Throttle Position Switch 308 QV Question | FerrariChat
Discussion in '308/328' started by Dr Tommy Cosgrove, Jul 16, 2007.
  1. Dr Tommy Cosgrove
    36,368
    Birmingham, AL
    Tommy
    Aren't you supposed to hear a little click when you just begin to move the throttle? I am not hearing a little click and I am pretty sure I used to. Just wanted to check before I adjust the thing all over the earth trying to find the click sound.
  2. wolftalk
    wolftalk Formula Junior
    Jan 27, 2004
    367
    san franciso area
    phil
    #2 wolftalk, Jul 17, 2007
    yes, there's a microswitch inside that is making the noise. You can also test the thing (assuming a certain contortionism if you don't dismount it) per below.
    bosch part # 0 280 120 310 on the 328. Pretty sure it's the same on yours.
    ebay price is $33.50 (including shipping) currently.
    it's usually pretty cocked on the throttle body when positioned right.
  3. Dr Tommy Cosgrove
    36,368
    Birmingham, AL
    Tommy
    You're a big help. Thanks.
    I wonder if mine is out of adjustment and stuck in the "on" position all the time since it won't "click" at all thru the entire throttle travel.
    How would the car idle if this is the case? (I am having an idle problem too). It feels and sounds like a hot rod Ford with big cams, real lumpy. It runs smooth but it just doesn't sound right during idle at all.
  4. wolftalk
    Jan 27, 2004
    367
    san franciso area
    phil
    the leaf switch on the left in the above pic is the WOT switch. You can usually feel a small resistance when the cam operates the switch.
    the microswitch on the right just closes when the throttle is closed. The adjust is to loosen the two bolts and rotate the thing counterclockwise until you hear/feel the microswitch click closed, then tighten the bolts at that position.
    if the microswitch fails, it's usually cruddy contacts inside. It'll still do it's clicking thing, but the closed switch will be high/infinite resistance. That's why measuring it is really needed. If you happen to have the injection ecu plate up, then it easiest to check the throttle switch from there.
    wrt what the throttle switch actually does, my memory is a bit vague. Both of the switches feed into the injection ecu. I assume the WOT one signals for fuel enrichment, and the throttle closed one may be for tweaking to prevent idle undershoot.
    one of the switches can also power the relay that is controlling the electrovalve for the air injection cutoff valve. Whether it turns off the air injection, or turns it on I don't remember.
    on the 328, the other switch also connects to the ignition ecu. May not connect to the digiplexes.
    I think it's been said that a bad microswitch can effect idle. I've never seen details on what the injection ecu is doing, though, so can't say for sure. One of these years I'm going to get around to hooking up some test equipment to the 328 and trying to figure out how these bits interact. A scope on the frequency valve should do most of it, since that's the only control the injection ecu has. A wideband O2 sensor would be nice to for measuring the fuel mixture, but I don't currently have one of those.
  5. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,309
    Dumpster Fire #31
    SMG
    the throttle switch on 'pulsed' systems sends the signal to the ECU to correct for over swing on vane of the L-jet systems. it also provides full enrichment based on obviously throttle position for WOT and idle transition much like a progression circuit from the carb days. this is all on 'pulsed' injectors where you can adjust the flow rate at the injector. it's basic operation is to sync the signals from the vane to the throttle for proper fuel distrabution, some of them also control coasting fuel cut-off and RPM limitation, much like the KE.
    my guess is it operates in a similar manner but pre-dates the KE-jet.
    OK grabbed my Bosch book, the KE3-jetronic is the first system to use these inputs and was used by Audi in 1987 on the 5000's. no mention of the TPS on the CIS prior to that and no mention of it in the WSM's I have. Bosch stipulates that it operates two separate control units, ignition and injection. so it would function much like the motronic and KE3 or CIS-E III Mercedes employed in 1988.
    so bottom line it's an 'electrical' version of a carbs accelerator pump, clear as mud right? :D
  6. Dr Tommy Cosgrove
    36,368
    Birmingham, AL
    Tommy
    My 87 16V Scirocco has the same inj system. It has two TPS too; idle and WOT.
    I have it adjusted now. I have no idea how long it wasn't working properly. I haven't driven the car yet to see if the idle problem is resolved.
