Ticking noise coming from F512M engine bay | FerrariChat
Discussion in 'Boxers/TR/M' started by Zanzibar, Mar 28, 2010.
  1. Zanzibar
    Zanzibar Karting
    Jul 17, 2004
    119
    Hi all,
    I went to see an F512M that is for sale locally. When the engine is running at idle, there is a harsh ticking noise emanating from near the A/C compressor. It is hard to pinpoint it, but that is more or less the area it comes from. It does not seem to be entirely in synch with engine speed, more an erratic ticking once every few seconds. With my limited knowledge, I would guess either the A/C compressor itself or perhaps a bad spark plug wire that makes a short circuit with the engine ground?
    I know I should get a PPI anyway, but before I go that route, perhaps there are enlightened souls out here who can shed more light on this?
    Regards,
    Rik
  2. notenuphstuph
    notenuphstuph Formula Junior
    Apr 29, 2008
    273
    Lossiemouth,Scotland
    Ivor Hewjun
    Try spaying belt dressing on the ac belt, it works on mine, I think it's a common problem
  3. Zanzibar
    Zanzibar Karting
    Jul 17, 2004
    119
    The noise is actually quite harsh. Perhaps I should say more like a clicking noise than a ticking noise. The car is almost 400 km from my place, so I cannot spray the belt dressing from here. ;-)
  4. notenuphstuph
    Apr 29, 2008
    273
    Ivor Hewjun
    Mine is also VERY loud when it happens. But I aint no mechanic. I guess if your serious then a PPI will expose the problem. good luck and keep us posted with the outcome..
  5. JohnP
    JohnP Karting
    Nov 23, 2007
    159
    Richmond Hill
    Mine does the same, especially when the rpm drops during take off. it started after i changed the alternator. it sounds like a furl ping almost. I think its the alternator belt hitting the fan blades on the alternator. maybe the belt is to tight or to loose.
  6. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    ...could be the AC compressor or Alt.
    ....more likely the AC compressor. When it clicks, turn the HVAC control to full heat....if it goes away, it's the compressor.
    A couple of years ago, I had an alarming ticking noise. It was the upper rad hose leaking ever so slightly at the clamp dripping coolant on the AC belt.
    You would never believe the sound...sounded like a valve going
    ...tightened the clamp, full clean of the belt and voilà ! ....noise gone...heart back down out of throat. :D
    Shamile
    Freeze....Miami Vice !
  7. Zanzibar
    Zanzibar Karting
    Jul 17, 2004
    119
    Thanks to all for the input. It turns out that it was the belt. Problem has been fixed already by the dealer.
  8. Hawaii
    Hawaii Formula Junior
    Jan 28, 2007
    847
    Maui
    Emery
    Do you just spray it on the belt and pulley while it's running and the noise stops? What brand do you recommend.? Mine started clicking today....
  9. notenuphstuph
    Apr 29, 2008
    273
    Ivor Hewjun
    I use VAP VAPROMATIC beltdressing, spray on the AC belt whilst the engine is running, BE VERY CAREFULL, the ticking should stop immediately, I find that mine sometimes needs this after it's been caught in rain (sorry if I offened the (NEVER SEEN RAIN)guys) but here in N.E. Scotland they've all seen rain.............Hope this works for you.........
  10. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    In general, you should not need belt dressing. I drive my TR in very heavy FL rain with no squealing or ticking.
    I only had a ticking issue because of coolant dripping directly on the belt.
    If you have a ticking belt issue, the belt may be worn or glazed. Re-tension the belt first, if the ticking continues, put on a new belt. If it still continues, make sure the AC belt is aligned properly on the pulleys.
    Shamile
  11. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Also make sure you order the right belt. There was a design change and you need to know which belt is the correct one for your application..
    R
  12. LightGuy
    LightGuy Four Time F1 World Champ
    Oct 4, 2004
    46,160
    Texas
    David
    FWIW my Boxer ticks until it warms up. Has done so even after complete major service.
