348 - Throttle Control Solenoids $700 vs $40?!? | FerrariChat
348 Throttle Control Solenoids $700 vs $40?!?
Discussion in '348/355' started by JM280z, Mar 7, 2022.
  1. JM280z
    JM280z Formula Junior
    Aug 22, 2020
    852
    Jake
    Hey All,
    Ferrari part number: 142432
    Bosch: 0280140505
    Aka: regulator for idle adjustment or air control valve
    When I got the car, they were acting up. I swapped sides to see if problem followed but no more issues! I knew one was acting up as I felt it actuate or not. Regardless, car has been running flawless for the last 4 months, but I am replacing them preventative, also the sensors (link below).
    Question:
    Anyone have a source to the Bosch ones?
    Should we trust the $40 Tamkken ones?!
    We all agree $700 is ridiculous for OEM, right?
    OEM: $700-1,000
    https://www.scuderiacarparts.com/part/2348/ferrari/142432/regulator-for-idle-adjustment.html
    Duralast: $220
    https://www.autozone.com/engine-management/idle-air-control-valve?filterByKeyWord=0280140505&fromString=search&isIgnoreVehicle=false&searchText=0280140505
    Tamkken: $40
    35150-22000 Idle Speed Air Control Valve 0280140505 034133455 7637024 for Hyundai Tiburon Elantra Accent Kia Sportage Saab 900 Volkswagen VW Cabriolet Golf Jetta/TAMKKEN https://www.amazon.com/dp/B07MSCX1XR/ref=cm_sw_r_cp_api_glt_i_8XGMM6F91V4K0WF3ERQG?_encoding=UTF8&psc=1
    Sensors:
    Bosch 0280122001 Throttle Position Sensor https://www.amazon.com/dp/B000UIOQT8/ref=cm_sw_r_cp_api_glt_i_27FNGBCJD2D2DJQC7ZVF
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    26street and EastMemphis like this.
