Time for a 355 Bypass Valve DYI Update | FerrariChat
Discussion in '348/355' started by TrojanFan, Nov 8, 2015.
  1. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,182
    So. CA & NV
    Peter
    OK. My bypass valve it rattling like a Mother F****r. If anything it's gotten worse over the past 6 months. I've tried tightening the shaft a few turns and loosening the shaft and neither has made any difference. Short of replacing this with a $1,200 - $1,400 part, has anyone found anything that actually works? Has anyone had any luck with the $120+/- ones of EBay? If so, specifically which ones? Is Goth anywhere close to a replacement for a reasonable price?
    Your help is appreciated.
  2. TrojanFan
    Nov 17, 2008
    5,182
    So. CA & NV
    Peter
    Has anyone had any luck with this replacement from ebay? It's only $120 and I believe someone had said it worked for them with a slight modification.
    Stainless Steel Exhaust Control Valve Set Vacuum Actuator 2 1 2" 63mm Pipe Close | eBay
    Brand new Stainless Steel Exhaust Control Valve with Vacuum Actuator
    Fits with 2 1/2"/ 63mm approx. OD pipe
    The actuator vacuum pressure range: -2 psi to -5.5 psi without loading
    The valve is closed at no vacuum
    Material: Stainless steel for all components
    Rod end bearing linked between actuator and gate lever
    Please make sure your all dimensions before place order
    Shipping & handling: for low 48 states vtia US Postal Service first class mail
    Texas resident should pay 8.25% tax
  3. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,911
    Richmond
    Pete
    I thought somebody had taken an old one apart and machined a brass bushing to fix it at some point - seems like that would be the way to go.
  4. tres55
    tres55 F1 Rookie
    3,572
    Canada
    I have a refurbished OEM unit in my car now. Has been fine so far but only around 3k miles on it so far.
    Apparently it should never rattle again with the way it was rebuilt but only time will tell. :)
  5. TrojanFan
    Nov 17, 2008
    5,182
    So. CA & NV
    Peter
    Who did the rebuild? If it was you, what did you specifically do?
  6. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    +1 would like to know where you had it rebuilt?
    first time I hear of a bypass being rebuild.
  7. TrojanFan
    Nov 17, 2008
    5,182
    So. CA & NV
    Peter
    Bumping in hopes that someone will chime in about trying the cheap one from ebay or on rebuilding them.
  8. Raiden
    Raiden Karting
    Mar 13, 2015
    52
    Mines making a racket and would love a cost effective solution too.
  9. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,635
    SoCal LA/OC/New Mexico
    Tim Dee
    Ebay ones will not open, they need much more vacuum and some machining to fit
  10. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,911
    Richmond
    Pete
    It was posted in the forums, maybe you have the patience to endure the torture that is fchat search to find it? If nobody chimes in I might take a stab at it tomorrow.
  11. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
  12. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,635
    Tim Dee
    Thats the one I thought I had working but did not open all the way
    Very intermittent at best. Car does not pull enough vacuum volume to open it correctly
    This valve seems more of a hook it up to a vacuum switch to turn it on or off, not for dampening use like the 355 needs
  13. k17har
    k17har Karting
    Sep 3, 2009
    144
    london, uk
    kayer
  14. Brigadelok
    Brigadelok Karting
    Jul 31, 2009
    89
    San Anselmo, CA
    Jonathan
    Responding to TrojanFan I rebuilt to bypass valve on my 1998 F355. Let me start with my thoughts on the root cause of the rattle, where there are two major factors, the amount of play in the valve spindle, and the ability of the vacuum/spring actuator to hold the valve firmly in the fully open or closed position. If the actuator is working properly and correctly adjusted, the load in the fully open and closed positions will to some extent compensate for excessive spindle play.
    On my valve the spindle was supported by self aligning ceramic bearings/bushings that mate with a hemispherical surface on the valve body and are held in place with coil springs under the end caps. There is no control of end play except for the butterfly disc contacting the body, where some wear was apparent. The bearing at the actuator end had cracked in three places resulting in excessive shaft play. At the free end there was some shaft wear with a total clearance of about 8 thou. Since I could not find replacement ceramic bearings I made stainless substitutes. I’m not very happy with this from a long term wear perspective and bronze may be a better option. As noted on another bypass valve thread, bearing clearance is hard to gauge due to relative thermal expansion of the various components. I went with 6 thou total clearance as I did not want to risk any binding.
