throttle control | FerrariChat
throttle control
Discussion in '360/430' started by formula01, Feb 24, 2011.
  1. formula01
    formula01 Rookie
    Jul 14, 2010
    6
    Miami FL
    has anyone experienced a problem with the electronic throttle control on a 360?
    the CEL is blinking and the car would not accelerate as usual, my mechanic thinks its the ETC.
    any ideas?
    thanks!
  2. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    I did. Do your mechanic has a SD2/SD3? If not, find someone who does.
  3. Rifledriver
    37,104
    If there is a problem with the throttle pedal the system will limit you to 25% throttle. It is not what I would describe as a small reduction. Lots of things can cause what you describe.
    You really have to have one of the applicable Ferrari testers to diagnose it.
  4. formula01
    formula01 Rookie
    Jul 14, 2010
    6
    Miami FL
    turned out limited acceleration was due to a failed fuel pump, my mechanic removed it, had the lines in the fuel pump rebuilt.
    waiting to drive it back... at full speed!
