Time for Engine Out (F355) in primitive conditions (Guam) | FerrariChat
Discussion in '348/355' started by Markphd, Mar 7, 2015.
  1. Markphd
    Markphd Formula Junior
    Mar 10, 2012
    713
    I really wanted to wait until I returned to civilization to tear the F355 down, but a broken propeller shaft means that the car is down hard until I find a replacement (or have one built out of unobtanium). So I guess if I am going to go that far, I might as well pull the motor too.
    Stand by for documentation of the adventure... I will post photos of the interesting lessons and any of the crazy creative stuff I do along the way. I'm not planning on selling my F355 anytime soon, so if some of my creative engineer offends you, you don't have to worry about be pawning it off on someone else.
    I am always open to hints and suggestions. I've got a lot of work ahead! I might add, I don't have a lift... Just floor jacks... It's gonna be a good time.
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    An outfit in Germany has prop-shafts that aren't supposed to break. Le'me go find the link.
  3. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
  4. Markphd
    Mar 10, 2012
    713
    Thanks, I really appreciate the link... It's better to have a source to get one than to not have a source at all, especially if this can be avoided in the future.
    Seriously, what could these driveshafts be made of to cost 2600 Euros?
    I priced Maraging Steel the other day (300 series) and a 24" long shaft 1.125 (which should be more than enough was under $200.00. Now I know machine time isn't cheap, but this isn't exactly the most complex component in the world, it's actually a relatively trivial part to make for a machinist from all outward appearances (a couple of clearance cuts, a bearing surface, a worm gear for the speed-o, and the cuts for the triple seals).
    Still no room to complain, I picked the F355 knowing that it could be an expensive mistress. Time to pay the piper unless I can build a better mouse trap (working on that one).
    Mark
  5. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    The stock shaft will last a lifetime if you drive like an adult. No need for exotic solutions to a simple problem.
  6. Markphd
    Mar 10, 2012
    713
    You are funny... no, it wasn't my driving that caused the shaft to fail, since I have never driven the car abusively, what I suspect happened was related to losing the cam sensor and the out of balance condition that ensued. The shaft broke while the cars was on jack stands, hardly conditions conducive to abusive driving (it wasn't even in gear).
    So, there you have it, perhaps the previous owners abused her but it wasn't under my watch (unless you consider driving it daily abuse).
    Mark
  7. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,633
    SoCal LA/OC/New Mexico
    Tim Dee
    Too bad you need it now, they way the euro is dropping another few months may be a deal
    Time to stock up on GTs parts
    I need another throttle body setup
  8. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    Looking forward to following your thread.
  9. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    Good to know
  10. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #10 2NA, Mar 8, 2015
    The damage was likely done years ago by someone trying to smoke the tires. It finally broke on your watch.
  11. Markphd
    Mar 10, 2012
    713
    Well the transmission is out, and the prop shaft did not spew debris every but broke rather cleanly without drama like the pictures above. I may have gotten lucky on replacing the driveshaft, time will tell on that, but my fingers are crossed as I would much prefer a triple digit solution to a four digit solution.
    Lots of other work to do while I wait on the drive shaft gods to answer my prayers.
  12. Shootfighter65
    Shootfighter65 Formula 3
    May 13, 2014
    1,372
    Charleston SC
    Randy..alluneedtokno
  13. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    I'm in to see some pics.
  14. Markphd
    Mar 10, 2012
    713
    They will be entertaining, from the home made 4x4 wooden beam lift using scaffold jacks (you don't want to know what they would charge to ship a two post lift to Guam) to all the other tomfoolery to remove the offending parts. I will take some pictures soon.
    Good news is that that transmission looks perfect internally... thankfully, there are some bright spots in this story.
    M
  15. Shootfighter65
    May 13, 2014
    1,372
    Charleston SC
    yes....lots of them please