  13. Shemmer
    Shemmer Formula Junior
    Jul 8, 2007
    623
    Toronto
    Rob
    Funny, once in a while I hear the same thing when starting up. It's clearly a rotational noise but pretty loud, not AC related. It's similar to taking a screwdriver tip and tapping a metal bench with it. Kinda worrries me cause it sounds like it comes from the timing belt cover area. If it was a frayed belt I'm not sure it would make this type of noise. We should record it and post the video to see if they are the same noises we hear.
    I never thought of the belt dressing, maybe I'll try it.
  14. AHudson
    AHudson F1 Rookie
    2,781
    Florida
    Adams Hudson
    Same exact thing here. In retrospect, it does sound a little like a belt. I'm going to invest in some dressing and give a spray next time. Might be the cheapest fix in the history of Fcars.
  15. curtisc63
    curtisc63 Formula 3
    Dec 13, 2005
    2,290
    Maryland
    Curtis Campbell
    My TR will do this on occaision on first start up - usually cooler mornings. Goes away pretty quickly. I was made aware of this "quirk" early on in my TR search and never thought much of it.
    CC
  16. HOU
    HOU Karting
    May 2, 2009
    90
    Houston, Texas
    John S
    1. The gates polyflex AC belt can make a clicking noise. had the same belts on the Bora.
    2. the belts are very tuff. also seen them on airplanes. i never had a failure, but the belts do start to strangely click when they age.
    3. i recently changed both belts after an alternator belt failure at texas world speedway. see my post for the details.
    4. also belts are listed in the cross reference section
    5. i did not tighten the pivot bolts 100 percent so i can now more easily adjust tension entirely from above. after 1500 miles the alternator grooved belt was a little stretched so i tightened it. the ac polyflex did not need adjustment
  17. KENCO
    KENCO Formula 3
    Nov 1, 2006
    2,396
    FL
    KJG
    #17 KENCO, Apr 2, 2010
  18. Shemmer
    Jul 8, 2007
    623
    Toronto
    Rob
    Exactly, so nothing to be worried about then right?
  19. curtisc63
    curtisc63 Formula 3
    Dec 13, 2005
    2,290
    Maryland
    Curtis Campbell
    Two well respected F-trained techs have told me the same thing - one here in MD and another in Mass. I do not worry about it as long as it goes away in a few minutes - once some heat gets into the belt I guess.
  20. bensonae
    bensonae Formula Junior
    Apr 7, 2013
    284
    Tokyo, Japan
    Alex Benson
    Hey guys I found this thread with a search and think I may have similar issue. Recently at start up audible clicking noise coming from directly around AC compressor. To me it is very clear it is coming from that area. AC compressor comes on fine and works fine. Engine runs perfectly. But sometimes I can hear what sounds like a valve noise coming from behind the passenger side and from what Shamile wrote it sounds precisely like what my issue is. I tightened the AC belt and not sure it quieted it much. It feels tight with only a bit of slack as I am nervous to tighten it too much more. Any ideas to completely silence it. Belt does not seem to have oil or coolant on it to cause slippage. Thanks
  21. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,996
    So. Shore MA.
    Kenny K
    Here's a test to try. Get an adjustable nozzle water spritzer and spray just a light fine mist on the belt while it's making the clicking. Only need a squirt or 2. If the clicking goes away your belt is still a bit loose. Worked for me.
  22. Themaven
    Themaven F1 Rookie
    Nov 2, 2014
    4,385
    Eastdown
    Darius
    Did you buy the M?
  23. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,663
    romano schwabel
    or it is old and hard
    also may be a very little stone is in there who makes this noise?
    also it could be inductive electric charge ( don´t know if this is the right word?? ), so try to have a look in the dark and if you see some sparks then it is inductive charge. use some silicone spray
  24. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Its caused by static electric on the drive belts......
  25. turbo-joe
    Apr 6, 2008
    9,663
    romano schwabel
    I think static electric and inductive charge is the same?
