Throttle Nut Torque? | FerrariChat
Discussion in '308/328' started by thorn, Mar 12, 2020.
  1. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Have been chasing imprecise throttle control for months... thought I had it solved, but over the weekend it popped up again. Decided to take a closer look, and believe I've found the gremlin. The problem is that I'm not sure the proper way to address it.
    The nut (green arrow) is slightly loose, allowing play in the linkage. I can easily tighten it, but TOO tight seems to bind up the butterfly. What's the proper torque or procedure?
    Also, I've noted that the keeper flap (yellow arrow) isn't flat against the nut to keep it from turning. I assume it should be bent into place once the nut is tight, yes?
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,825
    Cerritos, CA.
    Yes, that tab need to be bend against the nut to keep the nut from coming loose.
    thorn likes this.
  3. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Thanks, Mike. That's how I've done it on other cars, but wanted to make sure this flat tab wasn't some weird Italian thing.
    miketuason likes this.
  4. maxflynn
    maxflynn Karting
    Feb 9, 2015
    112
    GTA
    David
    Hi, FWIW, my throttle stuck open on me once, actually it wouldn’t close all the way, maybe different from your issue, but I found the culprit to be excessive carbon build up on the throttle plate and the shaft.
    While you’re there maybe have a look, it can cause the throttle to bind.
    David
  5. miketuason
    Feb 24, 2006
    15,825
    Cerritos, CA.
    Here’s mine and you notice I installed a new “anti tampering” (gray) part. Image Unavailable, Please Login
    dinoart and thorn like this.
