News
Thunderbirds
Discussion in 'AviatorChat.com' started by BJK, Jan 14, 2021.
  1. BJK
    BJK Formula 3
    Jul 18, 2014
    1,963
    CT
    bradyward and Jaguar36 like this.
  3. To remove this ad click here.
  4. Gatorrari
    Gatorrari F1 World Champ
    13,974
    Georgia
    Jim Pernikoff
    I first saw them in Puerto Rico in the '60s when they were flying F-100s!
    bradyward likes this.
  5. tazandjan
    33,076
    Jim- F-84Fs for me the first time I remember. The red, white and blue drag chutes were fun to see. Dad was in the AF, so do not remember where I saw them. Too many bases.
  6. To remove this ad click here.
  7. BJK
    BJK Formula 3
    Jul 18, 2014
    1,963
    CT
  8. Gatorrari
    13,974
    Georgia
    Jim Pernikoff
    They flew both F-100Cs and F-100Ds, separated by their abortive switch to the F-105 Thunderchief in 1964. After a fatal F-105 crash due to structural failure, they switched to the F-100D. Appearance-wise, the difference is that the F-100Ds had the dark blue Thunderbird on their underside, while the F-100Cs didn't.
    greg328 likes this.
  9. tazandjan
    33,076
    They liked the F-100D much better because of the larger vertical stabilizer and rudder. The Thunderbirds I knew in the 70s (T-38s) were always grumping they needed more rudder authority. They hated those aircraft because they had no legs at all and no aerial refueling capability. During the hollow Air Force days.
    greg328 likes this.
  10. megamarco9
    megamarco9 Rookie
    Dec 11, 2020
    32
    Marco
    I'll never forget the Thunderbirds fly in at Detroit's Willow Run airport (early 70's) when I was a teen, they shocked the crowd when they come out of nowhere for an unannounced low pass from behind in the F4 Phantom.... I was back the next day for the air show, amazing sight & sound. I did not like the T38 years, OPEC did a number on us back then and hence the T38's.
  11. Boomhauer
    Boomhauer Formula Junior
    Aug 18, 2007
    510
    Milano - Italia
    Since the Blue Angels are transitioning to Super Hornets, are there any plans for the Thunderbirds to replace the F-16 ? F-35s are probably out of the question for the time being, but maybe upgraded F-16s ?
  12. megamarco9
    megamarco9 Rookie
    Dec 11, 2020
    32
    Marco
    I also think that F-35 would be out of the question... the service-per-flight hours on this model, $44k an hour, twice that of the F-16, seems a likely reason.
    Boomhauer likes this.
  13. tazandjan
    33,076
    The F-16C/D engines were upgraded during later versions and the Thunderbirds are flying Block 52s last time I heard, with P&W F100-PW-229 engines. With over 29,000 lbst, that provides a really good T/W ratio at the gross weights the Thunderbirds use in performances.
  14. megamarco9
    megamarco9 Rookie
    Dec 11, 2020
    32
    Marco
    single engine @29,000 lbst is impressive, why would they not use the Block 60 F16E with over 32,000 lbst.? Then you see the mind-blowing F35 w/43,000 lbst.... but monstrously complex.
    ChipG likes this.
  15. ChipG
    ChipG Formula 3
    May 26, 2011
    1,207
    Santa Monica, CA
    Let's just be thankful they are not grounded due to covid...
    However, the blue angels are, their separation is less than 6 feet.
  16. Dicecal
    Dicecal Formula 3
    1,328
    Phoenix, AZ
    Rob
    USAF never bought block 60s, the top dog is the block 50 with the GE 129 engines.
  17. niklas
    niklas Formula 3
    Apr 25, 2008
    1,361
    Chilliwack BC
    N. Olafsson
    I must admit, the Falcon has to be the prettiest fighter ever built. At least in my opinion. It just looks so damn good!
  18. tazandjan
    33,076
    Modern version of the P-51, both with belly intakes that work well at high AOA, even if one was only a radiator and oil cooler intake.
    Boomhauer and Bob Parks like this.
  19. Gatorrari
    13,974
    Georgia
    Jim Pernikoff
  20. tazandjan
    33,076
    When you are flying close formation aerobatics, when lead augers in, so do two, three and four. Very sad accident.
