throttle linkage part | FerrariChat
Discussion in '206/246' started by stanzeman, Oct 17, 2006.
  1. stanzeman
    stanzeman Rookie
    Sep 25, 2006
    14
    #1 stanzeman, Oct 17, 2006
    Hello everyone,
    I lost the little nut that holds the throttle linkage together (see pic).
    Any idea of where I could find a replacement that looks like the original?
  2. Dinoguy2
    Dinoguy2 Karting
    Nov 9, 2005
    91
    Racine, Wisconsin
    Bob Budlow
    I would try contacting Dennis McCann or Superformance (UK). I checked recently with Superformance regarding a small piece that was missing from my throttle linkage, and they had it. Also, Dennis seems to have lots of Dino bits; I'd try him too.
    Regards, Bob.
  3. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,067
    Seattle, WA
    Keith Mitchell Wintraub
    I know that nut! You'll also need a cotter pin which fits through two of the holes and sits in one of the nut's slots so that it doesn't back out. That is probably how it went missing in the first place.
    Dennis has always been great with these sorts of things. If you have a parts book with your car, look up the part number and you can see if Dennis has it in stock at www.allferrariparts.com.
    Maranello Concessionaires may have it as well.
    Cheers...Keith
  4. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    I'm not certain, but I think you will find that this is exactly the same as the linkage end pieces on the 348 (and other models?). I have unscrewed the end cap on my 348 in order to remove the ball from the socket, it looks identical. I can remove it and photograph it if you wish to see it in detail. It would only take a few minutes. Or perhaps someone in your area has a 348?
    The threaded end cap piece does not show as a separate part in the 348 parts book, you have to buy the "spheric head" in either RH thread or LH thread, Ferrari part numbers 105617 and 105619.
  5. dm_n_stuff
    Dec 10, 2003
    43,715
    26.806311,-81.755805
    Dave M.
