal and the throttle body.
    4. There is a tiny cotter pin at the very top of the end at the throttle body. It really doesnt seem to attach to anything or have any purpose at all. Maybe this is the source of all my problems though??
    My deduction:
    If I can figure how to remove the slack from the cable everything should work properly and be just fine.
    So, I tried to figure how to disconnect the cable at the throttle body in order to pull it taut as suggested by both Pad and Guido Ferrari. When I undo the screw I see that the end should unscrew from inside the connector. However, when I try to rotate the cable itself to unscrew that piece it immediately springs back.
    My question is How do I do that properly??
    Photos to follow. Thanks for any and all help!!!
    PDG
  12. GrayTA
    15,130
    Deep South
    PDG
    Before anyone asks - Yes, I did clean out the fuzzies from the area around the pedal and I pushed that cotter pin back in. I did both AFTER taking the photos though, so there!! before anyone says anything about it. LOL!!!!! :p
    PDG
  13. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    #13 pad, Sep 29, 2011
    The slack is adjusted where the cable shield attaches to the intake manifold / runners. Follow the cable from where is leaves the engine firewall to where it comes up to the runners. At that junction, you will find the adjuster with a lock nut (see #7 in diagram). Loosen the lock nut (it may already be loose causing your problem), adjust the slack out of the cable, then tighten up the nut thereby locking the adjustment.
  14. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    #14 Crowndog, Sep 29, 2011
    From your pictures there does not appear IMO to be enough thread at either end to take up enough slack. I suggest that you study the diagram and notice that perhaps the lever (item 10)/pedal (item 1) relationship (picture 1) has changed. It may have slipped and that was what you felt previously. It may be that the assembly needs to be taken apart at the pedal and sorted out.
  15. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
    Make sure that the cable housing is solidly attached to the body/frame at both ends. If one end of the sleeve can move then you can get the same symptoms you are seeing.
    My Pinto station wagon had the clutch cable housing come through the fire wall once due to a broken washer. Symptoms were exactly as a broken cable.
    Gerrit
    Former owner of 11966
  16. GrayTA
    15,130
    Deep South
    PDG
    New Follow Up:
    Finally after some miscommunications I got the new cable in from Superformance.
    Now the cable seems to be a bit short on either end. I have it about as loosely as I can get it but if I were to start the car right now the engine would "idle" extremely high because of the tension.
    Is it best to try to loosen it at the pedal at this point?? I only need about 3/4 inch to remove the unnecessary tension.
    Suggestions??
    PDG
  17. GrayTA
    15,130
    Deep South
    PDG
    Bump!!!
    PDG
  18. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    I'll say yes to that question Pat.
    Good luck.
