throwout bearing needed...help | FerrariChat
Discussion in '348/355' started by nsxmann, Jun 21, 2006.
  1. nsxmann
    nsxmann Rookie
    Jul 4, 2005
    12
    anyplace to get a throwout bearing for my 355? i know there is an upgrade kit from ferrari for 1600.00 but can i still get just the bearing itself? any help would be greatly appreciated. dont really want to spend the 1600 if i dont have to. anybody get the 1600.00 kit any cheaper even?
    aaron
  2. Ricambi America
    Sponsor Owner
    What? That pricing is whack. The Hill Engineering bearing is a zillion times better than OEM and comes prefitted with seals. (always in stock at Ricambi) :
    http://www.ricambiamerica.com/product_info.php?cPath=2_735&products_id=261280
    I'm guessing your 6-speed F355 has blown the butt end of it's TO bearing, eh? That won't happen again using this Hill Engineering item.
    -Daniel
  3. jeffdavison
    jeffdavison F1 Rookie
    Jul 29, 2002
    2,544
    Suwanee Georgia
    Jeffrey Davison
    The Hill t.o. bearing for the 355 is the absolute way to go! Did mine a couple of months ago. Much stronger than oem and less expensive. Anyone not using the Hill piece (imo) is a fool.
    Daniel also has the best customer service in the business!
    JD
  4. Vitamin_J
    Vitamin_J Formula Junior
    Feb 4, 2006
    281
    Double True!
  5. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
  6. Llenroc
    Llenroc F1 Veteran
    5,493
    Colorado
    Vern
    Just a clarification on Ferraris 1600.00 price that is for the T.O. bearing, shaft and seals as a kit. The bearing alone is around 400.00 you wouldn't need the kit unless you have a damaged shaft. Ferrari uses the 360 bearing pt no. 201024 for non F1 355s and single disc 348s, this is the one with new blue seals vs the single black seals(I think you can still get the older bearing but what's the point). I would have to agree that the Hill bearing is probably better but I don't think it's much cheaper than ferraris newer 360 bearing. Anyway just passin' along info. Regards, Vern
  7. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Send F-chatter Plugzit a pm. He had the throw out bearing for a 348 rebuild by a shop here in Cali at a very reasonable price. If it's just the bearing that is out, I would rebuild it. If the housing has blow out, then get the Hill bearing from Dan.
  8. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Tripple true. Dan is the man.
