Throw-out bearing seal orientation | FerrariChat
Discussion in 'Technical Q&A' started by mike01606, Jan 17, 2018.
  1. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    Can anyone point me to a diagram showing which way the seals go into a 360 (or similar) throw-out bearing?
    I have the parts numbers versus locations and have installed the new ones like for like as per the old one but I just want to confirm they are in the correct way around.
    The WSM doesn’t show it.
    Thanks.....
  2. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    Thanks Daniel,
    All 6 are different and the slider rings in the middle of each end appear to be reversible.
    The other 4 oil seals have a rubber backing ring and a groove which I assume means they should go in a certain way....see poor picture.
    I put the new ones in as per the old ones but wanted to check before I fitted it to the car....
  3. Merlin Auto Group
    Merlin Auto Group Formula Junior
    397
    Atlanta
    The middle seal does not have a difference. The outer stepped seal should be installed with the o-ring on the outer edge of the groove. this should have the edge pointing to the fluid. The inner seal should have the edge pointing toward the fluid in the slave. I don't have one apart at the moment to show pictures, hope this helps.
  4. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    Thanks....
    I spoke to my main dealer today and one of the experienced tech’s said they go in like this.....
    The black shaded areas are the o’rings. Is that what you mean?
    The one I took off the car was different. The rear most seal on the slave (outer one, large diameter) had the o’ring towards the centre.
  5. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    The above post is wrong....I’ll correct later or if it can be deleted.
  6. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
  7. Merlin Auto Group
    397
    Atlanta
    That is the way I do them. That is what I was trying to explain, I just didn't have a cool drawing to explain it.
  8. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    Thanks.....
    The one installed in my car which I think is the one it left the factory with, had one of the seals in the wrong way round!
  9. Merlin Auto Group
    397
    Atlanta
    It happens like that sometimes.
  10. AceMaster
    Feb 6, 2009
    34,785
    Ontario, Canada
    And still it didn't leak?
  11. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    No and it has a 2000 date mark on it so assume it’s been in for 17 years and 44k miles.
    It wasn’t changed when the clutch was done at 22k.
    It’s more of a scraper ring so probably not the primary seal which is the inner one.