    The only other issue with the repair process is that the screws on the actuator bracket and the butterfly disk are tack welded in place. I’m not really sure that I have a long term solution as I only have about 1500 miles on the repair.
  15. Andy 355
    Andy 355 Formula Junior
    Jun 2, 2013
    434
    unaware of any rebuild of the valve with success. Its basically a cappy valve and away you go. simple as that once you realize the rebuild doesnt exist... Plus new they are pretty good price.
  16. TrojanFan
    Nov 17, 2008
    5,182
    So. CA & NV
    Peter
    Any more thoughts on a successful rebuild of the valve?
  17. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,911
    Richmond
    Pete
    You don't have much to lose...
  18. nathandarby67
    nathandarby67 F1 Veteran
    Feb 1, 2005
    8,349
    Mississippi
    Nathan
    Speaking of aftermarket valves that may not open....is there any concern for damage to the engine from a bypass valve that was stuck in the closed position? Obviously the exhaust flow will not be as efficient so horsepower may be down a touch, but could a closed valve cause any other problems?
  19. Skippr1999
    Skippr1999 F1 Rookie
    4,530
    Yes. Get a Capristo. It fails in the open position,so it doesn't fry things!!
  20. Gialllo uno
    Gialllo uno Formula Junior
    Jul 5, 2014
    346
    Reisterstown, Maryland
    Mark
    I believe mine is frozen and not working. I am going to take it off and see what it looks like. I know a 70 + guy who is a carburetor specialist and has re shafted all types of carbs and has some great skills. Depending on what I can do or what needs to be done, if anything can be done I might let him look at it. I might also look at trying one from eBay that open at a low vacuum pull. I think it was 2 to 5 1/2 psi vacuum pull, which I haven't looked up in the wsm, but believe in another thread that was about where it opened. $139 is worth the effort.
  21. flat_plane_eddie
    flat_plane_eddie F1 Rookie
    Owner Regional Sponsor
    Mar 30, 2013
    3,168
    DC
    Eddie
    Please correct me if I'm wrong but the issue comes from the muffler, not the bypass? I was reading on Capristo's site but kind of skimmed through it.
    From what I understood, the way the factory mufflers are designed, the gasses from both the bypass and the regular passage mix. Thus, if the bypass valve gets stuck (whether the bypass is stock or Capristo), you'll have a back pressure issue.
    However, the Capristo exhaust fixes this by having the exhaust gasses completely separate. Am I off?
  22. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,638
    Elliott Caras
    Capristo's twin sound exhaust removes the single bypass and implements a setup like the 360 with twin by pass and a different bypass path to remove what they believe is a vacuum which causes the exhaust gases to revert towards the cats and headers adding more heat and eventually burning through the headers. This exhaust also removes the F1 scream. Its different from the Capristo 1,2 and 3.
  23. ronrob
    ronrob Formula Junior
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    If the carburetor guy decides to re-shaft, make sure he is aware of the operating temperatures of the by-pass valve.
  24. Gialllo uno
    Jul 5, 2014
    346
    Mark
    I took mine off yesterday and it wasn't even connected properly. The vacuum actuator rod was not attached . I tested the vacuum actuator and it worked perfectly FYI starting movement with approximately 3-5 lbs vacuum . I was using a brake bleeder so not very accurate . I am going to hook up a vacuum Guage in line so that I can get a more precise reading. I have measured the existing stock bypass valve also. The shaft is stiff but not frozen, so I don't know if it can be saved . Maybe I can use my vacuum actuator with one of the aftermarket by pass valves if they Don,t open at the same vacuum . Just thinking out loud . Will report back in on progress . Mark
  25. Gialllo uno
    Jul 5, 2014
    346
    Mark
    Took it to my carb guy this morning and after a careful study of it, he saw that the shaft was bent and caused the binding. He says it is working and I am stoked, but until I get it and test it to see how much vacuum will open it am how smoothly it operates I am holding my breath. I am still ordering the by pass valve from eBay as a potential back up or to see if it will work to possibly help out others with the same issue.
